Skip Navigation Links | |
Exit Print View | |
Sun Server X2-4 (formerly Sun Fire X4470 M2) Installation Guide for Linux Operating Systems |
Part I Linux Software Installation on x86 Servers
1. Assisted OS Installation With Oracle Hardware Installation Assistant
Oracle Hardware Installation Assistant Task Overview
How to Obtain Oracle Hardware Installation Assistant
Oracle Hardware Installation Assistant Documentation Resources
Supported Linux Operating Systems
Linux Installation Prerequisites
Linux Installation Task Overview
Oracle Unbreakable Enterprise Kernel for Linux
Installing Oracle Linux 5 Using Local or Remote Media
Installing Oracle Linux 5 Using a PXE Network Environment
Oracle Linux Post Installation Tasks
Installing Oracle Unbreakable Enterprise Kernel for Linux Using Local or Remote Console
4. Installing SUSE Linux Enterprise Server
Installing SLES 11 SP1 Using Local or Remote Media
Install SLES 11 SP1 Using Local or Remote Media
Installing SLES 11 SP1 Using a PXE Network Environment
Install SLES 11 SP1 Using PXE Network Boot
5. Installing Red Hat Enterprise Linux
Installing RHEL 5.5 or 6.0 Using Local or Remote Media
Installing RHEL 5.5 or 6.0 Using a PXE Network Environment
Installing the Oracle Unbreakable Enterprise Kernel for Linux
6. Getting Server Firmware and Software
Firmware and Software Access Options
Available Software Release Packages
Accessing Firmware and Software
Part II Linux System Administrator References
A. Supported Installation Methods
B. Supported Operating Systems
C. BIOS Defaults for New Installations
After completing the SLES installation, review the following post installation tasks and, if necessary, perform the tasks that are applicable to your system.
The SLES OS installation media might not contain the most up-to-date versions of the operating system. The following procedure describes how to update the SLES OS on your server.
# you
Note that YaST can operate in both text and graphical modes. These directions apply to both.
Note - In order for the on-line update service to function correctly through a network HTTP or HTTPs proxy, the following additional configuration step must be performed.
run set-prefs proxy-url proxy_URL
Where proxy_URL is the fully qualified URL of your proxy server (for example: http://proxy.yourdomain:3128/).
Note - You will need your Novell Customer Center user name and password, as well as an SLES product activation code.
If you intend to use the Trusted Platform Module (TPM) feature set that is provided in SLES OS, you must configure the server to support this feature. For instructions, see the service manual for your server model:
Sun Server X2-4 Service Manual
Note - TPM enables you to administer the TPM security hardware in your server. For additional information about implementing this feature, refer to the TPM documentation available for SUSE Linux Enterprise Server OS.
