Skip Navigation Links
Exit Print View
Sun Flash Accelerator F40 PCIe Card
User's Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Feedback
Access to Oracle Support
Sun Flash Accelerator F40 PCIe Card Overview
Card Overview
About the Sun Flash Accelerator F40 PCIe Card
Key Features
Card Hardware Components
Card Software and Firmware Components
Card LEDs
Card Specifications
Physical Dimensions
Environmental Specifications
Electrical Specifications
Preparing the Card for Installation
Required Tools
Ship Kit Contents
Observing Safety Precautions
General Safety Information
Safety Symbols
ESD Safety Measures
Perform ESD Prevention Measures
Update the Host Operating System
Installing the Card
Installation Overview
Installing the Card Into a Server
Card Optimization Guidelines
Install a New Card
Remove an Existing Card From a Server
Servicing the Card
Service Overview
Update the Card Software
Update the Card Firmware
Technical Support
Servicing the Card Using the ddcli Utility
Accessing the ddcli Utility
Verify Card Status
ddcli Utility Command Summary
List All Command
List Command
Update Flash Package Command
Health Reporting Command
Locate Card Command
Format Card Command
Show the Vital Product Data Command
Extract SMART Logs Command
Help Command
Troubleshooting Using Card LEDs
Error Messages
Exception Handling
Firmware Exception Error Messages
Reason Codes
Index
Install a New Card
Before You Begin
To install a new Sun Flash Accelerator F40 PCIe Card:
  1. Back up your data, as required, before changing your server configuration.
  2. Prepare the card for installation.
    See Preparing the Card for Installation.
    1. Gather the required tools.
      See Required Tools .
    2. Unpack the shipping kit that includes the card.
      See Ship Kit Contents.
    3. Remove the card from the antistatic bag using good good antistatic grounding procedures.
      See ESD Safety Measures.
    4. Carefully inspect the card for damage.
      If you notice any damage, contact Oracle support , or your reseller support representative. Go to: https://support.oracle.com.
  3. Prepare the server for service.
    Refer to your server's service manual.
    1. Remove the server from active operation.
    2. Turn off the server.
      Power down the system.
    3. Disconnect all power cords from the server power supplies.
      Refer to the server sservice manual.
    4. Remove the cover from the chassis.
    Electrical
    Caution - Hazardous voltages are present. Disconnect the server from the main power and from any networks before installing the card to avoid electrical shock.
  4. Identify a supported and available PCI Express slot in the server.
    Refer to the Sun Flash Accelerator F40 PCIe Card Product Notes.
    Note - Exceeding the maximum number of Sun Flash Accelerator F40 PCIe Cards or placing cards in unsupported slots results in host platform error report and shutdown.
  5. Insert the card in the PCI Express slot.
    1. Remove the blank bracket panel on the server chassis that aligns with the empty PCI Express slot.
      Save the bracket screw, if applicable.
    2. Align the card to the PCI Express slot.
    3. Press down gently, but firmly, to properly seat the card in the slot.
      The following figure shows how to insert the card in a PCI Express slot:
      Figure 3 Sun Flash Accelerator F40 PCIe Card Installation
      image:Figure showing how to install the half-height bracket card.
      Figure Legend
      1 Bracket screw
      2 Press here
      3 Press here
      4 32-bit slot (3.3 V only)
      5 PCI express x8 slot
      6 64-bit slot (3.3 V only)
      7 Motherboard
      Note - Your server chassis may contain a card riser or other configuration. Refer to the servers service manual for card installation instructions.
  6. Secure the card bracket to the server chassis.
    • Install the bracket screw, as required, to secure the card to the server chassis. or
    • Engage the server retention mechanism to secure the card to the server chassis.
  7. Return the server to service.
    1. Replace the cover.
    2. Reconnect the power cord and any network cables.
    3. Power on the system.
    The card hardware installation is complete.
  8. If applicable, perform any required commands for your system to recognize the new card.
    For the Oracle Solaris OS, reboot with the reconfiguration option. Refer to your server's administration guide.
  9. Verify successful installation of the card through your systems OS.
    Upon completed installation, the Sun Flash Accelerator F40 PCIe Card appears on your server. Refer to your server's administration guide.
  10. Configure the system to maximize flash technology.
Related Information
