Go to main content
Oracle® Storage 12 Gb/s SAS PCIe RAID HBA, Internal Installation Guide For HBA Models 7110116 and 7110117
Exit Print View
Updated: April 2020
Installing the RAID Configuration Utilities
The HBA can be configured for RAID levels 0, 1, 5, 6, 10, 50, and 60. The following RAID configuration utilities are available for the HBA:
  • MegaRAID Storage Manager Software – A graphical user interface from which you can create RAID volumes for the HBA.
    Note -  The MegaRAID Storage Manager software is not supported with the Oracle Solaris OS.
  • StorCLI Utility – A command-line utility from which you can create RAID volumes for the HBA.
These utilities, and their associated documentation, are available for download at the Oracle designated web site:
https://www.broadcom.com/support/oem/oracle/
