Skip Navigation Links
Exit Print View
Oracle Integrated Lights Out Manager (ILOM) 3.0
Supplement for Sun Server X2-4
search filter icon
search icon
Document Information
Using This Documentation
1.  Determining Your Server Management Strategy
Common Server Management Tasks
Server Management Software Benefits
Oracle Hardware Management Pack
Oracle Hardware Installation Assistant
Evaluating Your Server Environment
Which Operating System Do You Plan to Install?
From Which Platform Do You Want to Run the Software?
Do You Want to Update or Monitor Your System Components?
Do You Have a Modular System Environment?
Server Management Downloads and Documentation
2.  Oracle ILOM 3.0 Documentation
Oracle ILOM 3.0 Documentation Collection
Oracle ILOM 3.0 Server-Specific Documentation
3.  Oracle ILOM Platform Features for the Sun Server X2-4
Supported Sun Server X2-4 Firmware
Power Management Policies
Host Power Throttling and Recovery
Service Processor Power-On Policy
Low Line AC Override Policy
Oracle ILOM Sideband Management
Special Considerations for Sideband Management
Switch Serial Port Output Between SP and Host Console
Switch Serial Port Output Using the Web Interface
Switch Serial Port Output Using the CLI
Server Chassis Intrusion Sensor
How the /SYS/INTSW Sensor Works
Fault Management
Determining Faults
Clearing Faults
Components With No Fault Diagnosis
Viewing Sensors Using IPMItool
Sensors and Indicators Reference Information
System Components
System Indicators
Temperature Sensors
Power Supply Fault Sensors
Fan Speed and Physical Security Sensors
Power Supply Unit Current, Voltage, and Power Sensors
Entity Presence Sensors
SNMP and PET Message Reference Information
SNMP Traps
PET Event Messages
4.  Getting Server Firmware and Software
Firmware and Software Updates
Firmware and Software Access Options
Available Software Release Packages
Accessing Firmware and Software
Download Firmware and Software Using My Oracle Support
Requesting Physical Media
Gathering Information for the Physical Media Request
Request Physical Media (Online)
Request Physical Media (By Phone)
Installing Updates
Installing Firmware
Installing Hardware Drivers and OS Tools
This section covers instructions for downloading or requesting software release files. See:
  1. Navigate to the following web site:
  2. Select the Flash interface and sign in to My Oracle Support.
  3. At the top of the page, click the Patches and Updates tab.
    The Patches and Updates screen appears.
  4. In the Search screen, click Product or Family (Advanced).
    The screen appears with search fields.
  5. In the Product field, select the product from the drop-down list.
    Alternatively, type a full or partial product name (for example, Sun Server X2-4) until a match appears.
  6. In the Release field, select a software release from the drop-down list.
    Expand the folders to see all available software releases.
  7. Click Search.
    The software release comprises a set of downloads (patches).
    See Available Software Release Packages for a description of the available downloads.
  8. To select a patch, click the check box next to the patch name (you can select more than one patch).
    A pop-up action panel appears. The panel contains several action options.
  9. To download the update, click Download in the pop-up panel.
    The download begins automatically.
If your processes do not allow downloads from Oracle web sites, you can access the latest software release through a physical media request (PMR).
The following table describes the high-level tasks for making a physical media request and provides links for further information.
Gather information you will need to provide for the request.
Make the physical media request either online or by calling Oracle Support.
You must have a warranty or support contract for your server in order to make a physical media request (PMR).
Before you make the PMR, gather the following information:
Obtain product name, software release version, and patches required. It will be easier to make the request if you know the latest software release and the name of the download packages (patches) that you are requesting.
Before You Begin
Gather the information described in Gathering Information for the Physical Media Request before making the request.
  1. Go to the following web site:
  2. Select the Flash interface, then sign in to My Oracle Support.
  3. Click on the Contact Us link in the upper right corner of the page.
  4. In the Request Description section, fill in the following:
    1. In the Request Category drop-down menu, select the following:
      Software and OS Media Requests
    2. In the Request Summary field, type: PMR for latest software release for Sun Server X2-4.
  5. In the Request Details section, answer the questions shown in the following table:
    Your Answer
    Is this a physical software media shipment request?
    Which product line does the media request involve?
    Sun Products
    Are you requesting a required password for a patch download?
    Are you requesting a patch on CD/DVD?
    If requesting a patch on CD/DVD, please provide the patch number and OS/platform?
    Enter the patch number for each download that you want from the software release.
    List the product name and version requested for the physical media shipment?
    Product Name: Sun Server X2-4
    Version: Latest software release number
    What is the OS/platform for the requested media?
    If you are requesting OS-specific downloads, specify the OS here. If you are requesting system firmware only, enter Generic.
    Are any languages required for this shipment?
  6. Fill in the Ship-To contact, phone number, email address, company name, and shipping address information.
  7. Click Next.
  8. In the Upload Files, Relevant Files screen, click next.
    You do not need to supply any information.
  9. In the Related Knowledge screen, review Knowledge Articles applicable to your request.
  10. Click Submit.
Before You Begin
  1. Call Oracle support, using the appropriate number from the Oracle Global Customer Support Contacts Directory at:
  2. Tell Oracle support that you want to make a physical media request (PMR) for the Sun Server X2-4.
    • If you are able to access the specific software release and patch number information from My Oracle Support, provide this information to the support representative.
    • If you are unable to access the software release information, request the latest software release for the Sun Server X2-4.
