System Administration Guide: Network Services
Part IV Mail Services Topics
This section provides overview, task, and reference information for the mail service.
Chapter 12 Mail Services (Overview)
Setting up and maintaining an electronic mail service involves complex tasks that are critical to the daily operation of your network. As a network administrator, you might need to expand an existing mail service. Alternately, you might need to set up a mail service on a new network or a subnet. The chapters on mail services can help you plan and set up a mail service for your network. This chapter provides links to descriptions of new features in sendmail, as well as a list of other sources of information. The chapter also provides overviews of the software and hardware components that are required to establish a mail service.
See Chapter 13, Mail Services (Tasks) for procedural information about how to set up and administer mail services. For details, refer to Task Map for Mail Services.
See Chapter 14, Mail Services (Reference) for a more detailed description of the components of mail services. This chapter also describes the mail service programs and files, the mail routing process, the interactions of sendmail with name services, and the features in version 8.13 of sendmail. See Changes in Version 8.13 of sendmail.
What's New With Mail Services
This section provides information about new features in various Solaris releases.
Changes in this Release
The following changes have been made in the Solaris 10 7/10 release release:
Changes in the Solaris 10 1/06 Release
Starting in the Solaris 10 1/06 release, sendmail supports SMTP using Transport Layer Security (TLS). For more information, see the following:
For a complete list of features in the Solaris 10 1/06 release, see Oracle Solaris 10 9/10 What’s New.
Changes in the Solaris 10 Release
Starting in the Solaris 10 release, sendmail version 8.13 is the default. For information about version 8.13 and other changes, see the following:
Additionally, the mail service is managed by the Service Management Facility. Administrative actions on this service, such as enabling, disabling, or restarting, can be performed by using the svcadm command. The service's status can be queried by using the svcs command. For more information about the Service Management Facility, see the smf(5) man page and Chapter 18, Managing Services (Overview), in System Administration Guide: Basic Administration.
Other sendmail Information Sources
The following is a list of additional information sources about sendmail.
Introduction to the Components of Mail Services
Many software and hardware components are required to establish a mail service. The following sections give a quick introduction to these components. These sections also provide some of the terms that are used to describe the components.
The first section, Overview of the Software Components, defines the terms that are used when discussing the software parts of the mail delivery system. The next section, Overview of the Hardware Components, focuses on the functions of the hardware systems in a mail configuration.
The following table introduces some of the software components of a mail system. Refer to Software Components for a complete description of all of the software components.
Component
Description
.forward files
Files that you can set up in a user's home directory to redirect mail or to send mail to a program automatically
mailbox
A file on a mail server that is the final destination for email messages
mail addresses
Address that contains the name of the recipient and the system to which a mail message is delivered
mail aliases
An alternate name that is used in a mail address
mail queue
A collection of mail messages that needs to be processed by the mail server
postmaster
A special mail alias that is used to report problems and to ask questions about the mail service
sendmail configuration file
A file that contains all the information necessary for mail routing
A mail configuration requires three elements, which you can combine on the same system or provide in separate systems.
If users are to communicate with networks outside your domain, you must also add a fourth element, a mail gateway.
Figure 12–1 shows a typical electronic mail configuration, using the three basic mail elements plus a mail gateway.
Figure 12–1 Typical Electronic Mail Configuration
Diagram shows the dependencies between a mail gateway,
a mail host, mail servers, mailboxes, clients.
Each element is described in detail in Hardware Components.
Chapter 13 Mail Services (Tasks)
This chapter describes how to set up and administer mail services. If you are not familiar with administering mail services, read Chapter 12, Mail Services (Overview) for an introduction to the components of mail services. This chapter also provides a description of a typical mail service configuration, as shown in Figure 12–1. The following list can help you find groups of related procedures that are covered in this chapter.
See Chapter 14, Mail Services (Reference) for a more detailed description of the components of mail services. This chapter also describes the mail service programs and files, the mail routing process, the interactions of sendmail with name services, and the features in version 8.13 of sendmail that are not fully described in the sendmail(1M) man page.
The following table refers you to other task maps that focus on a specific group of procedures.
Task
Description
For Instructions
Setting up mail services
Use these procedures to set up each component of your mail service. Learn how to set up a mail server, a mail client, a mail host, and a mail gateway. Learn how to use DNS with sendmail.
Setting Up Mail Services (Task Map)
Altering the sendmail configuration
Use these procedures to modify your configuration files or service properties.
Changing the sendmail Configuration (Task Map)
Administering mail alias files
Use these procedures to provide aliasing on your network. Learn how to manage entries in NIS+ tables. Also, learn how to set up an NIS map, a local mail alias, a keyed map file, and a postmaster alias.
Administering Mail Alias Files (Task Map)
Administering the mail queue
Use these procedures to provide smooth queue processing. Learn how to display and move the mail queue, force mail queue processing, and run a subset of the mail queue. Also, learn how to run the old mail queue.
Administering the Queue Directories (Task Map)
Administering .forward files
Use these procedures to disable .forward files or change the search path of the .forward file. Also, learn how to permit users to use the .forward file by creating and populating /etc/shells.
Administering .forward Files (Task Map)
Troubleshooting procedures and tips for mail services
Use these procedures and tips to resolve problems with your mail service. Learn how to test the mail configuration, check mail aliases, test the sendmail rule sets, verify connections to other systems, and log messages. Also, learn where to look for other mail diagnostic information.
Troubleshooting Procedures and Tips for Mail Services (Task Map)
Resolving error messages
Use the information in this section to resolve some mail-related error messages.
Resolving Error Messages
Planning Your Mail System
The following list describes some concerns that should be part of your planning process.
After you have completed the planning process, set up the systems on your site to perform the functions that are described in Setting Up Mail Services (Task Map). For other task information, refer to Task Map for Mail Services.
Local Mail Only
The simplest mail configuration, as shown in Figure 13–1, is two or more workstations that are connected to one mail host. Mail is completely local. All the clients store mail on their local disks, and the clients act as mail servers. Mail addresses are parsed by using the /etc/mail/aliases files.
Figure 13–1 Local Mail Configuration
Diagram shows the dependencies of a mail host to mail
clients.
To set up this kind of mail configuration, you need the following.
For task information about setting up your mail service, refer to Setting Up Mail Services. If you are looking for a particular procedure that is related to setting up your mail service, refer to Setting Up Mail Services (Task Map).
Local Mail and a Remote Connection
The most common mail configuration in a small network is shown in Figure 13–2. One system includes the mail server, the mail host, and the mail gateway that provides the remote connection. Mail is distributed by using the /etc/mail/aliases files on the mail gateway. No name service is required.
Figure 13–2 Local Mail Configuration With a UUCP Connection
Diagram shows the dependencies of mail clients to a mail
gateway.
In this configuration, you can assume that the mail clients mount their mail files from /var/mail on the mail host. To set up this kind of mail configuration, you need the following.
The following table describes the procedures for setting up mail services.
Task
Description
For Instructions
Setting up a mail server
Steps to enable a server to route mail
How to Set Up a Mail Server
Setting up a mail client
Steps to enable a user to receive mail
How to Set Up a Mail Client
Setting up a mail host
Steps to establish a mail host that can resolve email addresses
How to Set Up a Mail Host
Setting up a mail gateway
Steps to manage communication with networks outside your domain
How to Set Up a Mail Gateway
Using DNS with sendmail
Steps to enable DNS host lookups
How to Use DNS With sendmail
You can readily set up a mail service if your site does not provide connections to email services outside your company or if your company is in a single domain.
Mail requires two types of configurations for local mail. Refer to Figure 13–1 in Local Mail Only for a representation of these configurations. Mail requires two more configurations for communication with networks outside your domain. Refer to Figure 12–1 in Overview of the Hardware Components or Figure 13–2 in Local Mail and a Remote Connection for a representation of these configurations. You can combine these configurations on the same system or provide these configurations on separate systems. For example, if your mail host and mail server functions are on the same system, follow the directions in this section for setting up that system as a mail host. Then, follow the directions in this section for setting up the same system as a mail server.
Note –
The following procedures for setting up a mail server and mail client apply when mailboxes are NFS mounted. However, mailboxes typically are maintained in locally mounted /var/mail directories, which eliminates the need for the following procedures.
ProcedureHow to Set Up a Mail Server
No special steps are required to set up a mail server that is only serving mail for local users. The user must have an entry in the password file or in the namespace. Also, for mail to be delivered, the user should have a local home directory for checking the ~/.forward file. For this reason, home directory servers are often set up as the mail server. Hardware Components in Chapter 14, Mail Services (Reference) provides more information about the mail server.
The mail server can route mail for many mail clients. This type of mail server must have adequate spooling space for client mailboxes.
Note –
The mail.local program automatically creates mailboxes in the /var/mail directory the first time a message is delivered. You do not need to create individual mailboxes for your mail clients.
For clients to access their mailboxes, the /var/mail directory should be available for remote mounting. Alternately, a service such as Post Office Protocol (POP) or Internet Message Access Protocol (IMAP) should be available from the server. The following task shows you how to set up a mail server by using the /var/mail directory. To provide configuration guidelines for POP or IMAP is beyond the scope of this document.
For the following task, ensure that the /etc/dfs/dfstab file shows that the /var/mail directory is exported.
  1. Become superuser or assume an equivalent role.
    Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
  2. Stop sendmail.
    # svcadm disable -t network/smtp:sendmail
  3. Check if the /var/mail directory is available for remote access.
    # share
    If the /var/mail directory is listed, proceed to step 5.
    If the /var/mail directory is not listed or if no list appears, continue with the appropriate substep.
    1. (Optional) If no list appears, start NFS services.
      Follow the procedure, How to Set Up Automatic File-System Sharing, to use the /var/mail directory to start NFS services.
    2. (Optional) If the /var/mail directory is not included in the list, add the directory to /etc/dfs/dfstab.
      Add the following command line to the /etc/dfs/dfstab file.
      share -F nfs -o rw /var/mail
  4. Make the file system available for mounting.
    # shareall
  5. Ensure that your name service has been started.
    1. (Optional) If you are running NIS, use this command.
      # ypwhich
      For more information, refer to the ypwhich(1) man page.
    2. (Optional) If you are running NIS+, use this command.
      # nisls
      For more information, refer to the nisls(1) man page.
    3. (Optional) If you are running DNS, use this command.
      # nslookup hostname
      hostname
      Use your host name.
      For more information, refer to the nslookup(1M) man page.
    4. (Optional) If you are running LDAP, use this command.
      # ldaplist
      For more information, refer to the ldaplist(1) man page.
  6. Restart sendmail.
    # svcadm enable network/smtp:sendmail
ProcedureHow to Set Up a Mail Client
A mail client is a user of mail services with a mailbox on a mail server. Additionally, the mail client has a mail alias in the /etc/mail/aliases file that points to the location of the mailbox.
Note –
You can also perform the task of setting up a mail client by using a service such as Post Office Protocol (POP) or Internet Message Access Protocol (IMAP). However, to provide configuration guidelines for POP or IMAP is beyond the scope of this document.
  1. Become superuser on the mail client's system or assume an equivalent role.
  2. Stop sendmail.
  3. Ensure that a /var/mail mount point exists on the mail client's system.
    The mount point should have been created during the installation process. You can use ls to ensure that the file system exists. The following example shows the response that you receive if the file system has not been created.
    # ls -l /var/mail
    /var/mail not found
  4. Ensure that no files are in the /var/mail directory.
    If mail files do exist in this directory, you should move them so that they are not covered when the /var/mail directory is mounted from the server.
  5. Mount the /var/mail directory from the mail server.
    You can mount the mail directory automatically or at boot time.
    1. (Optional) Mount /var/mail automatically.
      Add an entry such as the following to the /etc/auto_direct file.
      /var/mail -rw,hard,actimeo=0 server:/var/mail
      server
      Use the assigned server name.
    2. (Optional) Mount /var/mail at boot time.
      Add the following entry to the /etc/vfstab file. This entry permits the /var/mail directory on the mail server that is specified to mount the local /var/mail directory.
      server:/var/mail - /var/mail nfs - no rw,hard,actimeo=0
      The client's mailbox is automatically mounted whenever the system is rebooted. If you are not rebooting the system, type the following command to mount the client mailbox.
      # mountall
      Caution – Caution –
      For mailbox locking and mailbox access to work properly, you must include the actimeo=0 option when mounting mail from an NFS server.
  6. Update /etc/hosts.
    Edit the /etc/hosts file and add an entry for the mail server. This step is not required if you are using a name service.
    # cat /etc/hosts
    # Internet host table
    IP-address     mailhost  mailhost  mailhost.example.com
    IP-address
    Use the assigned IP addresses.
    example.com
    Use the assigned domain.
    mailhost
    Use the assigned mailhost.
    For more information, refer to the hosts(4) man page.
  7. Add an entry for the client to one of the alias files.
    Refer to Administering Mail Alias Files (Task Map) for a task map about administering mail alias files. Note that the mail.local program automatically creates mailboxes in the /var/mail directory the first time a message is delivered. You do not need to create individual mailboxes for your mail clients.
  8. Restart sendmail.
ProcedureHow to Set Up a Mail Host
A mail host resolves email addresses and reroutes mail within your domain. A good candidate for a mail host is a system that provides your network with a remote connection or connects your network to a parent domain. The following procedure shows you how to set up a mail host.
  1. Become superuser on the mail host system or assume an equivalent role.
  2. Stop sendmail.
  3. Verify the host-name configuration.
    Run the check-hostname script to verify that sendmail can identify the fully qualified host name for this server.
    % /usr/sbin/check-hostname
    hostname phoenix OK: fully qualified as phoenix.example.com
    If this script is not successful in identifying the fully qualified host name, you need to add the fully qualified host name as the first alias for the host in /etc/hosts.
  4. Update the /etc/hosts file.
    Choose the step that is appropriate for you.
    1. (Optional) If you are using NIS or NIS+, edit the /etc/hosts file on the system that is to be the new mail host.
      Add the word mailhost and mailhost.domain after the IP address and system name of the mail host system.
      IP-address mailhost mailhost mailhost.domain loghost
      IP-address
      Use the assigned IP address.
      mailhost
      Use the system name of the mail host system.
      domain
      Use the expanded domain name.
      The system is now designated as a mail host. The domain should be identical to the string that is given as the subdomain name in the output of the following command.
      % /usr/lib/sendmail -bt -d0 </dev/null
      Version 8.13.1+Sun
       Compiled with: LDAPMAP MAP_REGEX LOG MATCHGECOS MIME7TO8 MIME8TO7
                      NAMED_BIND NDBM NETINET NETINET6 NETUNIX NEWDB NIS
                      NISPLUS QUEUE SCANF SMTP USERDB XDEBUG
      ============ SYSTEM IDENTITY (after readcf) ============
            (short domain name) $w = phoenix
        (canonical domain name) $j = phoenix.example.com
               (subdomain name) $m = example.com
                    (node name) $k = phoenix
      See the following example of how the hosts file should look after these changes.
      # cat /etc/hosts
      172.31.255.255   localhost
      192.168.255.255  phoenix mailhost mailhost.example.com loghost
    2. (Optional) If you are not using NIS or NIS+, edit the /etc/hosts file on each system in the network.
      Create the following entry.
  5. Restart sendmail.
  6. Test your mail configuration.
    See How to Test the Mail Configuration for instructions.
    Note –
    For further information about mail hosts, refer to Hardware Components in Chapter 14, Mail Services (Reference).
ProcedureHow to Set Up a Mail Gateway
A mail gateway manages communication with networks outside your domain. The mailer on the sending mail gateway can match the mailer on the receiving system.
A good candidate for a mail gateway is a system that is attached to Ethernet and phone lines. Another good candidate is a system that is configured as a router to the Internet. You can configure the mail host or another system as the mail gateway. You might choose to configure more than one mail gateway for your domain. If you have UNIX-to-UNIX Copy Program (UUCP) connections, you should configure the system (or systems) with UUCP connections as the mail gateway.
  1. Become superuser on the mail gateway or assume an equivalent role.
  2. Stop sendmail.
    # /usr/sbin/check-hostname
    If this script is not successful in identifying the fully qualified host name, you need to add the fully qualified host name as the first alias for the host in /etc/hosts. If you need help with this step, refer to Step 4 of How to Set Up a Mail Host.
  4. Ensure that your name service has been started.
      # ypwhich
      # nisls
      # nslookup hostname
      hostname
      Use your host name.
      # ldaplist
    Note –
    For more information about the mail gateway, refer to Hardware Components in Chapter 14, Mail Services (Reference).
ProcedureHow to Use DNS With sendmail
The DNS name service does not support aliases for individuals. This name service does support aliases for hosts or domains that use Mail Exchanger (MX) records and CNAME records. You can specify host names, domain names, or both names in the DNS database. For more information about sendmail and DNS, see Interactions of sendmail With Name Services in Chapter 14, Mail Services (Reference), or see the System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP).
  2. Enable DNS host lookups (NIS+ only).
    Edit the /etc/nsswitch.conf file and remove the # from the hosts definition that includes the dns flag. The host entry must include the dns flag, as the following example shows, in order for the DNS host aliases to be used.
    # grep hosts /etc/nsswitch.conf
    #hosts:     nisplus [NOTFOUND=return] files
    hosts:      dns nisplus [NOTFOUND=return] files
  3. Check for a mailhost and mailhost.domain entry.
    Use nslookup to ensure that an entry exists for mailhost and mailhost.domain in the DNS database. For more information, refer to the nslookup(1M) man page.
Task
Description
For Instructions
Building a sendmail configuration file
Use this procedure to modify your sendmail.cf file. An example of how to enable domain masquerading is included.
How to Build a New sendmail.cf File
Setting up a virtual host
Steps to configure sendmail so that mail is accepted for more than one domain.
Setting Up a Virtual Host
Setting up automatic rebuilding of the sendmail configuration file
Use this procedure to modify the sendmail service so that the sendmail.cf and submit.mc configuration files are automatically rebuilt after an upgrade.
How to Automatically Rebuild a Configuration File
Running sendmail in the open mode.
Use this procedure to modify the sendmail service properties to enable the open mode.
How to Use sendmail in the Open Mode
Setting SMTP to use Transport Layer Security (TLS)
Use this procedure to enable SMTP to have secure connections with TLS.
How to Set SMTP to Use TLS
Managing mail delivery with an alternate configuration
Use this procedure to prevent mail delivery problems that can occur if the master daemon is disabled.
How to Manage Mail Delivery by Using an Alternate Configuration of sendmail.cf
How to Build a New sendmail.cf File shows you how to build the configuration file. Although you can still use older versions of sendmail.cf files, the best practice is to use the new format.
For more details, refer to the following.
ProcedureHow to Build a New sendmail.cf File
The following procedure shows you how to build a new configuration file.
Note –
/usr/lib/mail/cf/main-v7sun.mc is now /etc/mail/cf/cf/sendmail.mc.
  2. Stop sendmail.
  3. Make a copy of the configuration files that you are changing.
    # cd /etc/mail/cf/cf
    # cp sendmail.mc myhost.mc
    myhost
    Select a new name for your .mc file.
  4. Edit the new configuration files (for example, myhost.mc), as necessary.
    For example, add the following command line to enable domain masquerading.
    # cat myhost.mc
    MASQUERADE_AS(`host.domain')
    host.domain
    Use the desired host name and domain name.
    In this example, MASQUERADE_AS causes sent mail to be labeled as originating from host.domain, rather than $j.
  5. Build the configuration file by using m4.
    # /usr/ccs/bin/make myhost.cf
  6. Test the new configuration file by using the -C option to specify the new file.
    # /usr/lib/sendmail -C myhost.cf -v testaddr </dev/null
    While this command displays messages, it sends a message to testaddr. Only outgoing mail can be tested without restarting the sendmail service on the system. For systems that are not handling mail yet, use the full testing procedure in How to Test the Mail Configuration.
  7. Install the new configuration file after making a copy of the original.
    # cp /etc/mail/sendmail.cf /etc/mail/sendmail.cf.save
    # cp myhost.cf /etc/mail/sendmail.cf
  8. Restart the sendmail service.
If you need to assign more than one IP address to a host, see this Web site: http://www.sendmail.org/tips/virtualHosting. This site provides complete instructions about how to use sendmail to set up a virtual host. However, in the “Sendmail Configuration” section, do not perform step 3b, as shown in the following.
# cd sendmail-VERSION/cf/cf
# ./Build mailserver.cf
# cp mailserver.cf /etc/mail/sendmail.cf
Instead, for the Solaris operating system, perform the following steps.
# /usr/ccs/bin/make mailserver.cf
mailserver
Use the name of the .cf file.
Changing the sendmail Configuration outlines the same three steps as part of the build process.
After you have generated your /etc/mail/sendmail.cf file, you can continue with the next steps to create a virtual user table.
ProcedureHow to Automatically Rebuild a Configuration File
If you have built your own copy of sendmail.cf or submit.cf, the configuration file is not replaced during the upgrade process. The following procedure shows how to configure the sendmail service properties so that the sendmail.cf file is automatically rebuilt for you. For instructions on how to automatically build the submit.cf configuration file, see Example 13–1. You may combine these procedures if you need to build both files.
  2. Set the sendmail properties.
    # svccfg -s sendmail
    svc:/network/smtp:sendmail> setprop config/path_to_sendmail_mc=/etc/mail/cf/cf/myhost.mc
    svc:/network/smtp:sendmail> quit
  3. Refresh and restart the sendmail service.
    The first command pushes the changes into the running snapshot. The second command restarts the sendmail service using the new options.
    # svcadm refresh svc:/network/smtp:sendmail
    # svcadm restart svc:/network/smtp:sendmail
Example 13–1 Establishing Automatic Rebuilding of submit.cf
This procedure configures the sendmail service, such that the submit.mc configuration file is rebuilt automatically.
# svccfg -s sendmail-client:default
svc:/network/smtp:sendmail> setprop config/path_to_submit_mc=/etc/mail/cf/cf/submit-myhost.mc
svc:/network/smtp:sendmail> exit
# svcadm refresh svc:/network/sendmail-client
# svcadm restart svc:/network/sendmail-client
ProcedureHow to Use sendmail in the Open Mode
In the Solaris 10 release, the sendmail service was changed so that it would run in local–only mode by default. The local-only mode means that only mail from the local host is accepted. Messages from any other systems are rejected. Earlier Solaris releases were configured to accept incoming mail from all remote systems, which is known as the open mode. To use the open mode, use the following procedure.
Caution – Caution –
Running sendmail in the local–only mode is much more secure than running in the open mode. Make sure that you are aware of the potential security risks if you follow this procedure.
    svc:/network/smtp:sendmail> setprop config/local_only = false
ProcedureHow to Set SMTP to Use TLS
Starting in the Solaris 10 1/06 release, SMTP can use Transport Layer Security (TLS) in version 8.13 of sendmail. This service to SMTP servers and clients provides private, authenticated communications over the Internet, as well as protection from eavesdroppers and attackers. Note that this service is not enabled by default.
The following procedure uses sample data to show you how to set up the certificates that enable sendmail to use TLS. For more information, see Support for Running SMTP With TLS in Version 8.13 of sendmail.
  2. Stop sendmail.
  3. Set up the certificates that enable sendmail to use TLS.
    1. Complete the following:
      # cd /etc/mail
      # mkdir -p certs/CA
      # cd certs/CA
      # mkdir certs crl newcerts private
      # echo "01" > serial
      # cp /dev/null index.txt
      # cp /etc/sfw/openssl/openssl.cnf .
    2. Use your preferred text editor to change the dir value in the openssl.cnf file from /etc/sfw/openssl to /etc/mail/certs/CA.
    3. Use the openssl command-line tool to implement TLS.
      Note that the following command line generates interactive text.
      # openssl req -new -x509 -keyout private/cakey.pem -out cacert.pem -days 365 \
      -config openssl.cnf
      Generating a 1024 bit RSA private key
      writing new private key to 'private/cakey.pem'
      Enter PEM pass phrase:
      Verifying - Enter PEM pass phrase:
      You are about to be asked to enter information that will be incorporated
      into your certificate request.
      What you are about to enter is what is called a Distinguished Name or a DN.
      There are quite a few fields but you can leave some blank
      For some fields there will be a default value,
      If you enter '.', the field will be left blank.
      Country Name (2 letter code) []:US
      State or Province Name (full name) []:California
      Locality Name (eg, city) []:Menlo Park
      Organization Name (eg, company) [Unconfigured OpenSSL Installation]:Sun Microsystems
      Organizational Unit Name (eg, section) []:Solaris
      Common Name (eg, YOUR name) []:somehost.somedomain.example.com
      Email Address []:someuser@example.com
      req
      This command creates and processes certificate requests.
      -new
      This req option generates a new certificate request.
      -x509
      This req option creates a self-signed certificate.
      This req option enables you to assign private/cakey.pem as the file name for your newly created private key.
      -out cacert.pem
      This req option enables you to assign cacert.pem as your output file.
      -days 365
      This req option enables you to certify the certificate for 365 days. The default value is 30.
      -config openssl.cnf
      This req option enables you to specify openssl.cnf as the configuration file.
      Note that this command requires that you provide the following:
      • Country Name, such as US.
      • State or Province Name, such as California.
      • Locality Name, such as Menlo Park.
      • Organization Name, such as Sun Microsystems.
      • Organizational Unit Name, such as Solaris.
      • Common Name, which is the machine's fully qualified host name. For more information, see the check-hostname(1M) man page.
      • Email Address, such as someuser@example.com.
  4. (Optional) If you need a new secure connection, make a new certificate and sign the new certificate with the certificate authority.
    1. Make a new certificate.
      # cd /etc/mail/certs/CA
      # openssl req -nodes -new -x509 -keyout newreq.pem -out newreq.pem -days 365 \
      -config openssl.cnf
      writing new private key to 'newreq.pem'
      This command requires that you provide the same information that you provided in step 3c.
      Note that in this example, the certificate and private key are in the file newreq.pem.
