Skip Navigation Links | |
Exit Print View | |
Sun Server X2-4 (formerly Sun Fire X4470 M2) Installation Guide for Linux Operating Systems |
Part I Linux Software Installation on x86 Servers
1. Assisted OS Installation With Oracle Hardware Installation Assistant
Oracle Hardware Installation Assistant Task Overview
How to Obtain Oracle Hardware Installation Assistant
Oracle Hardware Installation Assistant Documentation Resources
Supported Linux Operating Systems
Linux Installation Prerequisites
Linux Installation Task Overview
Oracle Unbreakable Enterprise Kernel for Linux
Installing Oracle Linux 5 Using Local or Remote Media
Installing Oracle Linux 5 Using a PXE Network Environment
Oracle Linux Post Installation Tasks
Installing Oracle Unbreakable Enterprise Kernel for Linux Using Local or Remote Console
4. Installing SUSE Linux Enterprise Server
Installing SLES 11 SP1 Using Local or Remote Media
Installing SLES 11 SP1 Using a PXE Network Environment
5. Installing Red Hat Enterprise Linux
Installing RHEL 5.5 or 6.0 Using Local or Remote Media
Installing RHEL 5.5 or 6.0 Using a PXE Network Environment
Installing the Oracle Unbreakable Enterprise Kernel for Linux
6. Getting Server Firmware and Software
Firmware and Software Access Options
Available Software Release Packages
Accessing Firmware and Software
Download Firmware and Software Using My Oracle Support
Gathering Information for the Physical Media Request
Installing Hardware Drivers and OS Tools
Part II Linux System Administrator References
A. Supported Installation Methods
B. Supported Operating Systems
C. BIOS Defaults for New Installations
This section covers instructions for downloading or requesting software release files. See:
The Patches and Updates screen appears.
The screen appears with search fields.
Alternatively, type a full or partial product name (for example, Sun Server X2-4) until a match appears.
Expand the folders to see all available software releases.
The software release comprises a set of downloads (patches).
See Available Software Release Packages for a description of the available downloads.
A pop-up action panel appears. The panel contains several action options.
The File Download dialog box appears.
The patch file downloads.
If your processes do not allow downloads from Oracle web sites, you can access the latest software release through a physical media request (PMR).
The following table describes the high-level tasks for making a physical media request and provides links for further information.
You must have a warranty or support contract for your server in order to make a physical media request (PMR).
Before you make the PMR, gather the following information:
Obtain product name, software release version, and patches required. It will be easier to make the request if you know the latest software release and the name of the download packages (patches) that you are requesting.
If you have access to My Oracle Support – Follow the instructions in Download Firmware and Software Using My Oracle Support to determine the latest software release and view available downloads (patches). After viewing the list of patches, you can navigate away from the Patch Search Results page, if you do not want to continue with the download steps.
If you do not have access to My Oracle Support – Use the information in Available Software Release Packages to determine which packages you want, then request those packages for the latest software release.
Have the shipping information ready. You will need to provide a contact, phone number, email address, company name, and shipping address as part of the request.
Before You Begin
Gather the information described in Gathering Information for the Physical Media Request before making the request.
You do not need to supply any information.
Before You Begin
If you are able to access the specific software release and patch number information from My Oracle Support, provide this information to the support representative.
If you are unable to access the software release information, request the latest software release for the Sun Server X2-4.
