Skip Navigation Links
Exit Print View
Oracle Integrated Lights Out Manager (ILOM) 3.0
Supplement for Sun Server X2-4
search filter icon
search icon
Document Information
Using This Documentation
1.  Determining Your Server Management Strategy
Common Server Management Tasks
Server Management Software Benefits
Oracle Hardware Management Pack
Oracle Hardware Installation Assistant
Evaluating Your Server Environment
Which Operating System Do You Plan to Install?
From Which Platform Do You Want to Run the Software?
Do You Want to Update or Monitor Your System Components?
Do You Have a Modular System Environment?
Server Management Downloads and Documentation
2.  Oracle ILOM 3.0 Documentation
Oracle ILOM 3.0 Documentation Collection
Oracle ILOM 3.0 Server-Specific Documentation
3.  Oracle ILOM Platform Features for the Sun Server X2-4
Supported Sun Server X2-4 Firmware
Power Management Policies
Host Power Throttling and Recovery
Service Processor Power-On Policy
Low Line AC Override Policy
Configure SP Power Management Policies Using the Web Interface
Configure SP Power Management Policies Using the CLI
Oracle ILOM Sideband Management
Special Considerations for Sideband Management
Configure Sideband Management Using the Web Interface
Configure Sideband Management Using the CLI
Configure Sideband Management Using the Host BIOS Setup Utility
Switch Serial Port Output Between SP and Host Console
Switch Serial Port Output Using the Web Interface
Switch Serial Port Output Using the CLI
Server Chassis Intrusion Sensor
How the /SYS/INTSW Sensor Works
Fault Management
Determining Faults
Clearing Faults
Components With No Fault Diagnosis
Viewing Sensors Using IPMItool
Sensors and Indicators Reference Information
System Components
System Indicators
Temperature Sensors
Power Supply Fault Sensors
Fan Speed and Physical Security Sensors
Power Supply Unit Current, Voltage, and Power Sensors
Entity Presence Sensors
SNMP and PET Message Reference Information
SNMP Traps
PET Event Messages
4.  Getting Server Firmware and Software
Firmware and Software Updates
Firmware and Software Access Options
Available Software Release Packages
Accessing Firmware and Software
Download Firmware and Software Using My Oracle Support
Requesting Physical Media
Gathering Information for the Physical Media Request
Request Physical Media (By Phone)
Installing Updates
Installing Firmware
Installing Hardware Drivers and OS Tools
Index
This release of Oracle ILOM 3.0 software provides new Power Management policies that are supported on the Sun Server X2-4.
For more information about the latest Oracle ILOM 3.0 Power Management policies, see the Oracle Integrated Lights Out Manager (ILOM 3.0) Feature Updates and Release Notes.
This section includes the following topics:
The Sun Server X2-4 supports a simple mechanism to automatically apply hardware throttles to the CPUs and memory controllers when power exceeds the rated capacity of the available power supplies. This can occur when a redundant power supply has failed or has been removed from the system.
When the server's hardware (power CPLD) determines that power demand has exceeded the system's available power, it automatically throttles the host processor to reduce its power consumption. The service processor (SP) removes this hardware throttle after it has been applied for 5 seconds. Host power throttling and recovery continues until such action is no longer needed.
The service processor (SP) power-on policy determines the power state of the server when AC power is applied to the server.
Service processor power-on policies are mutually exclusive, meaning that if one policy is enabled, the other policy is disabled by default. If both policies are disabled, then the server SP will not apply main power to the server at boot time. A brief description of the SP power-on policies and default settings follows:
You can configure SP power-on policies using the Oracle ILOM web interface or the Oracle ILOM command-line interface (CLI). For instructions, see the following sections:
The Low Line AC Override policy setting is provided to enable special test scenarios of a 4-CPU system using low-line (110 volt) power. Low-line voltage is normally supported only in 2-CPU system configurations. The capacity of each power supply unit (PSU) is roughly 1000 watts at low line. Since the power of a 4-CPU system can exceed 1000 watts by a large amount, enabling this setting results in a loss of PSU redundancy. This setting is disabled by default on the Sun Server X2-4.
Note - The server is rated to have a maximum AC input current of 12 amps (with one or both PSUs working). When the Low Line AC Override policy is enabled, a 4‐CPU system can require more than 12 amps total current for both PSUs. In any case, each AC inlet will not exceed 12 amps.
You can configure the Low Line AC Override policy setting using the Oracle ILOM web interface or the Oracle ILOM command-line interface (CLI). For instructions, see the following sections:
  1. Log in to the Oracle ILOM web interface.
  2. Select Configuration --> Policy.
    The Policy Configuration page is displayed.
    image:Screenshot of the Policy Configuration page.
  3. Select the radio button next to the SP policy that you want to configure.
    The SP policy options include:
    • Auto power-on host on boot
    • Set host power to last power state on boot
    • Set Low Line AC Override Mode Policy
  4. Click the Actions drop-down menu and select Enable or Disable.
  5. Click OK to enable or disable the SP policy.
  1. Log in to the Oracle ILOM CLI.
  2. To show the current power policy settings, type:
    -> show /SP/policy
    The SP policy properties are displayed. For example:
     /SP/policy
        Targets:
        Properties:
        HOST_AUTO_POWER_ON = disabled
        HOST_LAST_POWER_STATE = disabled
        LOW_LINE_AC_OVERRIDE_MODE = disabled
        Commands:
        cd
        set
        show
    In the above output, Host Auto Power On is disabled, Host Last Power State is disabled, and Low Line AC Override Mode is disabled.
  3. Depending on the SP policy you want to configure, do the following:
    • To enable or disable Host Auto Power On, type:
      -> set /SP/policy/ HOST_AUTO_POWER_ON=[enabled|disabled]
    • To enable or disable Host Last Power State, type:
      -> set /SP/policy/ HOST_LAST_POWER_STATE=[enabled|disabled]
    • To enable or disable Low Line AC Override Mode, type:
      -> set /SP/policy/ LOW_LINE_AC_OVERRIDE_MODE=[enabled|disabled]
