Shutting Down SuperCluster Gracefully
To shut down but not power off SuperCluster, only perform the shut down procedures in
the order listed.
If you plan to power off SuperCluster, perform all the tasks in the order
listed.
Note -
Depending on the configuration of your SuperCluster, some of the procedures might
not apply to your situation.
1.
Prepare users and the system for a shutdown.
2.
Obtain system configuration information needed for shutdown
tasks.
3.
Shut down zones.
4.
Shut down guest domains.
5.
Shut down the primary domains.
6.
Shut down the storage servers.
7.
Power off the ZFS storage appliance.
8.
Power off the racks.
