Skip Navigation Links
Exit Print View
Oracle Integrated Lights Out Manager (ILOM) 3.0
Supplement for Sun Server X2-4
search filter icon
search icon
Document Information
Using This Documentation
1.  Determining Your Server Management Strategy
Common Server Management Tasks
Server Management Software Benefits
Oracle Hardware Management Pack
Oracle Hardware Installation Assistant
Evaluating Your Server Environment
Which Operating System Do You Plan to Install?
From Which Platform Do You Want to Run the Software?
Do You Want to Update or Monitor Your System Components?
Do You Have a Modular System Environment?
Server Management Downloads and Documentation
2.  Oracle ILOM 3.0 Documentation
Oracle ILOM 3.0 Documentation Collection
Oracle ILOM 3.0 Server-Specific Documentation
3.  Oracle ILOM Platform Features for the Sun┬áServer X2-4
Supported Sun Server X2-4 Firmware
Power Management Policies
Host Power Throttling and Recovery
Service Processor Power-On Policy
Low Line AC Override Policy
Configure SP Power Management Policies Using the Web Interface
Configure SP Power Management Policies Using the CLI
Oracle ILOM Sideband Management
Special Considerations for Sideband Management
Configure Sideband Management Using the Web Interface
Configure Sideband Management Using the CLI
Configure Sideband Management Using the Host BIOS Setup Utility
Switch Serial Port Output Between SP and Host Console
Switch Serial Port Output Using the Web Interface
Switch Serial Port Output Using the CLI
Server Chassis Intrusion Sensor
How the /SYS/INTSW Sensor Works
Fault Management
Determining Faults
Clearing Faults
Components With No Fault Diagnosis
Viewing Sensors Using IPMItool
Sensors and Indicators Reference Information
System Components
System Indicators
Temperature Sensors
Power Supply Fault Sensors
Fan Speed and Physical Security Sensors
Power Supply Unit Current, Voltage, and Power Sensors
Entity Presence Sensors
SNMP and PET Message Reference Information
SNMP Traps
PET Event Messages
4.  Getting Server Firmware and Software
Firmware and Software Updates
Firmware and Software Access Options
Available Software Release Packages
Accessing Firmware and Software
Download Firmware and Software Using My Oracle Support
Requesting Physical Media
Gathering Information for the Physical Media Request
Request Physical Media (By Phone)
Installing Updates
Installing Firmware
Installing Hardware Drivers and OS Tools
Index
By default, you connect to the server's service processor (SP) using the out-of-band network management port (NET MGT). The Oracle ILOM sideband management feature enables you to select either the NET MGT port or one of the server's Gigabit Ethernet ports (NET 0, 1, 2, 3), which are in-band ports, to send and receive Oracle ILOM commands to and from the server SP. In-band ports are also called sideband ports.
The advantage of using a sideband management port to manage the server's SP is that one fewer cable connection and one fewer network switch port is needed. In configurations where numerous servers are being managed, such as data centers, sideband management can represent a significant savings in hardware and network utilization.
You can configure sideband management using either the web interface, the command-line interface (CLI), the BIOS, or IPMI. For special considerations and configuration instructions, see the following sections:
When sideband management is enabled in Oracle ILOM, the following conditions might occur:
  1. Log in to the Oracle ILOM web interface.
  2. Select Configuration --> Network.
    The Network Settings page is displayed.
    image:Screenshot of the Network Settings page.
  3. In the Network Settings page, do the following:
    1. Select DHCP to acquire the IP address automatically, or select Static to specify the appropriate IP address.
    2. To select a sideband management port, click the Management Port drop-down list and select the desired management port.
      The drop-down list enables you to change to any one of the four Gigabit Ethernet ports, /SYS/MB/NETn, where n is 0 to 3. The SP NET MGT port, /SYS/SP/NET0, is the default.
    3. Click Save for the changes to take effect.
  1. Log in to the Oracle ILOM CLI.
    Note - Using a serial connection for this procedure eliminates the possibility of losing connectivity during sideband management configuration changes.
  2. If you logged in using the serial port, you can assign a static IP address.
    For instructions, see the information about assigning an IP address in the Sun Server X2-4 Installation Guide.
  3. To show the current port settings, type:
    -> show /SP/network
    The network properties are displayed. For example:
    /SP/network
        Targets:
        Properties:
            commitpending = (Cannot show property)
            dhcp_server_ip = none
            ipaddress = xx.xx.xx.xx
            ipdiscovery = static
            ipgateway = xx.xx.xx.xx
            ipnetmask = xx.xx.xx.xx
            macaddress = 11.11.11.11.11.86
            managementport = /SYS/SP/NET0
     outofbandmacaddress = 11.11.11.11.11.86
            pendingipaddress = xx.xx.xx.xx
            pendingipdiscovery = static
            pendingipgateway =  xx.xx.xx.xx
            pendingipnetmask =  xx.xx.xx.xx
            pendingmanagementport = /SYS/SP/NET0
            sidebandmacaddress = 11.11.11.11.11.87
            state = enabled
    In the above output the current active macaddress is the same as the SP's outofbandmacaddress and the current active managementport is set to the default (/SYS/SP/NET0).
  4. To set the SP management port to a sideband port, type the following commands:
    -> set /SP/network pendingmanagementport=/SYS/MB/NETn
    Where n equals 0, 1, 2, or 3.
    -> set commitpending=true
  5. To view the change, type:
    -> show /SP/network
    The network properties appear and show that the change has taken effect. For example:
    /SP/network
        Targets:
        Properties:
     managementport = /SYS/MB/NETn
            pendingmanagementport = /SYS/MB/NETn
            state = enabled
    In the above output the macaddress matches the sidebandmacaddress, and the managementport matches the pendingmanagementport.
You can access the BIOS Setup Utility screens from the following interfaces:
To configure sideband management using the host BIOS Setup Utility, perform the following steps:
  1. Power on or power cycle the server.
  2. To enter the BIOS Setup Utility, press the F2 key while the system is performing the power-on self-test (POST).
    image:Graphic of the Press F2 to run Setup prompt.
    When BIOS is started, the main BIOS Setup Utility top-level screen appears. This screen provides seven menu options across the top of the screen.
    image:Graphic of BIOS Setup utility main screen.
  3. In the main screen, select Advanced --> IPMI 2.0 Configuration.
    The IPMI 2.0 Configuration screen appears.
    image:Graphic showing BIOS Setup utility: Advanced - IPMI configuration.
  4. In the IPMI 2.0 Configuration screen, select the Set LAN Configuration option.
    The LAN Configuration screen appears.
    image:Graphic showing BIOS Setup utility: Advanced - LAN Configuration.
  5. In the LAN Configuration screen, do the following:
    1. Use the left and right arrow keys to select the IP Assignment option and set it to DHCP to acquire the IP address automatically, or set it to Static to manually specify the IP address.
    2. Use the left and right arrow keys to select the Active Management Port option and set the port to a sideband management port (NET0, NET1, NET2, NET3).
      The NET MGT port is the default.
    3. Select Commit for the change to take effect.
