To configure the Oracle ILOM for base servers, complete the following steps on each compute server:
# show /SP/alertmgmt/rules
This lists the rules available, similar to the following:
1
2
3
15
# show /SP/alertmgmt/rules/rule-number
For example:
# show /SP/alertmgmt/rules/1
If you see output similar to the following:
Properties:
type = snmptrap
level = minor
destination = 10.60.10.243
destination_port = 0
community_or_username = public
snmp_version = 2c
testrule = (Cannot show property)
this rule is currently being used and should not be used for this exercise (the destination address shown would be the IP address of the ASR Manager in this case). If you see output similar to the preceding example, pick another rule and type the show /SP/alertmgmt/rules/rule-number command again, this time using another rule in the list.
Properties:
type = snmptrap
level = disable
destination = 0.0.0.0
snmp_version = 1
This rule is currently unused and can be used for this exercise.
# set /SP/alertmgmt/rules/unused-rule-number type=snmptrap level=minor destination=IP-address-of-ASR-Manager snmp_version=2c community_or_username=public
asr> activate_asset -i ILOM-IP-address
See Approve and Verify ASR Activation for SuperCluster systems Assets for those instructions.
For more information on the process, see ASR MOS 5.3+ Activation Process (Doc ID 1329200.1).