    2. Sign the new certificate with the certificate authority.
      # openssl x509 -x509toreq -in newreq.pem -signkey newreq.pem -out tmp.pem
      Getting request Private Key
      Generating certificate request
      # openssl ca -config openssl.cnf -policy policy_anything -out newcert.pem -infiles tmp.pem
      Using configuration from openssl.cnf
      Enter pass phrase for /etc/mail/certs/CA/private/cakey.pem:
      Check that the request matches the signature
      Signature ok
      Certificate Details:
              Serial Number: 1 (0x1)
              Validity
                  Not Before: Jun 23 18:44:38 2005 GMT
                  Not After : Jun 23 18:44:38 2006 GMT
              Subject:
                  countryName               = US
                  stateOrProvinceName       = California
                  localityName              = Menlo Park
                  organizationName          = Sun Microsystems
                  organizationalUnitName    = Solaris
                  commonName                = somehost.somedomain.example.com
                  emailAddress              = someuser@example.com
              X509v3 extensions:
                  X509v3 Basic Constraints:
                      CA:FALSE
                  Netscape Comment:
                      OpenSSL Generated Certificate
                  X509v3 Subject Key Identifier:
                      93:D4:1F:C3:36:50:C5:97:D7:5E:01:E4:E3:4B:5D:0B:1F:96:9C:E2
                  X509v3 Authority Key Identifier:
                      keyid:99:47:F7:17:CF:52:2A:74:A2:C0:13:38:20:6B:F1:B3:89:84:CC:68
                      DirName:/C=US/ST=California/L=Menlo Park/O=Sun Microsystems/OU=Solaris/\
                      CN=someuser@example.com/emailAddress=someuser@example.com
                      serial:00
      Certificate is to be certified until Jun 23 18:44:38 2006 GMT (365 days)
      Sign the certificate? [y/n]:y
      1 out of 1 certificate requests certified, commit? [y/n]y
      Write out database with 1 new entries
      Data Base Updated
      # rm -f tmp.pem
      In this example the file newreq.pem contains the unsigned certificate and private key. The file newcert.pem contains the signed certificate.
      x509 utility
      Displays certificate information, converts certificates to various forms, and signs certificate requests
      ca application
      Used to sign certificate requests in a variety of forms and to generate CRLs (certificate revocation lists)
  5. Enable sendmail to use the certificates by adding the following lines to your .mc file.
    define(`confCACERT_PATH', `/etc/mail/certs')dnl
    define(`confCACERT', `/etc/mail/certs/CAcert.pem')dnl
    define(`confSERVER_CERT', `/etc/mail/certs/MYcert.pem')dnl
    define(`confSERVER_KEY', `/etc/mail/certs/MYkey.pem')dnl
    define(`confCLIENT_CERT', `/etc/mail/certs/MYcert.pem')dnl
    define(`confCLIENT_KEY', `/etc/mail/certs/MYkey.pem')dnl
    For more information, see Configuration File Options for Running SMTP With TLS.
  6. Rebuild and install your sendmail.cf file in your /etc/mail directory.
    For detailed instructions, see Changing the sendmail Configuration.
  7. Create symbolic links from the files you created with openssl to the files you defined in your .mc file.
    # ln -s CA/cacert.pem CAcert.pem
    # ln -s CA/newcert.pem MYcert.pem
    # ln -s CA/newreq.pem MYkey.pem
  8. For added security, deny read permission to group and others for MYkey.pem.
    # chmod go-r MYkey.pem
  9. Use a symbolic link to install CA certs in the directory assigned to confCACERT_PATH.
    # C=CAcert.pem
    # ln -s $C `openssl x509 -noout -hash < $C`.0
  10. For secure mail with other hosts, install their host certificates.
    1. Copy the file defined by the other host's confCACERT option to /etc/mail/certs/host.domain.cert.pem.
      Replace host.domain with the other host's fully qualified host name.
    2. Use a symbolic link to install CA certs in the directory assigned to confCACERT_PATH.
      # C=host.domain.cert.pem
  11. Restart sendmail.
Example 13–2 Received: Mail Header
The following is an example of a Received: header for secure mail with TLS.
Received: from his.example.com ([IPv6:2001:db8:3c4d:15::1a2f:1a2b])
        by her.example.com (8.13.4+Sun/8.13.4) with ESMTP id j2TNUB8i242496
        (version=TLSv1/SSLv3 cipher=DHE-RSA-AES256-SHA bits=256 verify=OK)
        for <janepc@her.example.com>; Tue, 29 Mar 2005 15:30:11 -0800 (PST)
Received: from her.example.com (her.city.example.com [192.168.0.0])
        by his.example.com (8.13.4+Sun/8.13.4) with ESMTP id j2TNU7cl571102
        for <janepc@her.example.com>; Tue, 29 Mar 2005 15:30:07 -0800 (PST)
Note that the value for verify is OK, which means that the authentication was successful. For more information, see Macros for Running SMTP With TLS.
See Also
The following OpenSSL man pages:
ProcedureHow to Manage Mail Delivery by Using an Alternate Configuration of sendmail.cf
To facilitate the transport of inbound mail and outbound mail, the new default configuration of sendmail uses a daemon and a client queue runner. The client queue runner must be able to submit mail to the daemon on the local SMTP port. If the daemon is not listening on the SMTP port, the mail remains in the queue. To avoid this problem, perform the following task. For more information about the daemon and client queue runner and to understand why you might have to use this alternate configuration, refer to submit.cf Configuration File From Version 8.12 of sendmail.
This procedure ensures that your daemon runs only to accept connections from the local host.
  2. Stop sendmail client service.
    # svcadm disable -t sendmail-client
  3. Make a copy of the configuration file that you are changing.
    # cp submit.mc submit-myhost.mc
    myhost
  4. Edit the new configuration file (for example, submit-myhost.mc)
    Change the listening host IP address to the msp definition.
    # grep msp submit-myhost.mc
    FEATURE(`msp', `[#.#.#.#]')dnl
    # /usr/ccs/bin/make submit-myhost.cf
  6. Install the new configuration file after making a copy of the original.
    # cp /etc/mail/submit.cf /etc/mail/submit.cf.save
    # cp submit-myhost.cf /etc/mail/submit.cf
  7. Restart the sendmail client service.
    # svcadm enable sendmail-client
The following table describes the procedures for administering mail alias files. For more information about this topic, refer to Mail Alias Files in Chapter 14, Mail Services (Reference).
Task
Description
For Instructions
Managing alias entries in an NIS+ mail_aliases table
If your name service is NIS+, use these procedures to manage the contents of your mail_aliases table.
Initiate an NIS+ mail_aliases table.
How to Initiate an NIS+ mail_aliases Table
List the contents of the NIS+ mail_aliases table.
This procedure includes examples of how to list individual entries and how to list partial matches.
How to List the Contents of the NIS+ mail_aliases Table
Add aliases to the NIS+ mail_aliases table from the command line.
How to Add Aliases to the NIS+ mail_aliases Table From the Command Line
Add entries by editing an NIS+ mail_aliases table.
How to Add Entries by Editing an NIS+ mail_aliases Table
Edit entries in an NIS+ mail_aliases table.
This procedure includes an example of how to delete an entry.
How to Edit Entries in an NIS+ mail_aliases Table
Setting up an NIS mail.aliases map
If your name service is NIS, follow these instructions to facilitate aliasing with a mail.aliases map.
How to Set Up an NIS mail.aliases Map
Setting up a local mail alias file
If you are not using a name service (such as NIS or NIS+), follow these instructions to facilitate aliasing with the /etc/mail/aliases file.
How to Set Up a Local Mail Alias File
Creating a keyed map file
Use these steps to facilitate aliasing with a keyed map file.
How to Create a Keyed Map File
Setting up the postmaster alias
Use the procedures in this section to manage the postmaster alias. You must have this alias.
Managing the postmaster Alias
Mail aliases must be unique within the domain. This section provides the procedures for administering mail alias files. Alternately, you can use the Mailing List feature in the Solaris Management Console to perform these tasks on the aliases database.
In addition, you can create database files for the local mail host by using makemap. Refer to the makemap(1M) man page. The use of these database files does not provide all of the advantages of using a name service such as NIS or NIS+. However, you should be able to retrieve the data from these local database files faster because no network lookups are involved. For more information, refer to Interactions of sendmail With Name Services and Mail Alias Files in Chapter 14, Mail Services (Reference).
Choose from the following procedures:
ProcedureHow to Initiate an NIS+ mail_aliases Table
You can use the aliasadm command to manage entries in an NIS+ table. To create a table, follow these instructions. For more information, refer to the aliasadm(1M) man page.
  1. Either be a member of the NIS+ group that owns the table, or become root on the mail server, or assume an equivalent role.
  2. Initiate an NIS+ table.
    # aliasadm -I
  3. Add entries to the table.
ProcedureHow to List the Contents of the NIS+ mail_aliases Table
To see a complete list of the contents of the table, follow these instructions.
  2. List all of the entries in alphabetical order by alias.
    # aliasadm -1
Example 13–3 Listing an Individual Entry From the NIS+ mail_aliases Table
Alternately, you can use the aliasadm command to list individual entries. After you complete the first step in this procedure, type the following:
# aliasadm -m ignatz
ignatz: ignatz@saturn # Alias for Iggy Ignatz
The command matches only the complete alias name, not partial strings. You cannot use metacharacters, such as * and ?, with aliasadm -m.
Example 13–4 Listing Partial Matches From the NIS+ mail_aliases Table
Also, you can use the aliasadm command to list partial matches. After you complete the first step in this procedure, type the following:
# aliasadm -l | grep partial-string
Replace partial-string with the desired string for your search.
ProcedureHow to Add Aliases to the NIS+ mail_aliases Table From the Command Line
To add two or three aliases to the table, follow the following instructions. If you are adding more than two or three aliases, see How to Add Entries by Editing an NIS+ mail_aliases Table.
  1. Compile a list of each of your mail clients, the locations of their mailboxes, and the names of the mail server systems.
  2. Either be a member of the NIS+ group that owns the table, or become root on the mail server, or assume an equivalent role.
  3. (Optional) If necessary, initiate an NIS+ table.
    If you are creating a completely new NIS+ mail_aliases table, you must first initiate the table. To complete this task, refer to How to Initiate an NIS+ mail_aliases Table.
  4. Add aliases to the table.
    See this example of a typical entry.
    # aliasadm -a iggy iggy.ignatz@saturn "Iggy Ignatz"
    The following list describes the input from the preceding example.
    -a
    The option for adding an alias
    iggy
    The short form of the alias name
    iggy.ignatz@saturn
    The expanded alias name
    "Iggy Ignatz"
    The name for the alias in quotation marks
  5. Display the entry that you created and ensure that the entry is correct.
    # aliasadm -m alias
    alias
    The entry that you created
ProcedureHow to Add Entries by Editing an NIS+ mail_aliases Table
You can use the aliasadm command to manage entries in an NIS+ table. To add more than two or three aliases to the table, follow these instructions.
  3. Display and edit the aliases table.
    # aliasadm -e
    This command displays the table and enables you to edit the table. The editor that you use has been set with the $EDITOR environment variable. If this variable is not set, vi is the default editor.
  4. Use the following format to type each alias on a separate line.
    alias: expanded-alias # ["option" # "comments"]
    alias
    This column is for the short form of the alias name.
    expanded-alias
    This column is for the expanded alias name.
    option
    This column is reserved for future use.
    comments
    This column is used for comments about the individual alias, such as a name for the alias.
    If you leave the option column blank, type an empty pair of quotation marks ("") and add the comments.
    The order of the entries is not important to the NIS+ mail_aliases table. The aliasadm -l command sorts the list and displays the entries in alphabetical order.
    For more information, refer to Mail Alias Files and the aliasadm(1M) man page.
ProcedureHow to Edit Entries in an NIS+ mail_aliases Table
To edit entries in the table, follow these instructions.
  2. Display the alias entry.
    # aliasadm -m alias
    Replace alias with the assigned alias name.
  3. Edit the alias entry, as necessary.
    # aliasadm -c alias expanded-alias [options comments]
    alias
    If necessary, edit the alias name.
    expanded-alias
    If necessary, edit the expanded alias name.
    options
    If necessary, edit the option.
    comments
    If necessary, edit the comment for this entry.
    For more information, refer to the aliasadm(1M) man page, as well as Mail Alias Files.
  4. Display the entry that you have edited and ensure that the entry is correct.
    # aliasadm -m alias
Example 13–5 Deleting Entries From an NIS+ mail_aliases Table
To delete entries from the table, use the following syntax after you complete the first step in this procedure:
# aliasadm -d alias
Replace alias with the alias name for the entry that you are deleting.
ProcedureHow to Set Up an NIS mail.aliases Map
Use the following procedure to facilitate aliasing with an NIS mail.aliases map.
  2. Become root on the NIS master server or assume an equivalent role.
  3. Edit the /etc/mail/aliases file, and make the following entries.
    1. Add an entry for each mail client.
      # cat /etc/mail/aliases
      alias:expanded-alias
      alias
      Use the short alias name.
      expanded-alias
      Use the expanded alias name (user@host.domain.com).
    2. Ensure that you have a Postmaster: root entry.
      Postmaster: root
    3. Add an alias for root. Use the mail address of the person who is designated as the postmaster.
      root: user@host.domain.com
      Use the assigned address of the designated postmaster.
  4. Ensure that the NIS master server is running a name service to resolve the host names on each mail server.
  5. Change to the /var/yp directory.
    # cd /var/yp
  6. Apply the make command.
    # make
    The changes in the /etc/hosts and /etc/mail/aliases files are propagated to NIS slave systems. The changes are active in only a few minutes, at most.
ProcedureHow to Set Up a Local Mail Alias File
Use the following procedure to resolve aliases with a local mail alias file.
  1. Compile a list of each of your users and the locations of their mailboxes.
  2. Become an root on the mail server or assume an equivalent role.
  3. Edit the /etc/mail/aliases file and make the following entries.
    1. Add an entry for each user.
      user1: user2@host.domain
      user1
      Use the new alias name.
      user2@host.domain
      Use the actual address for the new alias.
      Postmaster: root
  4. Rebuild the alias database.
    # newaliases
    The configuration of the AliasFile option in /etc/mail/sendmail.cf determines whether this command generates in binary form either the single file, /etc/mail/aliases.db, or the pair of files, /etc/mail/aliases.dir and /etc/mail/aliases.pag.
  5. Perform one of the following steps to copy the file or files that were generated.
    1. (Optional) Copy the /etc/mail/aliases, the /etc/mail/aliases.dir, and the/etc/mail/aliases.pag files to each of the other systems.
      You can copy the three files by using the rcp or rdist commands. Refer to the rcp(1) man page or the rdist(1) man page for more information. Alternately, you can create a script for this purpose.
      When you copy these files, you do not need to run the newaliases command on each of the other systems. However, remember that you must update all the /etc/mail/aliases files each time you add or remove a mail client.
    2. (Optional) Copy the /etc/mail/aliases and the /etc/mail/aliases.db files to each of the other systems.
      You can copy these files by using the rcp or rdist commands. Refer to the rcp(1) man page or the rdist(1) man page for more information. Alternately, you can create a script for this purpose.
ProcedureHow to Create a Keyed Map File
To create a keyed map file, follow these instructions.
  2. Create an input file.
    Entries can have the following syntax.
    old-name@newdomain.com   new-name@newdomain.com
    old-name@olddomain.com    error:nouser No such user here
    @olddomain.com          %1@newdomain.com
    old_name@newdomain.com
    Use the user name that was previously assigned with the domain that is newly assigned.
    new_name@newdomain.com
    Use the address that is newly assigned.
    old_name@olddomain.com
    Use the user name that was previously assigned with the domain that was previously assigned.
    olddomain.com
    Use the domain that was previously assigned.
    newdomain.com
    Use the domain that is newly assigned.
    The first entry redirects mail to a new alias. The next entry creates a message when an incorrect alias is used. The last entry redirects all incoming mail from olddomain to newdomain.
  3. Create the database file.
    # /usr/sbin/makemap maptype newmap < newmap
    maptype
    Select a database type, such as dbm, btree, or hash.
    newmap
    Use the name of the input file and the first part of the name of the database file. If the dbm database type is selected, then the database files are created by using a .pag and a .dir suffix. For the other two database types, the file name is followed by .db.
Every system must be able to send mail to a postmaster mailbox. You can create an NIS or NIS+ alias for postmaster, or you can create the alias in each local /etc/mail/aliases file. Refer to these procedures.
ProcedureHow to Create a postmaster Alias in Each Local /etc/mail/aliases File
If you are creating the postmaster alias in each local /etc/mail/aliases file, follow these instructions.
  2. View the /etc/mail/aliases entry.
    # Following alias is required by the mail protocol, RFC 2821
    # Set it to the address of a HUMAN who deals with this system's
    # mail problems.
    Postmaster: root
  3. Edit each system's /etc/mail/aliases file.
    Change root to the mail address of the person who is designated as the postmaster.
    Postmaster: mail-address
    mail-address
    Use the assigned address for the person who is designated as the postmaster.
  4. (Optional) Create a separate mailbox for the postmaster.
    You can create a separate mailbox for the postmaster to keep postmaster mail separate from personal mail. If you create a separate mailbox, use the mailbox address instead of the postmaster's personal mail address when you edit the /etc/mail/aliases files. For details, refer to How to Create a Separate Mailbox for postmaster.
ProcedureHow to Create a Separate Mailbox for postmaster
If you are creating a separate mailbox for postmaster, follow these instructions.
  2. Create a user account for the person who is designated as postmaster. Put an asterisk (*) in the password field.
    For details about adding a user account, refer to Chapter 5, Managing User Accounts and Groups (Tasks), in System Administration Guide: Basic Administration.
  3. After mail has been delivered, enable the mail program to read and write to the mailbox name.
    # mail -f postmaster
    postmaster
    Use the assigned address.
ProcedureHow to Add the postmaster Mailbox to the Aliases in the /etc/mail/aliases File
If you are adding a postmaster mailbox to the aliases in the /etc/mail/aliases file, follow these instructions.
  2. Add an alias for root. Use the mail address of the person who is designated as the postmaster.
    Use the assigned address of the person who is designated as postmaster.
  3. On the postmaster's local system, create an entry in the /etc/mail/aliases file that defines the name of the alias. sysadmin is an example. Also, include the path to the local mailbox.
    sysadmin: /usr/somewhere/somefile
    sysadmin
    Create a name for a new alias.
    Use the path to the local mailbox.
    # newaliases
The following table describes the procedures for administering the mail queue.
Task
Description
For Instructions
Displaying the contents of the mail queue, /var/spool/mqueue
Use this procedure to see how many messages are in the queue and how fast the messages are being cleared from the queue.
How to Display the Contents of the Mail Queue, /var/spool/mqueue
Forcing mail queue processing for the mail queue, /var/spool/mqueue
Use this procedure to process messages to a system that previously was unable to receive messages.
How to Force Mail Queue Processing in the Mail Queue, /var/spool/mqueue
Running a subset of the mail queue, /var/spool/mqueue
Use this procedure to force a substring of an address, such as a host name, to be processed. Also, use this procedure to force a particular message out of the queue.
How to Run a Subset of the Mail Queue, /var/spool/mqueue
Moving the mail queue, /var/spool/mqueue
Use this procedure to move the mail queue.
How to Move the Mail Queue, /var/spool/mqueue
Running the old mail queue, /var/spool/omqueue
Use this procedure to run an old mail queue.
How to Run the Old Mail Queue, /var/spool/omqueue
This section describes some helpful tasks for queue administration. For information about the client-only queue, refer to submit.cf Configuration File From Version 8.12 of sendmail. For other related information, you can refer to Additional Queue Features From Version 8.12 of sendmail.
Refer to the following:
ProcedureHow to Display the Contents of the Mail Queue, /var/spool/mqueue
  1. Show how many messages are in the queue and how fast they are being cleared from the queue.
    Type the following:
    # /usr/bin/mailq | more
    This command provides the following information.
    • The queue IDs
    • The size of the message
    • The date that the message entered the queue
    • The message status
    • The sender and the recipients
    Additionally, this command now checks for the authorization attribute, solaris.admin.mail.mailq. If the check is successful, the equivalent of specifying the -bp flag with sendmail is executed. If the check fails, an error message is printed. By default, this authorization attribute is enabled for all users. The authorization attribute can be disabled by modifying the user entry in prof_attr. For more information, refer to the man pages for prof_attr(4) and mailq(1).
ProcedureHow to Force Mail Queue Processing in the Mail Queue, /var/spool/mqueue
Use this procedure, for example, to process messages to a system that was previously unable to receive messages.
  2. Force queue processing and display the progress of the jobs as the queue is cleared.
    # /usr/lib/sendmail -q -v
ProcedureHow to Run a Subset of the Mail Queue, /var/spool/mqueue
Use this procedure, for example, to force a substring of an address, such as a host name, to be processed. Also, use this procedure to force a particular message from the queue.
  2. Run a subset of the mail queue at any time with -qRstring.
    # /usr/lib/sendmail -qRstring
    string
    Use a recipient's alias or a substring of user@host.domain, such as a host name.
    Alternately, you can run a subset of the mail queue with -qInnnnn.
    # /usr/lib/sendmail -qInnnnn
    nnnnn
    Use a queue ID.
ProcedureHow to Move the Mail Queue, /var/spool/mqueue
If you are moving the mail queue, follow these instructions.
  1. Become root on the mail host or assume an equivalent role.
  2. Kill the sendmail daemon.
    # svcadm disable network/smtp:sendmail
    Now sendmail is no longer processing the queue directory.
  3. Change to the /var/spool directory.
    # cd /var/spool
  4. Move the directory, mqueue, and all its contents to the omqueue directory. Then create a new empty directory that is named mqueue.
    # mv mqueue omqueue; mkdir mqueue
  5. Set the permissions of the directory to read/write/execute by owner, and read/execute by group. Also, set the owner and group to daemon.
    # chmod 750 mqueue; chown root:bin mqueue
  6. Start sendmail.
ProcedureHow to Run the Old Mail Queue, /var/spool/omqueue
To run an old mail queue, follow these instructions.
  2. Run the old mail queue.
    # /usr/lib/sendmail -oQ/var/spool/omqueue -q
    The -oQ flag specifies an alternate queue directory. The -q flag says to run every job in the queue. Use the -v flag if you are displaying the verbose output on the screen.
  3. Remove the empty directory.
    # rmdir /var/spool/omqueue
The following table describes the procedures for administering .forward files. For more information, refer to .forward Files in Chapter 14, Mail Services (Reference).
Task
Description
For Instructions
Disabling .forward files
Use this procedure if, for example, you want to prevent automated forwarding.
How to Disable .forward Files
Changing the .forward file search path
Use this procedure if, for example, you want to move all .forward files into a common directory.
How to Change the .forward–File Search Path
Creating and populating /etc/shells
Use this procedure to enable users to use the .forward file to forward mail to a program or to a file.
How to Create and Populate /etc/shells
This section contains several procedures that are related to .forward file administration. Because these files can be edited by users, the files can cause problems. For more information, refer to .forward Files in Chapter 14, Mail Services (Reference).
ProcedureHow to Disable .forward Files
This procedure, which prevents automated forwarding, disables the .forward file for a particular host.
  2. Make a copy of /etc/mail/cf/domain/solaris-generic.m4 or your site-specific domain m4 file.
    # cd /etc/mail/cf/domain
    # cp solaris-generic.m4 mydomain.m4
    mydomain
    Use the file name of your choice.
  3. Add the following line to the file that you just created.
    define(`confFORWARD_PATH',`')dnl
    If a value for confFORWARD_PATH already exists in the m4 file, replace the value with this null value.
  4. Build and install a new configuration file.
    If you need help with this step, refer to How to Build a New sendmail.cf File.
    Note –
    When you edit the .mc file, remember to change DOMAIN(`solaris-generic') to DOMAIN(`mydomain').
ProcedureHow to Change the .forward–File Search Path
If, for example, you want to put all .forward files in a common directory, follow these instructions.
    mydomain
    define(`confFORWARD_PATH',`$z/.forward:/var/forward/$u')dnl
    If a value for confFORWARD_PATH already exists in the m4 file, replace the value with this new value.
    Note –
ProcedureHow to Create and Populate /etc/shells
This file is not included in the standard release. You must add the file if users are to be allowed to use .forward files to forward mail to a program or to a file. You can create the file manually by using grep to identify all of the shells that are listed in your password file. You can then type the shells into the file. However, the following procedure, which employs a script that can be downloaded, is easier to use.
  1. Download the script.
    http://www.sendmail.org/vendor/sun/gen-etc-shells.html
  2. Become superuser or assume an equivalent role.
  3. To generate a list of shells, run the gen-etc-shells script.
    # ./gen-etc-shells.sh > /tmp/shells
    This script uses the getent command to collect the names of shells that are included in the password file sources that are listed in /etc/nsswitch.conf.
  4. Inspect and edit the list of shells in /tmp/shells.
    With the editor of your choice, remove any shells that you are not including.
  5. Move the file to /etc/shells.
    # mv /tmp/shells /etc/shells
The following table describes troubleshooting procedures and tips for mail services.
Task
Description
For Instructions
Testing mail configuration
Steps for testing changes to the sendmail configuration file
Checking mail aliases
A step to confirm that mail can or cannot be delivered to a specified recipient
How to Check Mail Aliases
Testing the rule sets
Steps for checking the input and returns of the sendmail rule sets
How to Test the sendmail Rule Sets
Verifying connections to other systems
Tips for verifying connections to other systems
How to Verify Connections to Other Systems
Logging messages by using the syslogd program
Tips for gathering error message information
Logging Error Messages
Checking other sources for diagnostic information
Tips for getting diagnostic information from other sources
Other Sources for Mail Diagnostic Information
This section provides some procedures and tips that you can use for troubleshooting problems with mail services.
ProcedureHow to Test the Mail Configuration
To test the changes that you make to your configuration file, follow these instructions.
  1. Restart sendmail on any system that has a revised configuration file.
    # svcadm refresh network/smtp:sendmail
  2. Send test messages from each system.
    # /usr/lib/sendmail -v names </dev/null
    names
    Specify a recipient's email address.
    This command sends a null message to the specified recipient and displays the message activity on your monitor.
  3. Send mail to yourself or other people on the local system by addressing the message to a regular user name.
  4. (Optional) If you are connected to a network, send mail in three directions to someone on another system.
    • From the main system to a client system
    • From a client system to the main system
    • From a client system to another client system
  5. (Optional) If you have a mail gateway, send mail from the mail host to another domain to ensure that the relay mailer and host are configured properly.
  6. (Optional) If you have set up a UUCP connection on your phone line to another host, send mail to someone at that host. Have that person send mail back or call you when the message is received.
  7. Ask someone to send mail to you over the UUCP connection.
    The sendmail program cannot detect whether the message is delivered because the program passes the message to UUCP for delivery.
  8. From different systems, send a message to postmaster and ensure that the message is delivered to your postmaster's mailbox.
The following example shows you how to verify an alias.
% mconnect
connecting to host localhost (127.0.0.1), port 25
connection open
220 your.domain.com ESMTP Sendmail 8.13.6+Sun/8.13.6; Tue, 12 Sep 2004 13:34:13 -0800 (PST)
expn sandy
250 2.1.5 <sandy@phoenix.example.com>
quit
221 2.0.0 your.domain.com closing connection
In this example, the mconnect program opened a connection to a mail server on a local host and enabled you to test that connection. The program runs interactively, so you can issue various diagnostic commands. For a complete description, see the mconnect(1) man page. The entry, expn sandy, provided the expanded address, sandy@phoenix.example.com. Thus, you have verified that mail can be delivered when using the alias sandy.
Remember to avoid loops and inconsistent databases when both local and domain-wide aliases are used. Be especially careful to avoid the creation of alias loops when you move a user from one system to another system.
ProcedureHow to Test the sendmail Rule Sets
To check the input and returns of the sendmail rule sets, follow these instructions.
  1. Change to address test mode.
    # /usr/lib/sendmail -bt
  2. Test a mail address.
    Provide the following numbers and address at the last prompt (>).
    > 3,0 mail-sraddress
    mail-address
    Use the mail address that you are testing.
  3. End the session.
    Press Control-d.
Example 13–6 Address Test Mode Output
The following is an example of the output from the address test mode.
