Skip Navigation Links
Exit Print View
Sun Server X2-4 (formerly Sun Fire X4470 M2)
Service Manual
search filter icon
search icon
Document Information
Using This Documentation
1.  Sun Server X2-4 Service Manual Overview
1.1 System Overview
1.1.1 Intel Xeon E7 Platform
1.1.2 Block Diagrams
1.1.3 Processors (CPUs)
1.1.4 Memory
1.1.5 Cooling
1.1.6 Input/Output (I/O)
1.1.7 Summary of Supported Components and Capabilities
1.2 Server Front Panel Features
1.3 Server Back Panel Features
1.4 Performing Service Related Tasks
2.  Preparing to Service the Sun Server X2-4
2.1 Location of Replaceable Components
2.2 Tools and Equipment Needed
2.3 Performing Electrostatic Discharge and Static Prevention Measures
2.3.1 Using an Antistatic Wrist Strap
2.3.2 Using an Antistatic Mat
2.4 Positioning the Server for Maintenance
Extend the Server to the Maintenance Position
2.5 Releasing the Cable Management Arm
Release the CMA
2.6 Powering Off the Server
Power Off the Server Using the Service Processor Command-Line Interface
2.7 Removing the Server Top Cover
Remove the Server Top Cover
2.8 Removing or Installing Filler Panels
2.9 Attaching Devices to the Server
2.9.1 Connector Locations
2.9.2 Cabling the Server
3.  Servicing CRU Components That Do Not Require Server Power Off
3.1 Servicing Disk Drives (CRU)
3.1.1 Disk Drive Status LED Reference
3.1.2 Removing and Installing Disk Drives and Disk Drive Filler Panels
Remove a Disk Drive Filler Panel
Remove a Disk Drive
Install a Disk Drive
Install a Disk Drive Filler Panel
3.2 Servicing Fan Modules (CRU)
3.2.1 About Server Fans
3.2.2 Fan Module LED Reference
3.2.3 Detecting Fan Module Failure
3.2.4 Removing and Installing Fan Modules
Remove a Fan Module
Install a Fan Module
3.3 Servicing Power Supplies (CRU)
3.3.1 Power Supply LED Reference
3.3.2 Detecting a Power Supply Failure
3.3.3 Removing and Installing Power Supplies
Remove a Power Supply
Install a Power Supply
4.  Servicing CRU Components That Require Server Power Off
4.1 Servicing Memory Risers and DIMMs (CRU)
4.1.1 CPUs, Memory Risers, and DIMMs Physical Layout
4.1.2 Memory Riser Population Rules
4.1.3 Memory Riser DIMM Population Rules
4.1.4 Memory Performance Guidelines
4.1.5 DIMM Fault Isolation
4.1.6 Supported DIMMs
4.1.7 Unsupported DIMMs
4.1.8 Removing and Installing Memory Risers, DIMMs, and Filler Panels
Remove a Memory Riser Filler Panel
Remove a DIMM Filler Panel
Remove a Memory Riser and DIMM
Install Memory Risers and DIMMs
Install a Memory Riser Filler Panel
Install a DIMM Filler Panel
4.2 Servicing PCIe Cards (CRU)
4.2.1 PCIe Card Configuration Rules
4.2.2 PCIe Cards With Bootable Devices
4.2.3 Avoiding PCI Resource Exhaustion Errors
4.2.4 Removing and Installing PCIe Cards and PCIe Card Filler Panels
Remove a PCIe Card Filler Panel
Remove a PCIe Card
Install a PCIe Card
Install a PCIe Card Filler Panel
4.3 Servicing the DVD Drive and DVD Driver Filler Panel (CRU)
Remove the DVD Drive or DVD Drive Filler Panel
Install the DVD Drive or DVD Drive Filler Panel
4.4 Servicing the System Lithium Battery (CRU)
Remove the System Battery
Install the System Battery
5.  Servicing FRU Components
5.1 Servicing the CPU and Heatsink (FRU)
5.1.1 CPU Placement
5.1.2 Removing and Installing a Heatsink Filler Panel, CPU Cover Plate, Heatsink, and CPU
