Removing the HBA
If you need to remove the HBA from the system, follow the procedure in this section.
To Remove the HBA
Prepare your operating system for HBA removal.
Attach an antistatic wrist strap.
See Observing ESD and Handling Precautions.
Refer to the service manual for your specific system to remove the system
cover, power down the system, and remove AC power cords from the system, if
required.
Refer to the service manual for your specific system to locate the HBA in
the chassis of the system.
Disengage the retention clip that is securing the HBA to the chassis of
the system and pull up carefully to unseat the HBA from the PCIe
slot.
Detach all cables from the HBA.
Refer to the service manual for your specific system to reattach the
system cover, reinstall AC power cords to the system, and power on the
system, as necessary.
