If the target host is an x86-based system running Oracle Linux, run the following command to perform a loopback mount of the ISO:
# mount -o loop/tmp/OracleVM-Manager.iso/mnt
Substitute /tmp/OracleVM-Manager.iso
with the full path to the ISO. Substitute
/mnt with the path to the directory
on the file system to use as a mount point. From this point
onward, you can access the contents of the ISO at the location
of your mount point.
