The order in which you shut down domains is important and varies according to the type and number of domains. Shut down domains in this order:
1. I/O Domains (if present)
2. Middle domains (dedicated guest domains that are neither the primary (control) domain nor the end (service) domain
3. End (service) domain (domain named ssccnX-dom_highest_number)
4. Primary domain (described in Shut Down the Primary Domains)
If the PDomain is running with only one domain, shut down the system just as you would any other server by cleanly shutting down the OS (see Shut Down the Primary Domains).
To identify the number and types of domains on your system, perform Obtain Information Needed for Shutdown Tasks.
In this example, replace x with the number of the host.
-> start /HOSTx/console Are you sure you want to start /HOSTx/console [y/n] y Serial console started. To stop, type #.
sccn01 console login: root Password: Last login: Thur Feb 9 16:52:10 form /dev/console Oracle Corporation SunOS 511 11.2 Apr 2016
# ldm list NAME STATE FLAGS CONS VCPU MEMORY UTIL NORM UPTIME primary active -n-cv- UART 192 2095872M 0.1% 0.1% 12h 28m ssccn3-dom1 active -n---- 5001 192 2T 0.1% 0.1% 12h 25m ssccn3-dom2 active -n---- 5002 8 16G 0.1% 0.1% 2d 23h 34m ssccn3-dom3 active -n--v- 5003 16 32G 0.1% 0.1% 2d 23h 34m
# ldm stop domain_name LDom domain_name stopped
This example uses telnet and the CONS port number obtained in Obtain Information Needed for Shutdown Tasks.
# telnet 0 CONS_Port_NO Trying 0.0.0.0... Connecting to 0. Escape character is '^]' Connecting to console "ssccn3-dom1" in group "ssccn3-dom1" . . . . Press ~? for control options .. ssccn3-dom1 console login: root Password: Feb 14 04:34:52 ssccn3-dom1 login: ROOT LOGIN /dev/console Last login: Wed Feb 5 07:44:41 on console Oracle Corporation SunOS 5.10 Generic Patch January 2005 #
# init 0
# telnet 0 CONS_Port_NO Trying 0.0.0.0... Connecting to 0. Escape character is '^]' Connecting to console "ssccn3-dom1" in group "ssccn3-dom1" . . . . Press ~? for control options .. ssccn3-dom1 console login: root Password: Feb 14 04:34:52 ssccn3-dom1 login: ROOT LOGIN /dev/console Last login: Wed Feb 5 07:44:41 on console Oracle Corporation SunOS 5.10 Generic Patch January 2005 # init 0
