Skip Navigation Links | |
Exit Print View | |
Oracle Integrated Lights Out Manager (ILOM) 3.0 Supplement for Sun Server X2-4 |
1. Determining Your Server Management Strategy
Common Server Management Tasks
Server Management Software Benefits
Oracle Hardware Management Pack
Oracle Hardware Installation Assistant
Evaluating Your Server Environment
Which Operating System Do You Plan to Install?
From Which Platform Do You Want to Run the Software?
Do You Want to Update or Monitor Your System Components?
Do You Have a Modular System Environment?
Server Management Downloads and Documentation
2. Oracle ILOM 3.0 Documentation
Oracle ILOM 3.0 Documentation Collection
Oracle ILOM 3.0 Server-Specific Documentation
Supported Sun Server X2-4 Firmware
Host Power Throttling and Recovery
Service Processor Power-On Policy
Configure SP Power Management Policies Using the Web Interface
Configure SP Power Management Policies Using the CLI
Oracle ILOM Sideband Management
Special Considerations for Sideband Management
Configure Sideband Management Using the Web Interface
Configure Sideband Management Using the CLI
Configure Sideband Management Using the Host BIOS Setup Utility
Switch Serial Port Output Between SP and Host Console
Switch Serial Port Output Using the Web Interface
Switch Serial Port Output Using the CLI
Server Chassis Intrusion Sensor
How the /SYS/INTSW Sensor Works
Components With No Fault Diagnosis
Viewing Sensors Using IPMItool
Sensors and Indicators Reference Information
Fan Speed and Physical Security Sensors
Power Supply Unit Current, Voltage, and Power Sensors
SNMP and PET Message Reference Information
4. Getting Server Firmware and Software
Firmware and Software Access Options
Available Software Release Packages
Accessing Firmware and Software
Download Firmware and Software Using My Oracle Support
Gathering Information for the Physical Media Request
Request Physical Media (By Phone)
Oracle's Sun Server X2-4 supports the entire Oracle ILOM feature set provided in Oracle ILOM 3.0, with the exception of the Power Budget features. In addition, the server supports Oracle ILOM features that are specific to the Sun Server X2-4.
For detailed information about Oracle ILOM features that are common to all server platforms, see the Oracle Integrated Lights Out Manager (ILOM) 3.0 Documentation Collection, as described in Chapter 2, Oracle ILOM 3.0 Documentation.
Oracle ILOM features discussed in this chapter, which are specific to the Sun Server X2-4, are as follows:
