These topics detail the known issues at the time of this release.
When You Create Logical Domains, Some Memory Is Reserved by the Server
rKVMS Does Not Support Redirecting Storage From a SPARC Client (15795058)
Mouse Pointer Is Not Aligned With the Cursor in a Remote Window (15798251)
/System/Cooling Target Lists Power Supply Fans as Not Supported (15809846)
File Descriptor Leakage in libldom/ldom_xmpp_client.c (15811297)
High-Speed PCIe I/O Cards Sometimes Downtrain to Gen1 I/O Speed (15825866)
POST Does Not Work After a Reconfiguration Call From HC (15968276)
FPGA iPOST power-on-reset, error-reset, and hw-change Triggers Do Not Work (16192025)
Oracle ILOM Gets Confused When Multiple LDOM Configuration Files Exist With the Same Name (16239544)
Oracle Solaris 10 OS Does Not Display Some Fault Information (16456603)
Management of SP Does Not Display a Table as Expected (16607793)
Drive Controller Not Ready When the Driver Tries to Attach (16608475)
OPS Failing fault.ops.chassis.voltage.fail on FRU /SYS/MB at Component /SYS/MB (18070361)
RAID 10 Volumes Created Instead of RAID 1e on an Even Number of Target Disks (18335578)
Europa-Based 10 GbE PCIe Cards Generate Device Training Errors (18647589)
