Skip Navigation Links | |
Exit Print View | |
Sun Server X2-4 (formerly Sun Fire X4470 M2) Installation Guide for Linux Operating Systems |
Part I Linux Software Installation on x86 Servers
1. Assisted OS Installation With Oracle Hardware Installation Assistant
How to Obtain Oracle Hardware Installation Assistant
Oracle Hardware Installation Assistant Documentation Resources
Supported Linux Operating Systems
Linux Installation Prerequisites
Linux Installation Task Overview
Oracle Unbreakable Enterprise Kernel for Linux
Installing Oracle Linux 5 Using Local or Remote Media
Installing Oracle Linux 5 Using a PXE Network Environment
Oracle Linux Post Installation Tasks
Installing Oracle Unbreakable Enterprise Kernel for Linux Using Local or Remote Console
4. Installing SUSE Linux Enterprise Server
Installing SLES 11 SP1 Using Local or Remote Media
Installing SLES 11 SP1 Using a PXE Network Environment
5. Installing Red Hat Enterprise Linux
Installing RHEL 5.5 or 6.0 Using Local or Remote Media
Installing RHEL 5.5 or 6.0 Using a PXE Network Environment
Installing the Oracle Unbreakable Enterprise Kernel for Linux
6. Getting Server Firmware and Software
Firmware and Software Access Options
Available Software Release Packages
Accessing Firmware and Software
Part II Linux System Administrator References
A. Supported Installation Methods
B. Supported Operating Systems
C. BIOS Defaults for New Installations
You can perform the following tasks using Oracle Hardware Installation Assistant:
Note - The supported Oracle Hardware Installation Assistant installation and recovery tasks listed below are server-dependent and might vary.
Perform an assisted installation of a Linux or Windows operating system on your Sun x86 server from Oracle. Oracle Hardware Installation Assistant provides the appropriate drivers and platform-specific software, eliminating the need to create a separate driver disk.
Optionally create RAID-0 or RAID-1 volumes on internal storage devices.
Optionally upgrade your system's Oracle Integrated Lights Out Manager (ILOM) service processor (SP), BIOS, and storage device firmware (regardless of the OS on your server).
Optionally update your Oracle Hardware Installation Assistant session with the latest firmware and drivers.
Optionally recover from a corrupt or inaccessible Oracle ILOM service processor.
