Sanity Checks
This step holds a number of checks and rules that execute immediately once the claim enters the processing flow. Note that this step is not performed for locked claim lines and replaced claim lines. The sanity checks flow is schematically depicted by the following figure:
![Sanity Checks](_images/sanity-checks-1.png)
Remove Existing Messages
The messages attached to the claim, claim line and bills that were attached in a previous sanity checks step are removed.
Derivation Rules
A derivation rule sets the value of certain fields on a claim, bill or claim line. There are two types of derivation rules, i.e., for dynamic and fixed fields and for process fields. At this point in the flow, only derivation rules are executed for which the "step" field has the value "pre reversal" which means no process field drivation rules. Pre reversal derivation rules are evaluated even if a fatal message is attached to the same (or higher) level as specified by the derivation rule. The pre reversal derivation rules are evaluated in the following order: claim (header) first, bill second, claim line last. Then, if multiple derivation rules exist, they are executed in order of the configured sequence (sequence null is evaluated last).
Reverse Edits
Reverse edits is a step that always needs to be carried out, both for a claim that comes from the Change page and for a claim that is processed again through the Claims In IP, Claims Update IP or Claims Reprocessing IP (note that this step is skipped for new claims).
Edits that are marked by a tag can be reversed automatically. Whether that actually needs to be done, can be set by an operator in the Change page or by an IP though claim tag actions. These actions refer to a particular claim and a particular skip tag, which can be set through either a callout rule or a replacement rule.
When are edits reversed?
Edits are reversed depending on the claim tag action:
Redo - The edit is reversed unless
One of the lines on the claim has a checked KP/KB/Locked indicator AND was added by the callout / replacement rule
One of the lines on the claim has a checked KP/KB/Locked indicator AND has a fatal message added by the callout rule
One of the lines on the claim has a checked KP/KB/Locked indicator AND has an allowed amount set by the callout rule
Skip or Force - The edit is reversed unless
One of the lines on the claim has a checked Locked indicator AND was added by the callout / replacement rule
One of the lines on the claim has a checked Locked indicator AND has a fatal message added by the callout rule
* One of the lines on the claim has a checked Locked indicator AND has an allowed amount set by the callout rule
Hold - The edit is not reversed.
What is reversed?
Edits are reversed per skip tag. Note that edits on locked claim lines are not reversed. Reversing an edit means:
Claim lines that were added by the callout rule(s) or a replacement rule(s) using the skip tag are removed. If the added line replaced original lines, the original lines are restored.
Any allowed amount and allowed number of units field that was set through the callout rule(s) using the skip tag is cleared (set to 0) and the accompanying skip tag for allowed is cleared.
Any claim line message that was added through the callout rule(s) using the skip tag are removed
Rematching
When reference data like relations, providers and procedures are loaded into OHI Claims from an external source, it can occasionally be that the claim is stored through the Claims In Integration Point while one or more references cannot be resolved. As a result, for the unresolved reference data, unmatched values are stored on the claim, bill or claim line. There are ways to resolve this:
by manually picking the right reference data through a list of values in the 'Receive, Change or Enter Claim' page
by updating the reference through the Claims Update Integration Point
by loading the more recent reference data and then reprocessing the claim so that another attempt is made to match the reference data
This last practice is automated through the rematching step. At all three levels, non-matches are being tried to resolve (a non-match is recognizable by the combination of a missing reference and at least one one of the corresponding non-matched fields being filled). The way of resolving differs, either by
trying to match the non-matched code field against the reference table. This structure applies to:
Serviced entity type (claim, bill and claim line) - matching against insurable entity types
Serviced person (claim, bill and claim line) - matching against persons
Serviced object (claim, bill and claim line) - matching against objects
Service specialty (claim, bill and claim line) - matching against specialties
Messages (claim, bill and claim line) - matching against messages
Modifiers (claim line) - matching against modifiers
Claim line contract references (claim line) - matching against contract references
trying to match the combination of the unmatched code field and the unmatched code definition field against the reference table. This structure applies to:
Service provider (claim, bill and claim line) - matching against providers
Location (claim, bill and claim line) - matching against providers
Referral provider (claim, bill and claim line) - matching against providers
Price individual provider (claim line) - matching against individual providers
Price organization provider (claim line) - matching against organization providers
Benefits provider (claim line) - matching against providers
Procedure (claim line) - matching against procedures belonging to the flex code system as specified under the claims form
Procedure 2 (claim line) - matching against procedures belonging to the flex code system as specified under the claims form
Procedure 3 (claim line) - matching against procedures belonging to the flex code system as specified under the claims form
Claim sub line procedure (claim sub line) - matching against procedures
trying to match the combination of the unmatched code field, the unmatched code definition field and the type code against the reference table.This structure applies to:
Diagnoses (claim, bill and claim line) - matching against diagnoses
trying to match the combination of the unmatched code field and the claim form code against the reference table. This structure applies to:
Location type (claim, bill and claim line) - matching against location types
trying to match either the code or the combination of the unmatched code field and the unmatched code definition field against the reference table. This structure applies to:
Claimant (claim) - matching against relations respectively providers
Payment specification receiver (claim) matching against relations respectively providers
Payment beneficiary (claim) matching against relations respectively providers
Payment receiver (claim, bill and claim line) matching against relations respectively providers
Once a match has been made, the non-matched fields are cleared - just like an update through the UI or the Claims Update Integration Point would accomplish.
Note: Rematching for persons also includes rematching on relation or provider identifiers .
Claim Level Completeness Check
The purpose of this check is to make sure that every piece of information is matched, i.e., that the information provided in the claims "in" integration point message has been successfully mapped to the reference data. This check is also executed for each bill that may be underlying to the claim. The claim completeness check is executed regardless of existing fatal messages.
The following claim fields are checked for non-matches:
Serviced entity (person or object)
Service provider
Service specialty
Claimant
Location
Location type
Referral provider
Payment receiver
Payment beneficiary
Claim messages
Claim diagnoses
The following bill fields are checked for non-matches:
Service provider
Service specialty
Location
Location type
Referral provider
Payment receiver
Bill Messages
Bill Diagnoses
A field is considered to be non-matched in the event that no foreign key has been set for that field and at least one of the pertaining non-matched fields contains a value. When a non-match is detected the following message is attached to the claim:
Code | Sev | Text |
CLA-FL-PPRI-006 |
Fatal |
The {field name} is not matched. |
CLA-FL-PPRI-007 |
Fatal |
One of the {field name} is not matched. |
Examples:
CLA-FL-PPRI-006 |
Fatal |
The serviced entity is not matched. |
CLA-FL-PPRI-006 |
Fatal |
The claimant is not matched. |
CLA-FL-PPRI-007 |
Fatal |
One of the message codes is not matched. |
CLA-FL-PPRI-007 |
Fatal |
One of the diagnoses codes is not matched. |
Note that any non-match will lead to a fatal message on the claim. There is no distinction given the importance of the field. A non-matched serviced entity and non-matched tenth claim diagnosis code will both lead to a fatal message. One message is attached for each non-matched field.
Claim Line Level Completeness Check
The purpose of this check is twofold. First, this check makes sure that everything that was provided on a claim line is actually matched. Second, it is to make sure that everything vital from a processing point of view, is present. As claims are processed per line, this latter check only on the line level. The claim line completeness check is executed regardless of existing fatal messages.
The following claim line fields are checked for non-matches:
Service provider
Service specialty
Location
Location type
Referral provider
Payment receiver
Procedure
Procedure 2
Procedure 3
Benefits provider
Claim line messages
Claim line diagnoses
Claim line modifiers
In the event that a non match is detected, a fatal message is attached to the line. One message is attached for each non-matched field:
Code | Sev | Text |
CLA-FL-PPRI-006 |
Fatal |
CLA-FL-PPRI-007 |
Fatal |
Examples:
CLA-FL-PPRI-006 - The serviced entity is not matched.
CLA-FL-PPRI-006 - The claimant is not matched.
CLA-FL-PPRI-007 - One of the claim line message codes is not matched.
CLA-FL-PPRI-007 - One of the claim line diagnoses codes is not matched.
Because any non matched field may be key in determining the right price or benefit, the CLA-FL-PPRI-006 and 007 are fatal. Claim line procedures are an exception: a configuration option is available for non matched claim line procedures to result in an informative message rather than a fatal message. This configuration is available under the claims form. If the "Fatal non match" indicator is unchecked for a procedure, and that procedure is unmatched, the following message is generated instead of the the CLA-FL-PPRI-006:
Code | Sev | Text |
CLA-FL-PPRI-020 |
Info |
The {procedure display name} is not matched. |
The procedure display name value is configured under the claims form.
After the non-matches have been checked, the system re-checks the serviced entity. If the serviced entity is neither matched nor unmatched, i.e., not specified at all, then the following message is generated:
Code | Sev | Text |
CLA-FL-PPRI-008 |
Fatal |
The serviced entity must be specified. |
The completeness check only covers those fields which are not mandatory in the claims data model. These are fields that can be on multiple levels or may be non-matched. Mandatory fields (such as the claim line start date) are not checked at this point; if this field was not specified the claim would not have been accepted by the integration point.
