Skip Navigation Links
Exit Print View
Sun Flash Accelerator F40 PCIe Card
User's Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Feedback
Access to Oracle Support
Sun Flash Accelerator F40 PCIe Card Overview
Card Overview
About the Sun Flash Accelerator F40 PCIe Card
Key Features
Card Hardware Components
Card Software and Firmware Components
Card LEDs
Card Specifications
Physical Dimensions
Environmental Specifications
Electrical Specifications
Preparing the Card for Installation
Required Tools
Ship Kit Contents
Observing Safety Precautions
General Safety Information
Safety Symbols
ESD Safety Measures
Perform ESD Prevention Measures
Update the Host Operating System
Installing the Card
Installation Overview
Installing the Card Into a Server
Card Optimization Guidelines
Install a New Card
Remove an Existing Card From a Server
Servicing the Card
Service Overview
Update the Card Software
Update the Card Firmware
Technical Support
Servicing the Card Using the ddcli Utility
Accessing the ddcli Utility
Access Text Menu Interface in ddcli Utility
Access Command Line Interface (CLI) in ddcli Utility
Verify Card Status
ddcli Utility Command Summary
List All Command
List Command
Update Flash Package Command
Health Reporting Command
Locate Card Command
Format Card Command
Show the Vital Product Data Command
Extract SMART Logs Command
Help Command
Troubleshooting Using Card LEDs
Error Messages
Exception Handling
Firmware Exception Error Messages
Reason Codes
Index
Verify Card Status
To assess if the Sun Flash Accelerator F40 PCIe Card is ready to be used:
  1. Run the ddcli utility.
    See Access Text Menu Interface in ddcli Utility.
  2. List card information.
    • Select 1 in text interface. or:
    • Type ddcli -listall
    See List All Command
  3. Display card health.
    • Select 3 in text interface. or:
    • Type ddcli -health
    See Health Reporting Command
Related Information
