Skip Navigation Links | |
Exit Print View | |
Sun Server X2-4 (formerly Sun Fire X4470 M2) Installation Guide for Linux Operating Systems |
Part I Linux Software Installation on x86 Servers
1. Assisted OS Installation With Oracle Hardware Installation Assistant
Oracle Hardware Installation Assistant Task Overview
How to Obtain Oracle Hardware Installation Assistant
Oracle Hardware Installation Assistant Documentation Resources
Supported Linux Operating Systems
Linux Installation Prerequisites
Linux Installation Task Overview
Oracle Unbreakable Enterprise Kernel for Linux
Installing Oracle Linux 5 Using Local or Remote Media
Install Oracle Linux 5 Using Local or Remote Media
Installing Oracle Linux 5 Using a PXE Network Environment
Install Oracle Linux 5 Using PXE Network Boot
Oracle Linux Post Installation Tasks
Register Oracle Linux and Activate Automatic Updates
Installing Oracle Unbreakable Enterprise Kernel for Linux Using Local or Remote Console
Install Oracle Unbreakable Enterprise Kernel for Linux Using Local or Remote Console
4. Installing SUSE Linux Enterprise Server
Installing SLES 11 SP1 Using Local or Remote Media
Installing SLES 11 SP1 Using a PXE Network Environment
5. Installing Red Hat Enterprise Linux
Installing RHEL 5.5 or 6.0 Using Local or Remote Media
Installing RHEL 5.5 or 6.0 Using a PXE Network Environment
Installing the Oracle Unbreakable Enterprise Kernel for Linux
6. Getting Server Firmware and Software
Firmware and Software Access Options
Available Software Release Packages
Accessing Firmware and Software
Part II Linux System Administrator References
A. Supported Installation Methods
B. Supported Operating Systems
C. BIOS Defaults for New Installations
Before installing the Oracle Unbreakable Enterprise Kernel for Linux, you must have Oracle Linux 5.5 or later, or Red Hat Enterprise Linux (RHEL) 5.5 or 6.0 installed on your server.
[el5_u5_base] name=Enterprise Linux $releasever U5 - $basearch - base baseurl=http://publicyum. oracle.com/repo/EnterpriseLinux/EL5/5/base/$basearch/ gpgkey=http://public-yum.oracle.com/RPM-GPG-KEY-oracle-el5 gpgcheck=1 enabled=1 [ol5_u5_base] name=Oracle Linux $releasever - U5 - x86_64 - base baseurl=http://publicyum. oracle.com/repo/OracleLinux/OL5/5/base/x86_64/ gpgkey=http://public-yum.oracle.com/RPM-GPG-KEY-oracle-el5 gpgcheck=1 enabled=1
[ol6_ga_base] name=Oracle Linux 6 GA - $basearch - base baseurl=http://public-yum.oracle.com/repo/OracleLinux/OL6/0/base/$basearch/ gpgkey=http://public-yum.oracle.com/RPM-GPG-KEY-oracle-ol6 gpgcheck=1 name=Oracle Linux 6 GA - $basearch - base enabled=1
# yum install kernel
Or
# yum install oracle-linux
# yum install kernel-uek
Or
# yum update
Note - For more information on the Oracle Unbreakable Enterprise Kernel for Linux, see the product notes at: http://www.oracle.com/pls/topic/lookup?ctx=SunServerX2-4.
