Go to main content
Oracle® Storage 12 Gb/s SAS PCIe RAID HBA, Internal Installation Guide For HBA Models 7110116 and 7110117
Exit Print View
Updated: April 2020
Next Steps
If you are using the Oracle Solaris OS, the installation is complete. You can obtain the latest SRUs for the Oracle Solaris OS at: https://support.oracle.com
If you are using a supported operating system other than the Oracle Solaris OS, install the HBA driver for your operating system, as described in HBA Software Installation.
