Skip Navigation Links
Exit Print View
SPARC T4-1 Server HTML Document Collection
search filter icon
search icon
Document Information
Using This Documentation
Related Documentation
Support and Accessibility
Confirming Server and Site Specifications
Server Overview
Front Panel Components
Front Panel System LEDs and Buttons
Rear Panel Components
Rear Panel System LED and Button
Confirming Specifications
Preparing for Installation
Shipping Kit Inventory List
Handling Precautions
ESD Precautions
Tools Needed for Installation
Installing the Server
Rack Compatibility
Stabilize the Rack
Installing Slide Rails
Install the Server
(Optional) Installing the CMA
Verify Correct Operation of the Slide Rails and the CMA
Connecting Cables
Cabling Requirements
Identifying Ports
Connecting Data and Management Ports
Secure Cables in the CMA
Powering On the Server for the First Time
Oracle ILOM System Console
Connect a Terminal or Emulator to the SER MGT Port
Power On the Server for the First Time
Verify Functionality
Assigning a Static IP Address to the SP
Understanding System Administration Resources
Oracle ILOM Overview
Platform-Specific Oracle ILOM Features
Oracle Solaris OS Overview
OpenBoot Overview
Oracle VM Server for SPARC Overview
Multipathing Software
Hardware Management Pack Overview
Source for Downloading Hardware Management Pack Software
Hardware Management Pack Documentation
Accessing the Server
Log In to Oracle ILOM
Log In to the System Console
Display the ok Prompt
Display the Oracle ILOM -> Prompt
Use a Local Graphics Monitor
Oracle ILOM Remote Console
Controlling the Server
Power On the Server (Oracle ILOM)
Power Off the Server (Oracle ILOM)
Reset the Server (Oracle Solaris OS)
Reset the Server (Oracle ILOM)
Reset the SP to Default Values
Configuring Hardware RAID
Hardware RAID Support
Important Hardware RAID Guidelines
Prepare to Use the FCode Utility
FCode Utility Commands
Create a Hardware RAID Volume
Hot Spare Drives in RAID Volumes (LSI)
Determining If a Drive Has Failed
RAID Drive Replacement Strategies
Locate Device Paths
Changing Server Identification Information
Change Customer Data on FRU PROMs
Change System Identifier Information
Configuring Policy Settings
Specify Cooldown Mode
Restore the Host Power State at Restart
Specify the Host Power State at Restart
Disable or Re-Enable the Host Power-On Delay
Specify Parallel Boot of the SP and Host
Configure Host Behavior (Keyswitch State)
Configuring Network Addresses
SP Network Address Options
Disable or Re-Enable Network Access to the SP
Display the DHCP Server IP Address
Display the IP Address of the SP
Display the Host MAC Address
Using an In-band Connection to the SP
Configuring Boot Mode
Boot Mode Overview
Configure the Host Boot Mode (Oracle VM Server for SPARC)
Change the Host Boot Mode Behavior at Reset
Manage the Host Boot Mode Script
Display Host Boot Mode Expiration Date
Override OBP Settings to Reset the Server
Configuring Server Behavior at Restart
Specify Behavior When the Host Resets
Specify Behavior When the Host Stops Running
Set the Boot Timeout Interval
Specify Behavior at Boot Timeout
Specify Behavior if Restart Fails
Specify Maximum Restart Attempts
Configuring Devices
Unconfigure a Device Manually
Reconfigure a Device Manually
Monitoring the Server
Monitoring Faults
Enabling Automatic System Recovery
Display Server Components
Locate the Server
Updating the Firmware
Display the Firmware Version
Update the Firmware
Display OpenBoot Version
Display POST Version
Identifying WWN-Designated SAS2 Devices
World Wide Name Syntax
Mapping WWN Values to Hard Drives (OBP probe-scsi-all Command)
Identify a Disk Slot Using prtconf (Oracle Solaris OS)
WWN Syntax in an OS Installation on an Individual Drive
WWN Syntax in an OS Installation on a RAID Volume
Identifying Server Components
Front Components
Rear Components
Infrastructure Boards in the SPARC T4-1 Server
Internal System Cables
Illustrated Parts Breakdown
Understanding Hard Drive Data Cable Routing
Detecting and Managing Faults