ADDRESS TEST MODE (ruleset 3 NOT automatically invoked)
Enter <ruleset> <address>
> 3,0 sandy@phoenix
canonify           input: sandy @ phoenix
Canonify2          input: sandy < @ phoenix >
Canonify2        returns: sandy < @ phoenix . example . com . >
canonify         returns: sandy < @ phoenix . example . com . >
parse              input: sandy < @ phoenix . example . com . >
Parse0             input: sandy < @ phoenix . example . com . >
Parse0           returns: sandy < @ phoenix . example . com . >
ParseLocal         input: sandy < @ phoenix . example . com . >
ParseLocal       returns: sandy < @ phoenix . example . com . >
Parse1             input: sandy < @ phoenix . example . com . >
MailerToTriple     input: < mailhost . phoenix . example . com >
MailerToTriple   returns: $# relay $@ mailhost . phoenix . example . com
     $: sandy < @ phoenix . example . com . >
Parse1           returns: $# relay $@ mailhost . phoenix . example . com
parse            returns: $# relay $@ mailhost . phoenix . example . com
The mconnect program opens a connection to a mail server on a host that you specify and enables you to test that connection. The program runs interactively, so you can issue various diagnostic commands. See the mconnect(1) man page for a complete description. The following example verifies that mail to the user name sandy is deliverable.
% mconnect phoenix
connecting to host phoenix (172.31.255.255), port 25
connection open
220 phoenix.example.com ESMTP Sendmail 8.13.1+Sun/8.13.1; Sat, 4 Sep 2004 3:52:56 -0700
expn sandy
quit
If you cannot use mconnect to connect to an SMTP port, check these conditions.
Your mail service logs most error messages by using the syslogd program. By default, the syslogd program sends these messages to a system that is called loghost, which is specified in the /etc/hosts file. You can define loghost to hold all logs for an entire NIS domain. If no loghost is specified, error messages from syslogd are not reported.
The /etc/syslog.conf file controls where the syslogd program forwards messages. You can change the default configuration by editing the /etc/syslog.conf file. You must restart the syslog daemon for any changes to become active. To gather information about mail, you can add the following selections to the file.
The following entry in the /etc/syslog.conf file sends a copy of all critical, informational, and debug messages to /var/log/syslog.
mail.crit;mail.info;mail.debug			/var/log/syslog
Each line in the system log contains a timestamp, the name of the system that generated the line, and a message. The syslog file can log a large amount of information.
The log is arranged in a succession of levels. At the lowest level, only unusual occurrences are logged. At the highest level, even the most mundane and uninteresting events are recorded. As a convention, log levels under 10 are considered “useful.” Log levels that are higher than 10 are usually used for debugging. See Customizing System Message Logging in System Administration Guide: Advanced Administration for information about loghost and the syslogd program.
For other diagnostic information, check the following sources.
This section describes how you can resolve some sendmail–related error messages. You can also refer to http://www.sendmail.org/faq.
The following error messages contain two or more of the following types of information.
451 timeout waiting for input during source
Cause:
When sendmail reads from any source that might time out, such as an SMTP connection, the program sets a timer to the value of various Timeout options before reading begins. If the read is not completed before the timer expires, this message appears and reading stops. Usually, this situation occurs during RCPT. The mail message is then queued for later delivery.
Solution:
If you see this message often, increase the value of various Timeout options in the /etc/mail/sendmail.cf file. If the timer is already set to a large number, look for hardware problems, such as poor network cabling or connections.
550 hostname... Host unknown
Cause:
This sendmail message indicates that the destination host machine, which is specified by the portion of the address after the at sign (@), was not found during domain name system (DNS) lookup.
Solution:
Use the nslookup command to verify that the destination host exists in that domain or other domains, perhaps with a slightly different spelling. Otherwise, contact the intended recipient and ask for a proper address.
550 username... User unknown
Cause:
This sendmail message indicates that the intended recipient, who is specified by the portion of the address before the at sign (@), could not be located on the destination host machine.
Solution:
Check the email address and try again, perhaps with a slightly different spelling. If this remedy does not work, contact the intended recipient and ask for a proper address.
554 hostname... Local configuration error
Cause:
This sendmail message usually indicates that the local host is trying to send mail to itself.
Solution:
Check the value of the $j macro in the /etc/mail/sendmail.cf file to ensure that this value is a fully qualified domain name.
Description:
When the sending system provides its host name to the receiving system in the SMTP HELO command, the receiving system compares its name to the sender's name. If these names are the same, the receiving system issues this error message and closes the connection. The name that is provided in the HELO command is the value of the $j macro.
For additional information, refer to http://www.sendmail.org/faq/section4#4.5.
config error: mail loops back to myself.
Cause:
This error message occurs if you set up an MX record and make host bar the mail exchanger for domain foo. However, you fail to configure host bar to know that it is the mail exchanger for domain foo.
Also, another possibility is that both the sending system and the receiving system are identifying as the same domain.
Solution:
For instructions, refer to http://www.sendmail.org/faq/section4#4.5.
host name configuration error
Description:
This is an old sendmail message, which replaced I refuse to talk to myself and is now replaced by the Local configuration error message.
Solution:
Follow the instructions that were provided for resolving this error message, 554 hostname... Local configuration error.
user unknown
Cause:
When you try to send mail to a user, the error Username... user unknown is displayed. The user is on the same system.
Solution:
Check for a typographical error in the entered email address. Otherwise, the user could be aliased to a nonexistent email address in /etc/mail/aliases or in the user's .mailrc file. Also, check for uppercase characters in the user name. Preferably, email addresses should not be case sensitive.
For additional information, refer to http://www.sendmail.org/faq/section4#4.17.
Chapter 14 Mail Services (Reference)
The sendmail program is a mail transport agent. The program uses a configuration file to provide aliasing and forwarding, automatic routing to network gateways, and flexible configuration. The Solaris OS supplies standard configuration files that most sites can use. Chapter 12, Mail Services (Overview) provides an introduction to the components of mail services and a description of a typical mail service configuration. Chapter 13, Mail Services (Tasks) explains how to set up and administer an electronic mail system. This chapter provides information about the following topics.
For details that are not covered in these chapters, see the following man pages:
Solaris Version of sendmail
This section, which includes the following topics, describes some of the differences in the Solaris version of sendmail as compared to the generic Berkeley version.
Flags Used and Not Used to Compile sendmail
Starting in the Solaris 10 release, the following flags are used to compile sendmail. If your configuration requires other flags, you need to download the source and recompile the binary. You can find information about this process at http://www.sendmail.org.
Table 14–1 General sendmail Flags
Flag
Description
SOLARIS=21000
Support for the Solaris 10 release.
MILTER
Support for the Mail Filter API. In version 8.13 of sendmail, this flag is enabled by default. See MILTER, Mail Filter API for sendmail.
NETINET6
Support for IPv6. This flag has been moved from conf.h to Makefile.
Table 14–2 Maps and Database Types
Flag
Description
NDBM
Support for ndbm databases
NEWDB
Support for Berkeley DB databases
USERDB
Support for the user database
NIS
Support for nis databases
NISPLUS
Support for nisplus databases
LDAPMAP
Support for LDAP maps
MAP_REGEX
Support for regular expression maps
Table 14–3 Solaris Flags
Flag
Description
SUN_EXTENSIONS
Support for Sun extensions that are included in sun_compat.o.
SUN_INIT_DOMAIN
For backward compatibility, support for the use of NIS domain names to fully qualify the local host name. For more information, look for vendor-specific information in http://www.sendmail.org.
SUN_SIMPLIFIED_LDAP
Support for a simplified LDAP API, which is specific to Sun. For more information, look for vendor-specific information in http://www.sendmail.org.
VENDOR_DEFAULT=VENDOR_SUN
Selects Sun as the default vendor.
The following table lists generic flags that are not used to compile the version of sendmail that is delivered with the Solaris 10 release.
Table 14–4 Generic Flags Not Used in the Solaris Version of sendmail
Flag
Description
SASL
Simple Authentication and Security Layer (RFC 2554)
STARTTLS
Transaction Level Security (RFC 2487)
To see a list of the flags that are used to compile sendmail, use the following command.
% /usr/lib/sendmail -bt -d0.10 < /dev/null
Note –
The preceding command does not list the flags that are specific to Sun.
MILTER, sendmail's Mail Filter API, enables third-party programs to access mail messages as they are being processed to filter meta-information and content. You do not need to build the filter and configure sendmail to use it. This API is enabled by default in version 8.13 of sendmail.
For more details, see the following:
Alternative sendmail Commands
The Solaris release does not include all of the command synonyms that are provided in the generic release from sendmail.org. This table includes a complete list of the command aliases. The table also lists whether the commands are included in the Solaris release and how to generate the same behavior by using sendmail.
Table 14–5 Alternate sendmail Commands
Alternate Name
In the Solaris Release?
Options With sendmail
hoststat
No
sendmail -bh
mailq
Yes
sendmail -bp
newaliases
Yes
sendmail -bi
purgestat
No
sendmail -bH
smtpd
No
sendmail -bd
Versions of the Configuration File
Starting in the Solaris 10 release, sendmail includes a configuration option that enables you to define the version of the sendmail.cf file. This option enables older configuration files to be used with the current version of sendmail. You can set the version level to values between 0 and 10. You can also define the vendor. Either Berkeley or Sun is a valid vendor option. If a version level is specified but no vendor is defined, Sun is used as the default vendor setting. The following table lists some of the valid options.
Table 14–6 Version Values for the Configuration File
Field
Description
V7/Sun
Setting that was used for version 8.8 of sendmail.
V8/Sun
Setting that was used for version 8.9 of sendmail. This setting was included in the Solaris 8 release.
V9/Sun
Setting that was used for versions 8.10 and 8.11 of sendmail.
V10/Sun
Setting that is used for version 8.12 and version 8.13 of sendmail. Version 8.12 is the default for the Solaris 9 release. Starting in the Solaris 10 release, version 8.13 is the default.
Note –
You are urged not to use V1/Sun. For more information, refer to http://www.sendmail.org/vendor/sun/differences.html#4.
For task information, refer to Changing the sendmail Configuration in Chapter 13, Mail Services (Tasks).
Software and Hardware Components of Mail Services
This section describes the software and hardware components of a mail system.
Software Components
Each mail service includes at least one of each of the following software components.
This section also describes these software components.
Mail User Agent
The mail user agent is the program that acts as the interface between the user and mail transfer agent. The sendmail program is a mail transfer agent. The Solaris operating system supplies the following mail user agents.
Mail Transfer Agent
The mail transfer agent is responsible for the routing of mail messages and the resolution of mail addresses. This agent is also known as a mail transport agent. The transfer agent for the Solaris operating system is sendmail. The transfer agent performs these functions.
Local Delivery Agent
A local delivery agent is a program that implements a mail delivery protocol. The following local delivery agents are provided with the Solaris operating system.
Changes From Version 8.12 of sendmail provides information on these related topics.
Mailers and sendmail
Mailer is a sendmail-specific term. A mailer is used by sendmail to identify a specific instance of a customized local delivery agent or a customized mail transfer agent. You need to specify at least one mailer in your sendmail.cf file. For task information, refer to Changing the sendmail Configuration in Chapter 13, Mail Services (Tasks). This section provides a brief description of two types of mailers.
For additional information about mailers, see http://www.sendmail.org/m4/readme.html or /etc/mail/cf/README.
Simple Mail Transfer Protocol (SMTP) Mailers
SMTP is the standard mail protocol that is used on the Internet. This protocol defines these mailers.
UNIX-to-UNIX Copy Program (UUCP) Mailers
If possible, avoid using UUCP. For an explanation, refer to http://www.sendmail.org/m4/uucp_mailers.html or do a search in /etc/mail/cf/README on this string: USING UUCP MAILERS.
UUCP defines these mailers.
uucp-old
Names in the $=U class are sent to uucp-old. uucp is the obsolete name for this mailer. The uucp-old mailer uses an exclamation-point address in the headers.
uucp-new
Names in the $=Y class are sent to uucp-new. Use this mailer when you know that the receiving UUCP mailer can manage multiple recipients in one transfer. suucp is the obsolete name for this mailer. The uucp-new mailer also uses an exclamation-point address in the headers.
If MAILER(smtp) is also specified in your configuration, two more mailers are defined.
uucp-dom
This mailer uses domain-style addresses and, basically, applies the SMTP rewriting rules.
uucp-uudom
Names in the $=Z class are sent to uucp-uudom. uucp-uudom and uucp-dom use the same header address format, domain-style addresses.
Note –
Because the smtp mailer modifies the UUCP mailer, always put MAILER(smtp) before MAILER(uucp) in your .mc file.
Mail Addresses
The mail address contains the name of the recipient and the system to which the mail message is delivered. When you administer a small mail system that does not use a name service, addressing mail is easy. The login names uniquely identify the users. Complexity is introduced if you are administering a mail system that has more than one system with mailboxes or that has one or more domains. Additional complexity can be generated if you have a UUCP (or other) mail connection to servers outside your network. The information in the following sections can help you understand the parts and complexities of a mail address.
Domains and Subdomains
Email addressing uses domains. A domain is a directory structure for network address naming. A domain can have one or more subdomains. The domain and subdomains of an address can be compared to the hierarchy of a file system. Just as a subdirectory is considered to be inside the directory above it, each subdomain in a mail address is considered to be inside the location to its right.
The following table shows some top-level domains.
Table 14–7 Top-Level Domains
Domain
Description
com
Commercial sites
edu
Educational sites
gov
United States government installations
mil
United States military installations
net
Networking organizations
org
Other nonprofit organizations
Domains are case insensitive. You can use uppercase, lowercase, or mixed-case letters in the domain part of an address without making any errors.
Name Service Domain Name and Mail Domain Name
When you are working with name service domain names and mail domain names, remember the following.
For more information, refer to Interactions of sendmail With Name Services.
Typical Format for Mail Addresses
Typically, a mail address has the following format. For further details, refer to Route–Independent Mail Addresses.
user@subdomain. ... .subdomain2.subdomain1.top-level-domain
The part of the address to the left of the @ sign is the local address. The local address can contain the following.
Note –
The receiving mailer is responsible for determining what the local part of the address means. For information about mailers, refer to Mailers and sendmail.
The part of the address to the right of the @ sign shows the domain levels, which is where the local address resides. A dot separates each subdomain. The domain part of the address can be an organization, a physical area, or a geographic region. Furthermore, the order of domain information is hierarchical, so the more local the subdomain, the closer the subdomain is to the @ sign.
Mail addresses can be route independent. Route-independent addressing requires the sender of an email message to specify the name of the recipient and the final destination. A high-speed network, such as the Internet, uses route-independent addresses. Route-independent addresses can have this format.
user@host.domain
Route-independent addresses for UUCP connections can have this address format.
host.domain!user
The increased popularity of the domain-hierarchical naming scheme for computers is making route-independent addresses more common. Actually, the most common route-independent address omits the host name and relies on the domain name service to properly identify the final destination of the email message.
user@domain
Route-independent addresses are first read by searching for the @ sign. The domain hierarchy is then read from the right (the highest level) to the left (the most specific part of the address to the right of the @ sign).
Mailbox Files
A mailbox is a file that is the final destination for email messages. The name of the mailbox can be the user name or the identity of a specific function, such as the postmaster. Mailboxes are in the /var/mail/username file, which can exist either on the user's local system or on a remote mail server. In either instance, the mailbox is on the system to which the mail is delivered.
Mail should always be delivered to a local file system so that the user agent can pull mail from the mail spool and store it readily in the local mailbox. Do not use NFS-mounted file systems as the destination for a user's mailbox. Specifically, do not direct mail to a mail client that is mounting the /var/mail file system from a remote server. Mail for the user, in this instance, should be addressed to the mail server and not to the client host name. NFS-mounted file systems can cause problems with mail delivery and handling.
The /etc/mail/aliases file and name services such as NIS and NIS+ provide mechanisms for creating aliases for electronic mail addresses. So, users do not need to know the precise local name of a user's mailbox.
The following table shows some common naming conventions for special-purpose mailboxes.
Table 14–8 Conventions for the Format of Mailbox Names
Format
Description
username
User names are frequently the same as mailbox names.
Firstname.Lastname Firstname_Lastname Firstinitial.Lastname Firstinitial_Lastname
User names can be identified as full names with a dot (or an underscore) that separates the first and last names. Alternately, user names can be identified by a first initial with a dot (or an underscore) that separates the initial and the last name.
postmaster
Users can address questions and report problems with the mail system to the postmaster mailbox. Each site and domain should have a postmaster mailbox.
MAILER-DAEMON
sendmail automatically routes any mail that is addressed to the MAILER-DAEMON to the postmaster.
aliasname-request
Names that end in -request are administrative addresses for distribution lists. This address should redirect mail to the person who maintains the distribution list.
owner-aliasname
Names that begin with owner- are administrative addresses for distribution lists. This address should redirect mail to the person who handles mail errors.
owner-owner
This alias is used when no owner-aliasname alias exists for errors to be returned to. This address should redirect mail to the person who handles mail errors. This address also should be defined on any system that maintains a large number of aliases.
local%domain
The percent sign (%) marks a local address that is expanded when the message arrives at its destination. Most mail systems interpret mailbox names with % characters as full mail addresses. The % is replaced with an @, and the mail is redirected accordingly. Although many people use the % convention, this convention is not a formal standard. This convention is referred to as the “percent hack.” This feature is often used to help debug mail problems.
Starting with sendmail version 8, the envelope sender for mail that is sent to a group alias has been changed to the address that is expanded from the owner alias, if an owner alias exists. This change enables any mail errors to be sent to the alias owner, rather than being returned to the sender. With this change, users notice that mail that was sent to an alias looks as if the mail came from the alias owner, when delivered. The following alias format helps with some of the problems that are associated with this change.
mygroup: :include:/pathname/mygroup.list
owner-mygroup: mygroup-request
mygroup-request: sandys, ignatz
In this example, the mygroup alias is the actual mail alias for the group. The owner-mygroup alias receives error messages. The mygroup-request alias should be used for administrative requests. This structure means that in mail sent to the mygroup alias, the envelope sender changes to mygroup-request.
Mail Aliases
An alias is an alternate name. For email, you can use aliases to assign a mailbox location or to define mailing lists. For a task map, refer to Administering Mail Alias Files (Task Map) in Chapter 13, Mail Services (Tasks). Also, you can refer to Mail Alias Files in this chapter.
For large sites, the mail alias typically defines the location of a mailbox. Providing a mail alias is like providing a room number as part of the address for an individual at a large corporation that occupies multiple rooms. If you do not provide the room number, the mail is delivered to a central address. Without a room number, extra effort is required to determine where within the building the mail is to be delivered. So, the possibility of an error increases. For example, if two people who are named Kevin Smith are in the same building, only one of them might get mail. To correct the problem, each Kevin Smith should have a room number added to his address.
Use domains and location-independent addresses as much as possible when you create mailing lists. To enhance portability and flexibility of alias files, make your alias entries in mailing lists as generic and system independent as possible. For example, if you have a user who is named ignatz on system mars, in domain example.com, create the alias ignatz@example instead of ignatz@mars. If user ignatz changes the name of his system but remains within the example domain, you do not need to update alias files to reflect the change in system name.
When you create alias entries, type one alias per line. You should have only one entry that contains the user's system name. For example, you could create the following entries for user ignatz.
ignatz: iggy.ignatz
iggyi: iggy.ignatz
iggy.ignatz: ignatz@mars
You can create an alias for local names or domains. For example, an alias entry for user fred, who has a mailbox on the system mars and is in the domain planets, could have this entry in the NIS+ aliases table.
fred: fred@planets
When you create mail lists that include users outside your domain, create the alias with the user name and the domain name. For example, if you have a user who is named smallberries on system privet, in domain example.com, create the alias as smallberries@example.com. The email address of the sender is now automatically translated to a fully qualified domain name when mail goes outside the user's domain.
The following list describes methods for creating and administering mail alias files.
Hardware Components
You can provide the three required elements of mail configuration in the same system or have separate systems provide these elements.
When users are to communicate with networks outside your domain, you must also add a fourth element, a mail gateway. For more information, refer to Mail Gateway. The following sections describe each hardware component.
Mail Host
A mail host is the machine that you designate as the main mail machine on your network. A mail host is the machine to which other systems at the site forward mail that cannot be delivered. You designate a system as a mail host in the hosts database by adding the word mailhost to the right of the IP address in the local /etc/hosts file. Alternately, you can add the word mailhost similarly to the hosts file in the name service. For detailed task information, refer to How to Set Up a Mail Host in Chapter 13, Mail Services (Tasks).
A good candidate for a mail host is a system that is configured as a router from your network to the Internet global network. For more information, refer to Chapter 15, Solaris PPP 4.0 (Overview), Chapter 24, UUCP (Overview), and Configuring an IPv4 Router in System Administration Guide: IP Services. If no systems on your local network have a modem, designate a system as the mail host.
Some sites use standalone machines that are not networked in a time-sharing configuration. Specifically, the standalone machine serves terminals that are attached to its serial ports. You can set up electronic mail for this configuration by designating the standalone system as the mail host of a single-system network. Overview of the Hardware Components in Chapter 12, Mail Services (Overview) provides a figure that shows a typical email configuration.
Mail Server
A mailbox is a single file that contains email for a particular user. Mail is delivered to the system where the user's mailbox resides, which can be on a local machine or a remote server. A mail server is any system that maintains user mailboxes in its /var/mail directory. For task information, refer to How to Set Up a Mail Server in Chapter 13, Mail Services (Tasks).
The mail server routes all mail from a client. When a client sends mail, the mail server puts the mail in a queue for delivery. After the mail is in the queue, a user can reboot or turn off the client without losing those mail messages. When the recipient gets mail from a client, the path in the From line of the message contains the name of the mail server. If the recipient responds, the response goes to the user's mailbox. Good candidates for mail servers are systems that provide a home directory for users or systems that are backed up regularly.
If the mail server is not the user's local system, users in configurations that use NFS software can mount the /var/mail directory by using the /etc/vfstab file, if they have root access. Otherwise, users can use the automounter. If NFS support is not available, users can log in to the server to read their mail.
If users on your network send other types of mail, such as audio files or files from desktop publishing systems, you need to allocate more space on the mail server for mailboxes.
By establishing a mail server for all mailboxes, you can simplify your process of doing backups. Backups can be difficult to do when mail is spread over many systems. The disadvantage of storing many mailboxes on one server is that the server can be a single point of failure for many users. However, the advantages of providing good backups usually make the risk worthwhile.
Mail Client
A mail client is a user of mail services with a mailbox on a mail server. Additionally, the mail client has a mail alias in the /etc/mail/aliases file that points to the location of the mailbox. For task information, refer to How to Set Up a Mail Client in Chapter 13, Mail Services (Tasks).
Mail Gateway
The mail gateway is a machine that handles connections between networks that run different communications protocols or communications between different networks that use the same protocol. For example, a mail gateway might connect a TCP/IP network to a network that runs the Systems Network Architecture (SNA) protocol suite.
The simplest mail gateway to set up is the mail gateway that connects two networks that use the same protocol or mailer. This system handles mail with an address for which sendmail cannot find a recipient in your domain. If a mail gateway exists, sendmail uses the gateway to send and receive mail outside your domain.
You can set up a mail gateway between two networks that use unmatched mailers, as shown in the next figure. To support this configuration, you must customize the sendmail.cf file on the mail gateway system, which can be a difficult and time-consuming process.
Figure 14–1 Gateway Between Different Communications Protocols
Diagram shows two mail gateways that use unmatched mailers.
If you have a machine that provides connections to the Internet, you can configure that machine as the mail gateway. Carefully consider your site's security needs before you configure a mail gateway. You might need to create a firewall gateway between your corporate network and other networks, and set up that gateway as the mail gateway. For task information, refer to How to Set Up a Mail Gateway in Chapter 13, Mail Services (Tasks).
Mail Service Programs and Files
Mail services include many programs and daemons that interact with each other. This section introduces the files, programs, terms, and concepts that are related to administering electronic mail.
Enhancement for vacation Utility
Starting in the Solaris 10 release, the vacation utility has been enhanced to enable a user to specify which incoming messages receive autogenerated replies. With this enhancement the user can avoid sharing confidential or contact information with unknown people. Messages from spammers or unknown people would not receive a reply.
This enhancement works by matching an incoming sender's email address to a list of domains or email addresses in a .vacation.filter file. This file is created by the user and is in the user's home directory. If a domain or email address match is found, a reply is sent. If no match is found, no reply is sent.
The .vacation.filter might contain entries such as these:
company.com
mydomain.com
onefriend@hisisp.com
anotherfriend@herisp.com
Note that each line contains one domain or one email address. Each entry must be on a separate line. For a sender's email address to match with an email address entry, the match must be exact, except for case. Whether the letters in the sender's address are lowercase or uppercase is ignored. For a sender's email address to match with a domain entry, the sender's address must contain the listed domain. For example, both somebody@dept.company.com and someone@company.com would be a match for a domain entry of company.com.
For more information, see the vacation(1) man page.
Contents of the /usr/bin Directory
The following table shows the contents of the /usr/bin directory, which is used for mail services.
Name
Type
Description
aliasadm
File
A program to manipulate the NIS+ aliases map.
mail
File
A user agent.
mailcompat
File
A filter to store mail in SunOS 4.1 mailbox format.
mailq
File
A program that lists the content of the mail queue.
mailstats
File
A program that is used to read mail statistics that are stored in the /etc/mail/statistics file (if present).
mailx
File
A user agent.
mconnect
File
A program that connects to the mailer for address verification and debugging.
praliases
File
A command to “uncompile” the alias database. Refer to the uncompile information that is provided in the man page for praliases(1).
rmail
Symbolic Link
A symbolic link to /usr/bin/mail. Command that is often used to permit only the sending of mail.
vacation
File
A command to set up an automatic reply to mail.
Contents of the /etc/mail Directory
The following table shows the contents of the /etc/mail directory.
Name
Type
Description
Mail.rc
File
Default settings for the mailx user agent.
aliases
File
Mail-forwarding information.
aliases.db
File
Default binary form of mail-forwarding information that is created by running newaliases.
aliases.dir
File
Binary form of mail-forwarding information that is created by running newaliases. Can still be used, but is no longer used by default starting with the Solaris 9 release.
aliases.pag
File
mailx.rc
File
main.cf
Symbolic link
A symbolic link from this sample configuration file for main systems to sendmail.cf is provided for backwards compatibility. This file is not needed in version 8.13 of sendmail.
relay-domains
File
List of all domains for which relaying is allowed. By default, only the local domain is allowed.
sendmail.cf
File
Configuration file for mail routing.
submit.cf
File
New configuration file for the mail submission program (MSP). For more information, refer to submit.cf Configuration File From Version 8.12 of sendmail.
local-host-names
File
Optional file that you can create if the number of aliases for the mail host is too long.
helpfile
File
Help file that is used by the SMTP HELP command.
sendmail.pid
File
File that lists the PID of the listening daemon and is now in /var/run.
statistics
File
sendmail statistics file. If this file is present, sendmail logs the amount of traffic through each mailer. Previously, this file was called sendmail.st.
subsidiary.cf
Symbolic link
A symbolic link from this sample configuration file for subsidiary systems to sendmail.cf is provided for backwards compatibility. This file is not needed in version 8.13 of sendmail.
trusted-users
File
File that lists the users (one user per line) who can be trusted to perform certain mail operations. By default, only root is in this file. Certain mail operations, when performed by untrusted users, result in the following warning, X-Authentication-Warning: header being added to a message.
