Skip Navigation Links
Exit Print View
Oracle Integrated Lights Out Manager (ILOM) 3.0
Supplement for Sun Server X2-4
search filter icon
search icon
Document Information
Using This Documentation
1.  Determining Your Server Management Strategy
Common Server Management Tasks
Server Management Software Benefits
Oracle Hardware Management Pack
Oracle Hardware Installation Assistant
Evaluating Your Server Environment
Which Operating System Do You Plan to Install?
From Which Platform Do You Want to Run the Software?
Do You Want to Update or Monitor Your System Components?
Do You Have a Modular System Environment?
Server Management Downloads and Documentation
2.  Oracle ILOM 3.0 Documentation
Oracle ILOM 3.0 Documentation Collection
Oracle ILOM 3.0 Server-Specific Documentation
3.  Oracle ILOM Platform Features for the Sun Server X2-4
Supported Sun Server X2-4 Firmware
Power Management Policies
Host Power Throttling and Recovery
Service Processor Power-On Policy
Low Line AC Override Policy
Configure SP Power Management Policies Using the Web Interface
Configure SP Power Management Policies Using the CLI
Oracle ILOM Sideband Management
Special Considerations for Sideband Management
Configure Sideband Management Using the Web Interface
Configure Sideband Management Using the CLI
Configure Sideband Management Using the Host BIOS Setup Utility
Switch Serial Port Output Between SP and Host Console
Switch Serial Port Output Using the Web Interface
Switch Serial Port Output Using the CLI
Server Chassis Intrusion Sensor
How the /SYS/INTSW Sensor Works
Fault Management
Determining Faults
Clearing Faults
Components With No Fault Diagnosis
Viewing Sensors Using IPMItool
Sensors and Indicators Reference Information
System Components
System Indicators
Temperature Sensors
Power Supply Fault Sensors
Fan Speed and Physical Security Sensors
Power Supply Unit Current, Voltage, and Power Sensors
Entity Presence Sensors
SNMP and PET Message Reference Information
SNMP Traps
PET Event Messages
4.  Getting Server Firmware and Software
Firmware and Software Updates
Firmware and Software Access Options
Available Software Release Packages
Accessing Firmware and Software
Download Firmware and Software Using My Oracle Support
Requesting Physical Media
Gathering Information for the Physical Media Request
Request Physical Media (By Phone)
Installing Updates
Installing Firmware
Installing Hardware Drivers and OS Tools
Index
Fault Management
When a server component fails, error telemetry is either captured via the BIOS or is monitored by the Oracle ILOM SP. Oracle ILOM consumes error telemetry from both sources and provides diagnosis in the form of a fault event. The fault event is stored in the Oracle ILOM event log as a fault message. You can use either the Oracle ILOM web interface or the command-line interface (CLI) to manually clear faults.
This section includes the following topics. The first four topics describe how to examine and clear faults, while the last topic provides reference information for sensors and indicators.
Determining Faults
When a system fault occurs, you can view system indicators and use the Oracle ILOM CLI or web interface to determine the fault:
Clearing Faults
The procedure for clearing a fault differs depending on the type of component.
  1. Customer-replaceable units (CRUs) that are hot-swappable and are monitored by the SP will have their faults cleared automatically when the failed component is replaced and the updated status is reported as deasserted.
  2. CRUs and field-replaceable units (FRUs) that have a FRUID container with identity information will have their faults cleared automatically when the failed component is replaced, as the SP is able to determine when a component is no longer present in the system.
  3. CRUs and FRUs that are not hot-swappable or lack a FRUID container with identity information will not have their faults cleared automatically.
You can use the Oracle ILOM web interface or the command-line interface (CLI) to manually clear faults. For information on how to use the Oracle ILOM web interface or the CLI to clear server faults, see the Oracle ILOM 3.0 Documentation Library at:
http://www.oracle.com/pls/topic/lookup?ctx=ilom30
The following types of faults are diagnosed by the Oracle ILOM SP:
Component Fault Events  lists the server component faults that are persistent after a system cold boot and the action to clear the fault.
Table 3-1 Component Fault Events
Component
Action to Clear the Fault
Motherboard
Fault is automatically cleared upon component replacement.
Memory riser
Fan board
DDR3 Memory DIMMs
CPU module
Clear fault manually after component replacement.
PCIe cards
Fan module
Fault is automatically cleared when the sensor status is OK.
Power supply
Disk drive
In addition to the above faults, the following fault does not require replacement of a faulty part; however, user action is needed to clear it:
fault.security.integrity-compromised@/sys/sp
This fault is generated when the server's top cover is removed while the AC power cords are still connected to the power supply, that is, power is not completely removed from the server. To clear this fault, replace the server's top cover and either reboot the server's SP or remove the AC power cords, and then reconnect the power cords.
Certain Sun Server X2-4 components do not provide a mechanism to diagnose faults. These include:
Sun Server X2-4 sensors can be viewed using IPMItool. For information and instructions for viewing sensors using IPMItool, see the Oracle Integrated Lights Out Manager (ILOM) 3.0 Protocol Management -- SNMP, IPMI, CIM, WS-MAN Guide.
