Group Validation Rules
A group validation rule is a user defined validation of the data elements on the group client. The result of failing the validation is that a message is attached to the group client and/or a function dynamic logic is executed that can set certain fields and can also add messages to the group client. Fatal messages prevent that the group client can be approved.
Field | Description |
Code |
The identifying code of the group client validation rule |
Description |
The description of the group client validation rule |
Level |
The level of the validation: Group Client or Group Account |
Condition |
The dynamic logic condition that is executed to determine if the message must be attached to the group client and/or the dynamic logic function must be executed |
Function |
The dynamic logic function that is executed if all conditions are met |
Message |
The message that is attached to the group client if all conditions are met (the message placeholders are described below) |
Process flow |
The process flow to which this validation rule is restricted |
Exclude from Validation? |
Is the group client validation rule excluded from the validation process? |
Enabled? |
Is the group client validation rule enabled? |
The use of a group validation rule can be restricted to a single group process flow. If the rule’s process flow has no value, the validation rule can be used in any process flow.
Message Placeholders (Group Clients)
The following table specifies the placeholder values (per level) for messages that are attached to group clients when a group client validation rule is applied:
# | Group Client | Group Account |
0 |
The code of the rule |
1 |
The description of the rule |
2 |
The level of the validation |
3 |
N/A |
The code of the group account |
4 |
N/A |
N/A |
5 |
N/A |
N/A |
6 |
N/A |
N/A |
7 |
N/A |
N/A |
8 |
N/A |
N/A |
9 |
N/A |
N/A |
