- Install and configure the SAS devices, SATA II devices, or both in the system.
For more information, see the documentation for the devices.
- Connect the SFF-8643 x4 Mini SAS HD connector on one end of the SAS cable to an internal
port.
Use only Oracle-provided SAS cables (provided with your Oracle system at time of purchase).
The cables are also available for purchase at: https://shop.oracle.com/pls/ostore/f?p=dstore:2:0::NO:RIR,RP,2:PROD_HIER_ID:368705418248091865179976
- Connect the other end of the SFF-8643 x4 Mini SAS HD cable to the connector on the SAS drive
or SATA drive.
Note - You can connect one device per SAS PHY unless you use
an expander.
