Follow this procedure to register base servers with Oracle Solaris 11 or Database Domains to the ASR Manager.
# svcs asr-notify
If you see the following message:
svcs: Pattern ???asr-notify' doesn't match any instances
then confirm that the asr-notify service is installed:
# pkg list asr-notify
pkg list: no packages matching ???asr-modify' installed
then install the asr-notify service:
# pkg install system/fault-management/asr-notify
Enter the svcs asr-notify command again to confirm that the asr-notify service is working.
If you see the following message, the asr-notify service is installed and is working properly:
# svcs asr-notify STATE STIME FMRI online 16:06:05 svc:/system/fm/asr-notify:default
# asradm register -e http://asr-manager-host:port-number/asr
For example:
# asradm register -e http://asrmanager1.example.com:8777/asr
You should see screens asking for your Oracle Support account name and password. After entering your Oracle Support account name and password, you should see a notification, saying that your registration is complete:
Enter Orcle SSO User Name: Enter password: Registration complete.
# asradm list
The screen output should be similar to the following:
PROPERTY VALUE Status Successfully Registered with ASR manager System Id system-identification-number Asset Id asset-identification-number User username Endpoint URL http://asr-manager-host:port-number/asr
Upon successful results of the above commands, the registration of the ASR Manager is complete.
See Approve and Verify ASR Activation for SuperCluster systems Assets for those instructions.
For more information on the process, see ASR MOS 5.3+ Activation Process (Doc ID 1329200.1).
