Go to main content
Oracle® Storage 12 Gb/s SAS PCIe RAID HBA, Internal Installation Guide For HBA Models 7110116 and 7110117
Exit Print View
Updated: April 2020
Fault Tolerance
The following table lists the fault tolerance features for the HBA.
Table 5  Fault Tolerance Features
Specification
HBA Support
Support for SMART
Yes
Drive failure detection
Automatic
Drive rebuild using hot spares
Automatic
Parity generation and checking
Yes
Note -  The Self Monitoring Analysis and Reporting Technology (SMART) detects up to 70 percent of all predictable drive failures. In addition, SMART monitors the internal performance of all motors, heads, and drive electronics.
