Installation Options - Person
Select Admin Menu, Installation Options and use the Person tab to define person-specific installation options.
Description of Page
Use the Person ID Usage to indicate whether or not at least one form of identification is Required or Optional when a new person is added.
Each form of identification has an identifier type. For persons that are humans (as defined by the person type), the system defaults the identifier type defined in Identifier Type (Person). For persons that are businesses (as defined by the person type), the system defaults the identifier type defined in Identifier Type (Business).