Claim Line Level General Checks
After the completeness check, a number of basic checks regarding time validity and the use of procedures are done for each claim line. General checks are only executed on line level because information on the claim or bill level is inherited down to the claim line level. Claim line level general checks are not evaluated if a fatal message (of origin MANUAL, EXTERNAL or SANITY CHECKS) exists that is attached to the claim line, or the bill or claim to which the line belongs.
Time validity of codes
All the codes that can be used on a claim or claim line can have a start date and an end date. The check whether a code is valid on the right date of the claim is performed in this step. The check is performed in the following way
At the claim level no time validity checks will be performed. This is because the claim has no "as-of" date to check a code’s validity against. In addition, if the claim holds provider and diagnosis information, that information will have inherited down to the lines that did not specify their own. Since the lines are checked, checking at the claim level is redundant.
For procedures, diagnoses, providers and flex code values, the code must be valid on the start date of the claim line. More precise:
The procedure/diagnosis/provider/flex code’s start date must be on or before the start date of the claim line
The procedure/diagnosis/provider/flex code’s end date must be either unspecified, on or after the start date of the claim line
If this is not the case the following message will be attached to the claim line:
Code | Sev | Text |
CLA-FL-PPRI-002 |
Fatal |
The value of the code {code} in the field {'field display name'} should be valid at {'claim line.startdate'} |
If this is not the case with flex codes on dynamic records the following message will be attached to the claim line:
Code | Sev | Text |
CLA-FL-PPRI-018 |
Fatal |
The value of the code {code} in the field {'record field display name'} on dynamic record {'field display name'} should be valid at {'claim line.startdate'} |
Procedure age and gender
A claim line can specify up to three procedures. This step handles the validation of a claim line with regard to the allowed age and gender that can be specified on procedures. These attributes represent conditions that must be met by a serviced person in order to claim the specified procedure. The age is determined as the age on the claim line start date.
If the person fails to meet the age and or gender conditions, then the following message is attached to the claim line.
Code | Sev | Text |
CLA-FL-PPRI-003 |
Fatal |
The serviced person’s age {'person.age'} exceeds the age bounds {'procedure setting.age from'}, {'procedure setting.age to'}, as specified for the procedure. |
CLA-FL-PPRI-021 |
Fatal |
The serviced person’s age {'person.age'} exceeds the age bounds {'procedure setting.age from'}, {'procedure setting.age to'}, as specified for the second procedure. |
CLA-FL-PPRI-022 |
Fatal |
The serviced person’s age {'person.age'} exceeds the age bounds {'procedure setting.age from'}, {'procedure setting.age to'}, as specified for the third procedure. |
Note that the bounds on the procedure are inclusive: if the "age to" is 75 and the person is exactly 75 years old on the as-of date, then no fatal message is attached.
In the event that the procedure gender attribute is specified, the gender of the serviced person has to be the same. If this is not the case, then the following message is attached to the claim line:
Code | Sev | Text |
CLA-FL-PPRI-004 |
Fatal |
The serviced person’s gender {'serviced person.gender'} does not match the gender {'procedure setting.gender'} specified for the procedure. |
CLA-FL-PPRI-023 |
Fatal |
The serviced person’s gender {'serviced person.gender'} does not match the gender {'procedure setting.gender'} specified for the second procedure. |
CLA-FL-PPRI-024 |
Fatal |
The serviced person’s gender {'serviced person.gender'} does not match the gender {'procedure setting.gender'} specified for the third procedure. |
Note that this check is only relevant if the claim or claim line relates to a serviced person. It does apply to serviced objects.
Serviced Entity Type
An additional validation is executed to check whether the serviced entity type is valid for the line of business related to the claim form.
Code | Sev | Text |
CLA-FL-PPRI-025 |
Fatal |
The serviced entity type {type} is not valid for line of business {code}. |
Evaluate External Intervention Rules
All external intervention rules of the sub type MANUAL CHANGE are evaluated. A rule triggers when all a claim, claim line or bill satisfies all criteria set by the rule.
For each triggered external intervention rule, the specified pend reason is checked: if the reattach indicator is unchecked and the pend reason history indicates that the same pend reason has been previously attached on the same level (claim, bill or line), then the pend reason is not attached and the claim will not pend because of this external intervention rule. Otherwise, the specified pend reason is attached to the claim, claim line or bill, and added to the claim pend reason history.
If no pend reasons are attached as a result of the external intervention rule evaluation, then the claim skips ahead to the "Pre Pricing" step. Otherwise, the claim indicators "Preprocessing Done?" and "Pricing Done?" are unchecked and the claim status is set to CHANGE. See the implementation guide on claims flow configuration for more details on how to configure external intervention rules.
