When you perform a deployment, you might experience a
Command failed error when starting the Ansible
container, for example:
TASK [common : Starting Ansible container]
fatal: [ol7-c4]: FAILED! => {"changed": false, "failed": true, "msg":
"ConnectionError(ProtocolError('Connection aborted.', error(2, 'No such file or directory')),)"}
PLAY RECAP
ol7-c4 : ok=3 changed=0 unreachable=0 failed=1
Traceback (most recent call last):
File "/usr/lib/python2.7/site-packages/kollacli/commands/deploy.py", line66, in take_action
verbose_level)
File "/usr/lib/python2.7/site-packages/kollacli/common/ansible/actions.py",line 89, in deploy
playbook.run()
File"/usr/lib/python2.7/site-packages/kollacli/common/ansible/playbook.py", line139, in run
raise e
CommandError: ERROR: Command failed. :This occurs when the Docker Engine is not running on a target node. To resolve this issue:
Ensure that the Docker Engine is running on all target nodes.
To check that the Docker Engine is running:
systemctl status docker.service● docker.service - Docker Application Container Engine Loaded: loaded (/usr/lib/systemd/system/docker.service; enabled; vendor preset: disabled) Drop-In: /etc/systemd/system/docker.service.d └─docker-sysconfig.conf, var-lib-docker-mount.conf Active: inactive (dead) since Tue 2016-03-29 13:20:53 BST; 2min 35s ago ...If the output of this command shows the status of the Docker service to be
inactive (dead), start the Docker Engine.# systemctl start docker.service
From the master node, deploy OpenStack services to the target nodes.
If you are using the Oracle Container Registry, you might need to sign in at https://container-registry.oracle.com and accept the Oracle Standard Terms and Restrictions for the Oracle software images before you can deploy.
$ kollacli deploy
