Service Definition, Product Service Definition, and Benefit Priorities
Just as benefit specifications are based on a combination of a service definition and a product service definition, benefit priorities can also be based on the combination of a service definition priority and a product service definition priority. But this is not mandatory, benefit priorities can also be based on solely a service definition priority or a product service definition priority.
So dependent on the configured priorities three flavors are automatically created:
Benefit Priorities based on a service definition and a product service definition priority
Benefit Priorities based on a service definition priority (and no product service definition priority)
Benefit Priorities based on a product service definition priority (and no service definition priority)
To clarify this and the (im)possibilities, some examples are given in this document.
Using Only Product Service Definition Priorities
Consider the following example containing two product service definition priorities.
Code | Short Code | Display Name | Priority |
REGULAR |
REGL |
Regular Service |
3 |
FEDERAL MANDATE |
FMAN |
Federal Mandate |
2 |
This results in the generation of two benefit priorities.
Benefit Priorities
FEDERAL MANDATE |
Federal Mandate |
2999 |
REGULAR |
Regular Service |
3999 |
The value of the benefit priority is calculated as follows:
Product Service Definition Priority * 1000 + Service Definition Priority AND if either priority is missing, use value "999" for that priority
This is why the value of the resulting benefit priority is "2999" and not "2".
Combined Priorities
Using both service definition and product service definition priorities to generate benefit priorities allows for the most fine grained list of benefit priorities, as each possible combination of two priorities results in a benefit priority. Consider the following example containing two product service definition priorities.
REGULAR |
REGL |
Regular Service |
3 |
FEDERAL MANDATE |
FMAN |
Federal Mandate |
2 |
And two service definition priorities.
DEFAULT |
DFLT |
Default |
5 |
EXCEPTION |
EXCP |
Exception |
3 |
These configured (product) service definition priorities result in the generation of the following benefit priorities (ordered from high to low priority).
Benefit Priorities
FMANEXCP |
Federal Mandate Exception |
2003 |
FMANDFLT |
Federal Mandate Default |
2005 |
FEDERAL MANDATE |
Federal Mandate |
2999 |
REGLEXCP |
Regular Service Exception |
3003 |
REGLDFLT |
Regular Service Default |
3005 |
REGULAR |
Regular Service |
3999 |
EXCEPTION |
Exception |
999003 |
DEFAULT |
Default |
999005 |
For each benefit priority that is based on two priorities the two short codes are used to create the code for the benefit priority. If the benefit priority is only based on a single priority, the code of that priority is used to create the code of the benefit priority.
Incorrect Setup
It is not possible to create a service definition and a product service definition priority with the same code. This will encounter an error when benefit priorities are generated. So the following example must be avoided.
