Troubleshooting Using Card LEDs
Use the Sun Flash Accelerator F40 PCIe Card LED indicators to determine
the status of the card. The Life, Status, and Activity LEDs, shown in
the following image, provide key status indicators to diagnose card issues.
The following table describes troubleshooting using the LED status indicators:
Life (1) |
Green |
On, steady: Card has
sufficient life remaining for programming and erasing the flash memory. No action required. |
Yellow |
On, steady:
Card has approximately 10%, or less, of life remaining for programming and erasing
the flash memory. Plan for replacements. |
Red |
On, steady: Card has 0% programming and erasing
cycles remaining. Backup data and copy data to a new card immediately. |
Status (2) |
Green |
On, steady: Normal. |
On, blinking: Locate A
user can locate a specific card in a rack of servers. Using
the -locate command causes this LED to blink. |
Yellow |
On, steady: Warning. A warning is caused
by the following:
Red |
On, blinking: Firmware fault code:
Run the ddcli utility to determine which component has an issue.
If no information appears, reboot the system and retry.
If no information appears, contact your Oracle support engineer.
On, steady: One of the following conditions applies:
One or more of the SSDs has failed.
At least one of the SSDs has reported critical temperature.
Backup power rail monitor failure detected.
Other component issues: Run the -list and -health commands in the ddcli utility to determine which component has an issue.
| Caution - If the critical
temperature warning persists, you can damage your card. Increase cooling or shut down your
system to prevent damage.
Activity (3) |
Green |
On, blinking: Indicates data activity on the card. No
action required. |
Related Information
