Searching for a Health Product
Prerequisites
To search for a health product, you should have:
Values defined for the PRODUCT_TYPE_FLG lookup.
Values defined for the PRODUCT_HC_CAT_FLG lookup.
Values defined for the PRODUCT_LOB_FLG lookup.
Characteristic types defined in the application (where the characteristic entity is set to Health Product)
Procedure
To search for a health product:
Click the Menu link in the Application toolbar.
A list appears.
From the Main menu, click Pricing Management and then click Health Product
360° View.
The Health Product 360° View screen appears.
- Select the Health Product Details option from the Search By list to indicate that you want to search for a health product.
Enter the required search criteria in the 360°
Search zone.
ORMB search engine supports wildcard search, where you can substitute the percentage (%) symbol as a stand in for any word or letter in a search criteria. The '%' wildcard character is suffixed automatically at the end of the partial search criteria. Therefore, you may or may not specify the wildcard character at the end of the partial search criteria. However, you have to prefix the wildcard character manually wherever required.
You must specify at least one search criterion while searching for a health product.
The Advanced Search link appears in the right side of the 360° Search zone. On clicking the Advanced Search link, additional fields appear in the zone which help you to refine the search.
If you select a predefined characteristic type, the Search (
) icon appears corresponding to the Characteristic Value field. On clicking the Search icon, you can search for a predefined characteristic value.
Click Search.
A list of health products that meet the search criteria appears in the Search Results section.
Related Topics
For more information on... | See... |
Health Product 360° View screen | Health Product 360° View (Used for Searching) |
360° Search zone | 360° Search |
