Skip Navigation Links | |
Exit Print View | |
Sun Server X2-4 (formerly Sun Fire X4470 M2) Installation Guide for Linux Operating Systems |
Part I Linux Software Installation on x86 Servers
Oracle Hardware Installation Assistant Task Overview
How to Obtain Oracle Hardware Installation Assistant
Oracle Hardware Installation Assistant Documentation Resources
Supported Linux Operating Systems
Linux Installation Prerequisites
Linux Installation Task Overview
Oracle Unbreakable Enterprise Kernel for Linux
Installing Oracle Linux 5 Using Local or Remote Media
Installing Oracle Linux 5 Using a PXE Network Environment
Oracle Linux Post Installation Tasks
Installing Oracle Unbreakable Enterprise Kernel for Linux Using Local or Remote Console
4. Installing SUSE Linux Enterprise Server
Installing SLES 11 SP1 Using Local or Remote Media
Installing SLES 11 SP1 Using a PXE Network Environment
5. Installing Red Hat Enterprise Linux
Installing RHEL 5.5 or 6.0 Using Local or Remote Media
Installing RHEL 5.5 or 6.0 Using a PXE Network Environment
Installing the Oracle Unbreakable Enterprise Kernel for Linux
6. Getting Server Firmware and Software
Firmware and Software Access Options
Available Software Release Packages
Accessing Firmware and Software
Part II Linux System Administrator References
A. Supported Installation Methods
B. Supported Operating Systems
C. BIOS Defaults for New Installations
Oracle Hardware Installation Assistant makes operating system installation easy. With Oracle Hardware Installation Assistant, all you need to begin is a licensed copy of Linux or Windows OS distribution media supported for your server. All software and required server-specific drivers are supplied by Oracle Hardware Installation Assistant. With a graphical wizard interface and flexible installation options, Oracle Hardware Installation Assistant brings simplicity, speed, and reliability to your server deployments.
To use Oracle Hardware Installation Assistant, simply boot the Oracle Hardware Installation Assistant program from the server's CD drive, a USB flash drive, or from a network image. Check for the latest Oracle Hardware Installation Assistant updates that are available. Select your OS distribution from the menu and follow the on-screen instructions. Oracle Hardware Installation Assistant scans your system to ensure that it has the drivers it needs to configure your server components[1]. It also provides you the option of having Oracle Hardware Installation Assistant check for the latest drivers that are available. Oracle Hardware Installation Assistant will prompt you for the appropriate media as needed and any other required information during the OS installation process (such as license keys).
Note - [1] Some option card drivers are downloaded to the server, but require manual installation. Feature enhancements are made to Oracle Hardware Installation Assistant regularly; therefore, you should check the Oracle Hardware Installation Assistant information page for the latest Oracle Hardware Installation Assistant updates and supported features http://www.oracle.com/goto/hia.
Topics discussed in this chapter include:
