Go to main content
To Install the Windows Driver
Log in to the host.
In a browser, go to https://www.broadcom.com/support/oem/oracle/.
Select the type and then model of the HBA that you want to use (7110116,
7110117).
Select and download the specific Windows driver that is supported by the
Windows release on your hardware platform.
Select and download the corresponding Readme file for the Windows driver,
and follow the instructions in the Readme file to complete the driver
installation.
