Affordability Savings Hub
The Affordability Savings Hub helps customers understand and apply for financial assistance programs at their utility. Customers can use the Savings Hub to learn what programs they are eligible for, and get direct access to enrollment instructions and the tools needed to begin the enrollment process.
Embedding Guidelines
Widget Name: widget-lmi-survey-programs
The Affordability Savings Hub consists of multiple sections, but is embedded as a single widget. There are several factors to consider when embedding it:
- The widget is a full-page experience, and so it must be embedded on its own page.
- It is recommended that you place the Savings Hub widget near the Home Energy Analysis widget or the billing section of your website. This is because customers will likely find a logical connection between signing up for an assistance program, learning more about where they use the most energy, and viewing their billing information. Your Delivery Team will work with you to determine the ideal placement.
For more information about Affordability Savings Hub, including details about its data requirements and the overall user experience, see Affordability Savings Hub - Customer Experience.