Diagnostics Overview
Diagnostics Process
Interpreting Diagnostic LEDs
Memory Fault Handling Overview
Managing Faults (Oracle ILOM)
Understanding Fault Management Commands
Interpreting Log Files and System Messages
Checking if Oracle VTS Software Is Installed
Managing Faults (POST)
Managing Faults (PSH)
Managing Components (ASR)
Preparing for Service
Safety Information
Tools Needed for Service
Find the Chassis Serial Number
Locate the Server
Understanding Component Replacement Categories
FRU Reference
Hot Service, Replaceable by Customer
Cold Service, Replaceable by Customer
Cold Service, Replaceable by Authorized Service Personnel
Removing Power From the System
Power Off the Server (SP Command)
Power Off the Server (Power Button - Graceful)
Power Off the Server (Emergency Shutdown)
Disconnect Power Cords
Positioning the System for Service
Extend the Server
Release the CMA
Remove the Server From the Rack
Accessing Internal Components
Perform Electrostatic Discharge Prevention Measures
Remove the Top Cover
Servicing DIMMs
About DIMMs
Locate a Faulty DIMM (DIMM Fault Remind Button)
Locate a Faulty DIMM (show faulty Command)
Remove a DIMM
Install a DIMM
Increase System Memory With Additional DIMMs
Verify DIMM Functionality
DIMM Configuration Error Messages
Servicing Hard Drives
Hard Drive Hot-Pluggable Capabilities
Hard Drive Slot Configuration Reference
Hard Drive LEDs
Remove a Hard Drive
Install a Hard Drive
Verify the Functionality of a Hard Drive
Servicing the DVD/USB Assembly
DVD/USB Assembly Overview
Remove the DVD/USB Assembly
Install the DVD/USB Assembly
Servicing the Power Supplies
Power Supply Hot-Swap Capabilities
Power Supply LEDs
Locate a Faulty Power Supply
Remove a Power Supply
Install a Power Supply
Verify the Functionality of a Power Supply
Remove or Install a Power Supply Filler Panel
Servicing the Power Distribution Board
Power Distribution Board Overview
Remove the Power Distribution Board
Install the Power Distribution Board
Servicing the Power Supply Backplane
Power Supply Backplane Overview
Remove the Power Supply Backplane
Install the Power Supply Backplane
Servicing the Connector Board
Connector Board Overview
Remove the Connector Board
Install the Connector Board
Servicing PCIe and PCIe/XAUI Risers
Remove a PCIe or PCIe/XAUI Riser
Install a PCIe or PCIe/XAUI Riser
Servicing PCIe Cards
PCIe Card Configuration Reference
Remove a PCIe or XAUI Card
Install a PCIe or XAUI Card
Servicing SAS PCIe RAID HBA Cards
Remove a SAS PCIe RAID HBA Card
Install a SAS PCIe RAID HBA Card
Servicing the Service Processor
Service Processor Overview
Remove the Service Processor
Install the Service Processor
Servicing the System Battery
Replace the System Battery
Verify the System Battery
Servicing Fan Modules
Fan Configuration Reference
Fan Module LEDs
Locate a Faulty Fan Module
Remove a Fan Module
Install a Fan Module
Servicing the Fan Power Board
Fan Power Board Overview
Remove the Fan Power Board
Install the Fan Power Board
Servicing the System Configuration PROM
System Configuration PROM Overview
Remove the System Configuration PROM
Install the System Configuration PROM
Verify the System Configuration PROM
Servicing the HDD Cage
Hard Drive Cage Overview
Remove the Hard Drive Cage
Install the Hard Drive Cage
Servicing the HDD Backplane
Hard Drive Backplane Overview
Remove the Hard Drive Backplane
Install the Hard Drive Backplane
Servicing the Front Panel Light Pipe Assemblies
Front Panel Light Pipe Assemblies Overview
Remove the Front Panel Light Pipe Assembly (Right or Left)
Install the Front Panel Light Pipe Assembly (Right or Left)
Servicing the Motherboard Assembly
Motherboard Servicing Overview
Remove the Motherboard Assembly
Install the Motherboard Assembly
Replace the Top Cover
Reinstall the Server in the Rack
Return the Server to the Normal Rack Position
Reconnect the Power Cords
Power On the Server (start /SYS Command)
Power On the Server (Power Button)
The server components and assemblies that can be replaced in the field fall into three categories:
