Skip Navigation Links
Exit Print View
Sun Flash Accelerator F40 PCIe Card
User's Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Feedback
Access to Oracle Support
Sun Flash Accelerator F40 PCIe Card Overview
Card Overview
About the Sun Flash Accelerator F40 PCIe Card
Key Features
Card Hardware Components
Card Software and Firmware Components
Card LEDs
Card Specifications
Physical Dimensions
Environmental Specifications
Electrical Specifications
Preparing the Card for Installation
Required Tools
Ship Kit Contents
Observing Safety Precautions
General Safety Information
Safety Symbols
ESD Safety Measures
Perform ESD Prevention Measures
Update the Host Operating System
Installing the Card
Installation Overview
Installing the Card Into a Server
Card Optimization Guidelines
Install a New Card
Remove an Existing Card From a Server
Servicing the Card
Service Overview
Update the Card Software
Update the Card Firmware
Technical Support
Servicing the Card Using the ddcli Utility
Accessing the ddcli Utility
Verify Card Status
ddcli Utility Command Summary
List All Command
List Command
Update Flash Package Command
Health Reporting Command
Locate Card Command
Format Card Command
Show the Vital Product Data Command
Extract SMART Logs Command
Help Command
Troubleshooting Using Card LEDs
Error Messages
Exception Handling
Firmware Exception Error Messages
Reason Codes
Index
Block size can be configured through a server OS or file system, and is set to a default size with Oracle databases.
The Sun Flash Accelerator F40 PCIe Card is designed to provide best performance for data transfers that are multiples of 8k size, and using addresses that are 8k aligned. Partitions should be aligned to start on 8k boundaries.
Oracle Solaris OS automatically ensures 8k alignment when the default SMI label type is selected. If a label of type EFI is desired, care must be taken to specify and ensure 8k alignment: the default start sector of 34 for EFI labels is not an 8k aligned value. Use the partition subcommand of the Solaris format command to change the start sector to 48, or any other 8k aligned value. Note that there are 512B per sector.
The ZFS file system automatically aligns partitions to start on 8k boundaries when a full disk is allocated to ZFS (recommended). If you allocate individual EFI partitions to a ZFS pool, ensure the partition is 8k-aligned as discussed above.
For optimal performance of ZFS with the Sun Flash Accelerator F40 PCIe Card, refer to the ZFS Tuning Guide.
For highest performance, verify that the following hardware criteria are met:
The Sun Flash Accelerator F40 PCIe Card functions in x4 and x2 active width slots, but with reduced performance.
Related Information
