Go to main content
oracle home
SPARC T5-8 Server Product Notes
Exit Print View
Search Term
Search Scope:
This Document
Entire Library
Documentation Home
SPARC T5-8 Documentation Library
Updated: May 2016
Document Information
Using This Documentation
Product Documentation Library
Feedback
Late-Breaking Information
IMPORTANT - Install Latest OS Updates, Patches, and Firmware
Preinstalled Software
Minimum Supported Versions of the Firmware, OS, and Software
Mandatory Oracle Solaris 11 OS Package Updates
Mandatory Oracle Solaris 10 OS Patches
Oracle Solaris 10 1/13 Mandatory Patches
Oracle Solaris 10 8/11 Mandatory Patches
Oracle Solaris 10 9/10 Mandatory Patches
Obtain Patches
Installing and Booting Oracle Solaris 11 From Devices Connected to a USB Port
I/O Slot and Quantity Restrictions
Known Issues
Security Updates for System Firmware and Oracle Solaris OS
When You Create Logical Domains, Some Memory Is Reserved by the Server
sas2ircu Might Fail to Create a RAID Volume (15788910)
rKVMS Does Not Support Redirecting Storage From a SPARC Client (15795058)
Mouse Pointer Is Not Aligned With the Cursor in a Remote Window (15798251)
xhci Device Failed During Boot on USB Ports (15809582)
/System/Cooling Target Lists Power Supply Fans as Not Supported (15809846)
File Descriptor Leakage in libldom/ldom_xmpp_client.c (15811297)
ilomconfig Might Report Internal Error (15823485)
High-Speed PCIe I/O Cards Sometimes Downtrain to Gen1 I/O Speed (15825866)
PCIe Fabric Error Panic or eReport Occurs on Slots Populated With the StorageTek 8 Gb FC PCI-Express HBA (15894188)
Check the HBA (fcinfo Command)
Check the HBA (prtdiag Command)
Active mempm Should Balance Cage Assignment Across All Nodes (Bug ID15944881)
POST Does Not Work After a Reconfiguration Call From HC (15968276)
FPGA iPOST power-on-reset, error-reset, and hw-change Triggers Do Not Work (16192025)
Oracle ILOM Gets Confused When Multiple LDOM Configuration Files Exist With the Same Name (16239544)
ldm unbind of an SDIO or SRIOV Domain Hangs (16426940)
Oracle Solaris 10 OS Does Not Display Some Fault Information (16456603)
Management of SP Does Not Display a Table as Expected (16607793)
Set the Number of Displayed Rows to a Maximum of 999
Display the System Log With Page Breaks
Drive Controller Not Ready When the Driver Tries to Attach (16608475)
Disable Debug UARTS on LSI 2308 Controllers (16802420)
OPS Failing fault.ops.chassis.voltage.fail on FRU /SYS/MB at Component /SYS/MB (18070361)
POST Abort When Retiring Multiple Memeory Pages (18091447)
RAID 10 Volumes Created Instead of RAID 1e on an Even Number of Target Disks (18335578)
Europa-Based 10 GbE PCIe Cards Generate Device Training Errors (18647589)
Server Cannot Be Shipped in a Rack
Processor Module Bezel Labels Are Incorrect
Documentation Issues
Processor Module Label Shows Incorrect DIMM Configurations
Processor Module Label Shows Support for Filler Panels
Language:
English
May 2016
Provides late-breaking information about the SPARC T5-8 server from Oracle.
Feedback
Obtain Patches
Known Issues
