Customer Feedback
The Customer Feedback module is an optional module that can be included to solicit feedback about the Email Home Energy Report. It asks the customer how useful they found the report and provides a way to gather feedback that can be used to improve the report experience. The module questions vary by report type.
Appears in: Peak Focused Report, Progress Report, Promotion Report, Seasonal Report, Solar Report, Time of Use Report
Customer Feedback Examples
The image below shows an example of the module in the Promotion Report.
The image below shows an example of the module as it could appear in the Progress Report, Seasonal Report, Time of Use Report, or Solar Report.
Configuration Options
| Configuration Option | Input Value |
| Prompt Utilities may configure the prompt to reinforce the report promotion. For example, "Is this heat pump water promotion relevant to you?" Default:
 | Optional