5.2 Servicing the Fan Board (FRU)
Remove the Fan Board
Install the Fan Board
5.3 Servicing the Power Supply Backplane (FRU)
Remove the Power Supply Backplane
Install the Power Supply Backplane
5.4 Servicing the Disk Drive Backplane (FRU)
Remove the Disk Drive Backplane
Install the Disk Drive Backplane
5.5 Servicing the Motherboard (FRU)
Remove the Motherboard
Install the Motherboard
6.  Returning the Server to Operation
6.1 Replacing the Server Top Cover
Replace the Server Top Cover
6.2 Returning the Server to the Normal Rack Position
Return the Server to the Normal Rack Position
6.3 Powering On the Server
Power On the Server
7.  Servicing the Server at Boot Time
7.1 Powering On the Server
7.2 About the BIOS
7.3 Default BIOS Power-On Self-Test (POST) Events
7.4 BIOS POST F1 and F2 Errors
7.5 How BIOS POST Memory Testing Works
7.6 Ethernet Port Device and Driver Naming
7.6.1 Ethernet Port Booting Priority
7.7 BIOS Setup Utility Menus
7.8 Performing Common BIOS Procedures
Access the BIOS Setup Utility
Reset the BIOS Password
Configure Support for TPM
Configure SP LAN Settings
Configure Option ROM Settings
7.8.1 Configuring Serial Port Sharing
7.9 BIOS and SP Updates
7.10 BIOS Configuration Tool
8.  Troubleshooting the Server and ILOM Defaults
8.1 Troubleshooting the Server
8.2 Diagnostic Tools
8.2.1 Diagnostic Tool Documentation
8.3 Using the Preboot Menu Utility
8.3.1 Accessing the Preboot Menu
8.3.1.1 Prerequisites for Accessing the Preboot Menu
Access the Preboot Menu
Edit Preboot Menu for Remote Serial Access
8.3.1.2 Edit Mode Settings in Preboot Menu
8.3.2 Restoring Oracle ILOM to Default Settings
Reset Oracle ILOM Configuration Using the Preboot Menu
8.3.3 Restoring Oracle ILOM Access to the Serial Console
Restore Access to the Serial Console Using the Preboot Menu
8.3.4 Restoring the SP Firmware Image
8.3.4.1 Prerequisites for Restoring SP Firmware Using the Preboot Menu
Restore the SP Firmware Image Using the Preboot Menu
8.3.5 Preboot Menu Command Summary
8.4 Contacting Support
8.5 Locating the Chassis Serial Number
A.  Server Specifications
A.1 Physical Specifications
A.2 Electrical Specifications
A.3 Environmental Requirements
B.  BIOS Setup Utility Menus
B.1 BIOS Main Menu Selections
B.2 BIOS Advanced Menu Selections
B.3 BIOS PCIPnP Menu Selections
B.4 BIOS Boot Menu Selections
B.5 BIOS Security Menu Selections
B.6 BIOS IO/MMIO Menu Selections
B.7 BIOS Chipset Menu Selections
B.8 BIOS Exit Menu Selections
C.  Connector Pinouts
C.1 USB Connectors
C.2 Serial Connector
C.3 Gigabit-Ethernet Connectors
C.4 Network Management Port Connector
C.5 Video Connectors
C.6 Serial Attached SCSI (SAS) Connector
D.  Getting Server Firmware and Software
D.1 Firmware and Software Updates
D.2 Firmware and Software Access Options
D.3 Available Software Release Packages
D.4 Accessing Firmware and Software
Download Firmware and Software Using My Oracle Support
D.4.1 Requesting Physical Media
D.4.2 Gathering Information for the Physical Media Request
D.5 Installing Updates
D.5.1 Installing Firmware
D.5.2 Installing Hardware Drivers and OS Tools
Index
You might need to have your server's serial number when you ask for service on your system. Record this number for future use. Use one of the following methods to locate your server's serial number:
