Efficiency Zone
The Efficiency Zone module is designed to motivate customers to save energy by showing how their usage compares to similar homes. It reframes the Efficient Homes concept from the Neighbor Comparison to improve customer satisfaction while maintaining a focus on energy efficiency. The module includes a bar graph that compares the customer's energy use and similar homes' usage against an Efficiency Zone, along with insights that help put the customer's usage into context. Usage at or below the threshold falls within the Efficiency Zone. This threshold is based on the average energy use of the most efficient 20% of similar homes during the billing period and may change with each report.
The normative comparison in Digital Self Service – Energy Management mirrors the customer's report experience. For example, if a customer sees the Efficiency Zone in their report, they will also see it in Digital Self Service – Energy Management. For more information about the web version of the Efficiency Zone, see Digital Self Service Energy Management Efficiency Zone.
Appears in: Progress Report, Welcome and Announcement Report, Limited Income Report, Time of Use Report
Utilities have the option of including either the Efficiency Zone or Three-Bar Neighbor Comparison module in most report types.
Requirements
Utility Requirements
Category Description
Required Cloud Service Energy Efficiency Cloud Service
Scale Less than 100,000 per week
Customer Requirements
Billing Frequency Monthly, bi-monthly, or quarterly
Data Delivery Frequency Monthly, bi-monthly, or quarterly
Data Requirements Billing data and third-party data (GSI and parcel data)
Data History A minimum of one historical bill
Data Coverage Not applicable. See Data Requirements.
Supported Fuels Monthly, bi-monthly, or quarterly
Limitations
  • Home Energy Reports vs. Web: Customers receive an Efficiency Zone user variation in the web product which differs slightly from the Efficiency Zone in the reports. See the Neighbor Comparison section of the Oracle Utilities Opower Digital Self Service - Energy Management Cloud Service Product Overview for more information.
  • Third-Party Data: Third-party data (GIS and parcel data) is needed to identify neighbors for the neighbor selection process.
  • Neighbor Selection: A minimum number of neighbors (the default target is 100) must be selected for the customer. See Neighbor Selection - Detailed for more information.
  • Solar Report: The Efficiency Zone cannot be included in the Solar Report. Solar customers receive a solar variation of the three-bar neighbor comparison. See Three-Bar Neighbor Comparison for more information.
User Experience
Efficiency Zone
This section describes the most common user experience for the Efficiency Zone. This image is an example of the Efficiency Zone.
Image of an example of the Efficiency Zone
Heading: "How you compare to others." invites the customer to explore their normative comparison and learn about their energy use in more detail.
Threshold: The label above the graph introduces the maximum Efficiency Zone threshold (for example, Up to 500 kWh). The threshold is the average use of the 20th percentile of similar homes during that bill period. A green tinted rectangle and darker vertical line indicate the range and upper boundary of the Efficiency Zone, enabling customers to quickly see whether they are in the zone. The threshold is recalculated and changes with each report.
Graph: Displays how much energy the customer (You) used in comparison with Similar Homes. The Similar Homes bar indicates the average use of the customer's neighbors.
Hero Insight: The large colorful numeric percentage to the right in the gray column which displays the customer's status relative to the Efficiency Zone or to Similar Homes. The color of the large number and percent sign varies, depending on their state. If the customer is within the Efficiency Zone, the large number is green. If the customer is not within the Efficiency Zone, the large number is orange.
The hero insight has three primary states:
  • Great: In the Efficiency Zone
  • Good or Fair: Outside the Efficiency Zone
  • Fair: Higher than Similar Homes
Explainer Text: Defines the efficiency zone for the customer.
Secondary Insight: The smaller green check mark or orange X – (not pictured) located under the Hero Metric that presents the customer with their status relative to the other comparison group. Depending on how the customer is performing, the color of the secondary insight is either green (Great or Good) or orange (Fair). There are several possible states:
  • Great: Near the Efficiency Zone
  • Good: Lower than Similar Homes
  • Good: About the same as Similar Homes
  • Fair: Not in the Efficiency Zone
User Experience Variations
Fuel Type
Gas-only and dual fuel customers see a variation in the units of energy displayed in the Efficiency Zone module. The electricity unit "kWh" is replaced by "therms" for gas-only customers and "units" for dual fuel customers. Moreover, there is a variation in the wording of the insight statement. The word "electricity" is replaced by "natural gas" for gas-only customers, and "energy" for dual fuel customers.
Substituting the Neighbor Comparison for the Efficiency Zone
Utilities have the option of including either the Efficiency Zone or Three-Bar Neighbor Comparison module in their reports. It is recommended that utilities with a savings-focus include a Three-bar Neighbor Comparison in their report experience instead of the Efficiency Zone. Contact your Delivery Teamfor more information.