Contents of the /etc/mail/cf Directory
Within the /etc/mail directory is a subdirectory, cf, that contains all of the necessary files to build a sendmail.cf file. The content of cf is shown in Table 14–9.
Starting in the Solaris 10 release, to support a read-only /usr file system, the content of the /usr/lib/mail directory has been moved to the /etc/mail/cf directory. Note, however, these exceptions. The shell scripts /usr/lib/mail/sh/check-hostname and /usr/lib/mail/sh/check-permissions are now in the /usr/sbin directory. See Other Files Used for Mail Services. For backward compatibility, symbolic links point to each file's new location.
Table 14–9 Contents of the /etc/mail/cf Directory Used for Mail Services
Name
Type
Description
README
File
Describes the configuration files.
cf/main.cf
Symbolic Link
As of the Solaris 10 release, this file name is linked to cf/sendmail.cf. This file used to be the main configuration file.
cf/main.mc
Symbolic Link
As of the Solaris 10 release, this file name is linked to cf/sendmail.mc. This file was the file used to create the main configuration file.
cf/Makefile
File
Provides rules for building new configuration files.
cf/submit.cf
File
Is the configuration file for the mail submission program (MSP), which is used to submit messages.
cf/submit.mc
File
Is the file used to build the submit.cf file. The file defines m4 macros for the mail submission program (MSP).
cf/sendmail.cf
File
Is the main configuration file for sendmail.
cf/sendmail.mc
File
Contains the m4 macros that are used to generate the sendmail.cf file.
cf/subsidiary.cf
Symbolic Link
As of the Solaris 10 release, this file name is linked to cf/sendmail.cf. This file used to be the configuration file for hosts that NFS-mount /var/mail from another host.
cf/subsidiary.mc
Symbolic Link
As of the Solaris 10 release, this file name is linked to cf/sendmail.mc. This file used to contain the m4 macros that were used to generate the subsidiary.cf file.
domain
Directory
Provides site-dependent subdomain descriptions.
domain/generic.m4
File
Is the generic domain file from Berkeley Software Distribution.
domain/solaris-antispam.m4
File
Is the domain file with changes that make sendmail function like the previous Solaris versions of sendmail. However, relaying is disabled completely, sender addresses with no host name are rejected, and unresolvable domains are rejected.
File
Is the default domain file with changes that make sendmail function like the previous Solaris versions of sendmail.
feature
Directory
Contains definitions of specific features for particular hosts. See README for a full description of the features.
m4
Directory
Contains site-independent include files.
mailer
Directory
Contains definitions of mailers, which include local, smtp, and uucp.
main-v7sun.mc
File
Obsolete: as of the Solaris 10 release, this file name is renamed to cf/sendmail.mc.
ostype
Directory
Describes various operating system environments.
ostype/solaris2.m4
File
Defines default local mailer as mail.local.
ostype/solaris2.ml.m4
File
ostype/solaris2.pre5.m4
File
Defines local mailer as mail.
ostype/solaris8.m4
File
Defines local mailer as mail.local (in LMTP mode), enables IPv6, specifies /var/run as the directory for the sendmail.pid file.
subsidiary-v7sun.mc
File
Contents of the /usr/lib Directory
The following table shows the contents of the /usr/lib directory, which is used for mail services.
Table 14–10 Contents of the /usr/lib Directory
Name
Type
Description
mail.local
File
Mailer that delivers mail to mailboxes.
sendmail
File
Routing program, also known as the mail transfer agent.
smrsh
File
Shell program (sendmail restricted shell) that uses the “|program” syntax of sendmail to restrict programs that sendmail can run to those programs listed in the /var/adm/sm.bin directory. Refer to the smrsh(1M) man page for recommendations about what to include in /var/adm/sm.bin. To enable, include this m4 command, FEATURE(`smrsh'), in your mc file.
mail
symbolic link
A symbolic link points to the/etc/mail/cf directory. For more information, refer to Contents of the /etc/mail/cf Directory.
Several other files and directories are used for mail services, as shown in Table 14–11.
Table 14–11 Other Files Used for Mail Services
Name
Type
Description
/etc/default/sendmail
File
Lists the environment variables for the startup script for sendmail.
/etc/shells
File
Lists the valid login shells.
/etc/mail/cf/sh
Directory
Contains shell scripts that are used by the m4 build process and migration aids.
/usr/sbin/check-permissions
File
Checks permissions of :include: aliases and .forward files and their parent directory path for correct permissions.
/usr/sbin/check-hostname
File
Verifies that sendmail is able to determine the fully qualified host name.
/usr/sbin/editmap
File
Queries and edits single records in database maps for sendmail.
/usr/sbin/in.comsat
File
Mail notification daemon.
/usr/sbin/makemap
File
Builds binary forms of keyed maps.
/usr/sbin/newaliases
Symbolic Link
A symbolic link to /usr/lib/sendmail. Used to create the binary form of the alias database. Previously in /usr/bin.
/usr/sbin/syslogd
File
Error message logger, used by sendmail.
/usr/sbin/etrn
File
Perl script for starting the client-side remote mail queue.
/usr/dt/bin/dtmail
File
CDE mail user agent.
/var/mail/mailbox1, /var/mail/mailbox2
File
Mailboxes for delivered mail.
/var/spool/clientmqueue
Directory
Storage for mail that is delivered by the client daemon.
/var/spool/mqueue
Directory
Storage for mail that is delivered by the master daemon.
/var/run/sendmail.pid
File
File that lists the PID of the listening daemon.
Interactions of Mail Programs
Mail services are provided by a combination of the following programs, which interact as shown in the simplified illustration in Figure 14–2.
Figure 14–2 Interactions of Mail Programs
The context describes the graphic.
The following is a description of the interactions of mail programs.
  1. Users send messages by using programs such as mailx. See the man page for mailx(1) for more information.
  2. The message is collected by the program that generated the message, and the message is passed to the sendmail daemon.
  3. The sendmail daemon parses the addresses (divides them into identifiable segments) in the message. The daemon uses information from the configuration file, /etc/mail/sendmail.cf, to determine network name syntax, aliases, forwarding information, and network topology. By using this information, sendmail determines which route a message must follow to get to a recipient.
  4. The sendmail daemon passes the message to the appropriate system.
  5. The /usr/lib/mail.local program on the local system delivers the mail to the mailbox in the /var/mail/username directory of the recipient of the message.
  6. The recipient is notified that mail has arrived and retrieves the mail by using mail, mailx, or a similar program.
sendmail Program
The following list describes some of the capabilities of the sendmail program.
The Solaris operating system uses the sendmail program as a mail router. The following list describes some of its functions.
For more information about the sendmail program, refer to the following topics.
sendmail and Its Rerouting Mechanisms
The sendmail program supports three mechanisms for mail rerouting. The mechanism that you choose depends on the type of change that is involved.
Additionally, the rerouting mechanism that you choose can affect the level of administration that is required. Consider the following options.
  1. One rerouting mechanism is aliasing.
    Aliasing can map names to addresses on a server-wide basis or a name service-wide basis, depending on the type of file that you use.
    Consider the following advantages and disadvantages of name service aliasing.
    • The use of a name service alias file permits mail rerouting changes to be administered from a single source. However, name service aliasing can create lag time when the rerouting change is propagated.
    • Name service administration is usually restricted to a select group of system administrators. A normal user would not administer this file.
    Consider the following advantages and disadvantages of using a server alias file.
    • By using a server alias file, rerouting can be managed by anyone who can become root on the designated server.
    • Server aliasing should create little or no lag time when the rerouting change is propagated.
    • The change only affects the local server, which might be acceptable if most of the mail is sent to one server. However, if you need to propagate this change to many mail servers, use a name service.
    • A normal user would not administer this change.
    For more information, refer to Mail Alias Files in this chapter. For a task map, refer to Administering Mail Alias Files (Task Map) in Chapter 13, Mail Services (Tasks).
  2. The next mechanism is forwarding.
    This mechanism permits users to administer mail rerouting. Local users can reroute their incoming mail to the following.
    • Another mailbox
    • A different mailer
    • Another mail host
    This mechanism is supported through the use of .forward files. For more information about these files, refer to .forward Files in this chapter. For a task map, refer to Administering .forward Files (Task Map) in Chapter 13, Mail Services (Tasks).
  3. The last rerouting mechanism is inclusion.
    This mechanism allows users to maintain alias lists instead of requiring root access. To provide this feature, the root user must create an appropriate entry in the alias file on the server. After this entry is created, the user can reroute mail as necessary. For more information about inclusion, refer to /etc/mail/aliases File in this chapter. For a task map, refer to Administering Mail Alias Files (Task Map) in Chapter 13, Mail Services (Tasks).
    Note –
    Programs that read mail, such as /usr/bin/mailx, can have aliases of their own, which are expanded before the message reaches sendmail. The aliases for sendmail can originate from a number of name service sources, such as local files, NIS, or NIS+. The order of the lookup is determined by the nsswitch.conf file. Refer to the nsswitch.conf(4) man page.
sendmail Features
The sendmail program provides the following features.
sendmail Configuration File
A configuration file controls the way that sendmail performs its functions. The configuration file determines the choice of delivery agents, address rewriting rules, and the format of the mail header. The sendmail program uses the information from the /etc/mail/sendmail.cf file to perform its functions.
The Solaris operating system provides two default configuration files in the /etc/mail directory.
  1. sendmail.cf, a configuration file that is used to run sendmail in daemon mode.
  2. submit.cf, a configuration file that is used to run sendmail in mail-submission program mode, instead of daemon mode. For more information, refer to submit.cf Configuration File From Version 8.12 of sendmail.
When setting up mail clients, mail servers, mail hosts, or mail gateways, consider the following:
The following list describes some configuration parameters that you can change, depending on the requirements of your site.
Mail Alias Files
You can use any of the following files, maps, or tables to maintain aliases.
Your method of maintaining aliases depends on who uses the alias and who needs to be able to change the alias. Each type of alias has unique format requirements.
If you are looking for task information, refer to Administering Mail Alias Files (Task Map) in Chapter 13, Mail Services (Tasks).
.mailrc Aliases
Aliases that are listed in a .mailrc file are accessible only by the user who owns the file. This restriction enables users to establish an alias file that they control and that is usable only by its owner. Aliases in a .mailrc file adhere to the following format.
alias aliasname value value value ...
aliasname is the name that the user uses when sending mail, and value is a valid email address.
If a user establishes a personal alias for scott that does not match the email address for scott in the name service, an error occurs. Mail is routed to the wrong person when people try to reply to mail that is generated by this user. The only workaround is to use any of the other aliasing mechanisms.
Any alias that is established in the /etc/mail/aliases file can be used by any user who knows the name of the alias and the host name of the system that contains the file. Distribution list formats in a local /etc/mail/aliases file adhere to the following format.
aliasname: value,value,value ...
aliasname is the name that the user uses when sending mail to this alias, and value is a valid email address.
If your network is not running a name service, the /etc/mail/aliases file of each system should contain entries for all mail clients. You can either edit the file on each system or edit the file on one system and copy the file to each of the other systems.
The aliases in the /etc/mail/aliases file are stored in text form. When you edit the /etc/mail/aliases file, you need to run the newaliases program. This program recompiles the database and makes the aliases available in binary form to the sendmail program. For task information, refer to How to Set Up a Local Mail Alias File in Chapter 13, Mail Services (Tasks). Otherwise, you can use the Mailing List feature in the Solaris Management Console to administer the mail aliases that are stored in the local /etc files.
You can create aliases for only local names, such as a current host name or no host name. For example, an alias entry for user ignatz who has a mailbox on the system saturn would have the following entry in the /etc/mail/aliases file.
ignatz: ignatz@saturn
You should create an administrative account for each mail server. You create such an account by assigning a mailbox on the mail server to root and by adding an entry for root to the /etc/mail/aliases file. For example, if the system saturn is a mailbox server, add the entry root: sysadmin@saturn to the /etc/mail/aliases file.
Normally, only the root user can edit this file. However, when you use the Solaris Management Console, all users in group 14, which is the sysadmin group, can change the local file. Another option is to create the following entry.
aliasname: :include:/path/aliasfile
aliasname is the name that the user uses when sending mail, and /path/aliasfile is the full path to the file that contains the alias list. The alias file should include email entries, one entry on each line, and no other notations.
user1@host1
user2@host2
You can define additional mail files in /etc/mail/aliases to keep a log or a backup copy. The following entry stores all mail that is sent to aliasname in filename.
aliasname: /home/backup/filename
You can also route the mail to another process. The following example stores a copy of the mail message in filename and prints a copy.
aliasname: "|tee -a /home/backup/filename |lp"
NIS aliases Map
All users in a local domain can use the entries that are in the NIS aliases map. The reason is that the sendmail program can use the NIS aliases map instead of the local /etc/mail/aliases files to determine mailing addresses. For more information, refer to the nsswitch.conf(4) man page.
Aliases in the NIS aliases map adhere to the following format.
The NIS aliases map should contain entries for all mail clients. In general, only the root user on the NIS master can change these entries. This type of alias might not be a good choice for aliases that are constantly changing. However, such aliases can be useful if the aliases point to another alias file, as in the following syntax example.
aliasname: aliasname@host
aliasname is the name that the user uses when sending mail, and host is the host name for the server that contains an /etc/mail/alias file.
For task information, refer to How to Set Up an NIS mail.aliases Map in Chapter 13, Mail Services (Tasks).
