Defining Head End Systems
You use the Head End System portal to display and maintain Head End Systems.
Refer to Understanding Head End Systems for more information.
You can access the portal by selecting Admin, select Digital Asset Management, then select Head End System.
Head End System List: This zone lists all head end system records. Broadcast a record to display the details of the selected record.
Head End System: This zone provides information about the selected head end system.
Processing Method List: This zone provides the list of processing methods defined for the head end system.
Translation Methods List: This zone provides the list of translation methods defined for the head end system.
Inbound BOs Send By Service Provider: This zone lists inbound business objects that are sent by this head end system. The identification is driven by the Business Object having a Business Object Option of type "Sent By Service Provider" that references the current Head End System.