NIS+ mail_aliases Table
The NIS+ mail_aliases table contains the names by which a system or person is known in the local domain. The sendmail program can use the NIS+ mail_aliases table, instead of the local /etc/mail/aliases files, to determine mailing addresses. Refer to the aliasadm(1M) and nsswitch.conf(4) man pages for more information.
Aliases in the NIS+ mail_aliases table adhere to the following format:
alias: expansion # ["options" # "comments"]
Table 14–12 describes the four columns that are in an NIS+ mail_aliases table.
Table 14–12 Columns in the NIS+ mail_aliases Table
Column
Description
alias
The name of the alias
expansion
The value of the alias or a list of aliases as it would appear in a sendmail /etc/mail/aliases file
options
The column that is reserved for future use
comments
The column for comments about an individual alias
The NIS+ mail_aliases table should contain entries for all mail clients. You can list, create, modify, and delete entries in the NIS+ aliases table with the aliasadm command. To use the aliasadm command, you must be a member of the NIS+ group that owns the aliases table. For task information, refer to Administering Mail Alias Files (Task Map) in Chapter 13, Mail Services (Tasks). Alternately, you can use the Solaris Management Console to administer the NIS+ mail aliases.
Note –
If you are creating a new NIS+ aliases table, you must initialize the table before you create the entries. If the table exists, no initialization is needed.
.forward Files
Users can create a .forward file in their home directories that sendmail, along with other programs, can use to redirect mail or send mail. Refer to the following topics.
Situations to Avoid
The following list describes some situations that you can avoid or easily fix.
Controls for .forward files
For the .forward files to be an effective part of mail delivery, ensure that the following controls (mostly permissions settings) are correctly applied.
.forward.hostname File
You can create a .forward.hostname file to redirect mail that is sent to a specific host. For example, if a user's alias has changed from sandy@phoenix.example.com to sandy@example.com, place a .forward.phoenix file in the home directory for sandy.
% cat .forward.phoenix
sandy@example.com
"|/usr/bin/vacation sandy"
% cat .vacation.msg
Subject: my alias has changed
My alias has changed to sandy@example.com.
Please use this alias in the future.
The mail that I just received from you
has been forwarded to my new address.
Sandy
In this example, mail can be forwarded to the correct place while the sender is notified of the alias change. Because the vacation program permits only one message file, you can forward only one message at a time. However, if the message is not host specific, one vacation message file can be used by .forward files for many hosts.
.forward+detail File
Another extension to the forwarding mechanism is the .forward+detail file. The detail string can be any sequence of characters except operator characters. The operator characters are .:%&!^[]+. By using this type of file, you can determine if someone else is using your email address without your knowledge. For instance, if a user tells someone to use the email address sandy+test1@example.com, the user would be able to identify any future mail that was delivered to this alias. By default, any mail that is sent to the sandy+test1@example.com alias is checked against the alias and the .forward+detail files. If no matches are made, the mail falls back to delivery to sandy@example.com, but the user is able to see a change in the To: mail header.
/etc/default/sendmail File
This file is used to store startup options for sendmail so that the options are not removed when a host is upgraded. The following variables can be used.
CLIENTOPTIONS=“string”
Selects additional options to be used with the client daemon, which looks in the client-only queue (/var/spool/clientmqueue) and acts as a client queue runner. No syntax checking is done, so be careful when making changes to this variable.
CLIENTQUEUEINTERVAL=#
Similar to the QUEUEINTERVAL option, CLIENTQUEUEINTERVAL sets the time interval for mail queue runs. However, the CLIENTQUEUEINTERVAL option controls the functions of the client daemon, rather than the functions of the master daemon. Typically, the master daemon is able to deliver all messages to the SMTP port. However, if the message load is too high or the master daemon is not running, then messages go into the client-only queue, /var/spool/clientmqueue. The client daemon, which checks in the client-only queue, then acts as a client queue processor.
ETRN_HOSTS=“string”
Enables an SMTP client and server to interact immediately without waiting for the queue run intervals, which are periodic. The server can immediately deliver the portion of its queue that goes to the specified hosts. For more information, refer to the etrn(1M) man page.
MODE=-bd
Selects the mode to start sendmail with. Use the -bd option or leave it undefined.
OPTIONS=string
Selects additional options to be used with the master daemon. No syntax checking is done, so be careful when making changes to this variable.
QUEUEINTERVAL=#
Sets the interval for mail queue runs on the master daemon. # can be a positive integer that is followed by either s for seconds, m for minutes, h for hours, d for days, or w for weeks. The syntax is checked before sendmail is started. If the interval is negative or if the entry does not end with an appropriate letter, the interval is ignored and sendmail starts with a queue interval of 15 minutes.
QUEUEOPTIONS=p
Enables one persistent queue runner that sleeps between queue run intervals, instead of a new queue runner for each queue run interval. You can set this option to p, which is the only setting available. Otherwise, this option is not set.
Mail Addresses and Mail Routing
The path that a mail message follows during delivery depends on the setup of the client system and the topology of the mail domain. Each additional level of mail hosts or mail domains can add another alias resolution, but the routing process is basically the same on most hosts.
You can set up a client system to receive mail locally. Receiving mail locally is known as running sendmail in local mode. Local mode is the default for all mail servers and some clients. On a mail server or a mail client in local mode, a mail message is routed the following way.
Note –
The following example assumes that you are using the default rule set in the sendmail.cf file.
  1. Expand the mail alias, if possible, and restart the local routing process.
    The mail address is expanded by checking for the mail alias in the name service and substituting the new value, if a new value is found. This new alias is then checked again.
  2. If the mail is local, deliver the mail to /usr/lib/mail.local.
    The mail is delivered to a local mailbox.
  3. If the mail address includes a host in this mail domain, deliver the mail to that host.
  4. If the address does not include a host in this domain, forward the mail to the mail host.
    The mail host uses the same routing process as the mail server. However, the mail host can receive mail that is addressed to the domain name as well as to the host name.
This section describes domain names as they apply to sendmail and name services. Furthermore, this section describes the rules for effective use of name services, and the specific interactions of sendmail with name services. For details, refer to the following topics.
If you are looking for related task information, refer to How to Use DNS With sendmail or Administering Mail Alias Files (Task Map) in Chapter 13, Mail Services (Tasks).
sendmail.cf and Mail Domains
The standard sendmail.cf file uses mail domains to determine whether mail is delivered directly or through a mail host. Intradomain mail is delivered through a direct SMTP connection, while interdomain mail is forwarded to a mail host.
In a secure network, only a few selected hosts are authorized to generate packets that are targeted to external destinations. Even if a host has the IP address of the remote host that is external to the mail domain, the establishment of an SMTP connection is not guaranteed. The standard sendmail.cf assumes the following.
With these assumptions, the mail host is responsible for delivering or forwarding interdomain mail.
sendmail and Name Services
sendmail imposes various requirements on name services. To improve your understanding of these requirements, this section first describes the relationship of mail domains to name service domains. Then the section describes the various requirements. Refer to the following.
Mail Domains and Name Service Domains
The mail domain name must be a suffix of the name service domain. For example, if the domain name of the name service is A.B.C.D, the mail domain name could be one of the following.
When first established, the mail domain name is often identical to the name service domain. As the network grows, the name service domain can be divided into smaller pieces to make the name service more manageable. However, the mail domain often remains undivided to provide consistent aliasing.
Requirements for Name Services
This section describes the requirements that sendmail imposes on name services.
A host table or map in a name service must be set up to support three types of gethostbyname() queries.
Two additional rules about the host name service need to be followed to establish efficient sendmail services within a name service.
For more information about the gethostbyname() function, refer to the gethostbyname(3NSL) man page.
Interactions of NIS and sendmail
The following list describes the interactions of sendmail and NIS and provides some guidance.
Interactions of sendmail With NIS and DNS
The following list describes the interactions of sendmail with NIS and DNS and provides some guidance.
For task information, refer to How to Use DNS With sendmail and Administering Mail Alias Files (Task Map) in Chapter 13, Mail Services (Tasks).
Interactions of NIS+ and sendmail
The following list describes the interactions of sendmail with NIS+ and provides some guidance.
Interactions of sendmail With NIS+ and DNS
The following list describes the interactions of sendmail with NIS+ and DNS and provides some guidance.
For task information, refer to Administering Mail Alias Files (Task Map) and How to Use DNS With sendmail in Chapter 13, Mail Services (Tasks).
Changes in Version 8.13 of sendmail
Although this new version of sendmail provides many new features, the FallBackSmartHost option is the most significant addition. Because of this option you no longer need to use main.cf and subsidiary.cf. The main.cf file was used in environments that supported MX records. The subsidiary.cf file was used in environments without a fully operative DNS. In such environments a smart host was used instead of MX records. The FallBackSmartHost option provides unified configuration. It operates like an MX record of last possible preference for all environments. To ensure that mail gets delivered to clients, this option, if enabled, provides a well-connected (or smart) host that serves as a backup (or failover) for MX records that fail.
For more information about version 8.13, see the following sections:
Additionally, starting in the Solaris 10 1/06 release, SMTP can run with Transport Layer Security (TLS). See the following description.
Support for Running SMTP With TLS in Version 8.13 of sendmail
Communications between SMTP servers and clients are not usually controlled or trusted on either end. This lack of security might allow a third party to monitor and even alter a communication between a server and a client. Starting in the Solaris 10 1/06 release, SMTP can use Transport Layer Security (TLS) in version 8.13 of sendmail to resolve this problem. This extended service to SMTP servers and clients provides the following:
Note –
The implementation of TLS is based on the Secure Sockets Layer (SSL) protocol.
STARTTLS is the SMTP keyword that initiates a secure SMTP connection by using TLS. This secure connection might be between two servers or between a server and a client. A secure connection is defined as follows:
When the client issues the STARTTLS command, the server responds with one of the following:
The 220 response requires the client to start the TLS negotiation. The 501 response notes that the client incorrectly issued the STARTTLS command. STARTTLS is issued with no parameters. The 454 response necessitates that the client apply rule set values to determine whether to accept or maintain the connection.
Note that to maintain the Internet's SMTP infrastructure, publicly used servers must not require a TLS negotiation. However, a server that is used privately might require the client to perform a TLS negotiation. In such instances, the server returns this response:
530 Must issue a STARTTLS command first
The 530 response instructs the client to issue the STARTTLS command to establish a connection.
The server or client can refuse a connection if the level of authentication and privacy is not satisfactory. Alternately, because most SMTP connections are not secure, the server and client might maintain an unsecure connection. Whether to maintain or refuse a connection is determined by the configuration of the server and the client.
Support for running SMTP with TLS is not enabled by default. TLS is enabled when the SMTP client issues the STARTTLS command. Before the SMTP client can issue this command, you must set up the certificates that enable sendmail to use TLS. See How to Set SMTP to Use TLS. Note that this procedure includes defining new configuration file options and rebuilding your sendmail.cf file.
Configuration File Options for Running SMTP With TLS
The following table describes the configuration file options that are used to run SMTP with TLS. If you declare any of these options, use one of the following syntaxes:
Table 14–13 Configuration File Options for Running SMTP With TLS
Option
Description
CACertFile
m4 name: confCACERT
Argument: filename
Default value: undefined
Identifies the file that contains one CA certificate.
CACertPath
m4 name: confCACERT_PATH
Argument: path
Identifies the path to the directory that contains certificates of CAs.
ClientCertFile
m4 name: confCLIENT_CERT
Argument: filename
Identifies the file that contains the certificate of the client. Note that this certificate is used when sendmail acts as a client.
ClientKeyFile
m4 name: confCLIENT_KEY
Argument: filename
Identifies the file that contains the private key that belongs to the client certificate.
CRLFile
m4 name: confCRL
Argument: filename
Identifies the file that contains the certificate revocation status, which is used for X.509v3 authentication.
DHParameters
m4 name: confDH_PARAMETERS
Argument: filename
Identifies the file that contains the Diffie-Hellman (DH) parameters.
RandFile
m4 name: confRAND_FILE
Argument: file:filename or egd:UNIX socket
Uses the file: prefix to identify the file that contains random data or uses the egd: prefix to identify the UNIX socket. Note that because the Solaris OS supports the random number generator device, this option does not need to be specified. See the random(7D) man page.
ServerCertFile
m4 name: confSERVER_CERT
Argument: filename
Identifies the file that contains the server's certificate. This certificate is used when sendmail acts as a server.
Timeout.starttls
m4 name: confTO_STARTTLS
Argument: amount of time
Default value: 1h
Sets the amount of time the SMTP client waits for a response to the STARTTLS command.
TLSSrvOptions
m4 name: confTLS_SRV_OPTIONS
Argument: V
Determines whether the server asks for a certificate from the client. If this option is set to V, no client verification is performed.
For sendmail to support SMTP's use of TLS, the following options must be defined:
Other options are not required.
Macros for Running SMTP With TLS
The following table describes the macros that are used by the STARTTLS command.
Table 14–14 Macros for Running SMTP With TLS
Macro
Description
${cert_issuer}
Holds the distinguished name (DN) of the certification authority (CA), which is the certificate issuer.
${cert_subject}
Holds the DN of the certificate that is called the cert subject.
${cn_issuer}
Holds the common name (CN) of the CA, which is the cert issuer.
${cn_subject}
Holds the CN of the certificate that is called the cert subject.
${tls_version}
Holds the version of TLS that is used for the connection.
${cipher}
Holds a set of cryptographic algorithms (known as a cipher suite) that is used for the connection.
${cipher_bits}
Holds in bits the key length of the symmetric encryption algorithm that is used for the connection.
${verify}
Holds the result of the verification of the certificate that was presented. Possible values are as follows:
  • OK – The verification succeeded.
  • NO – No certificate was presented.
  • NOT – No certificate was requested.
  • FAIL – The certificate that was presented could not be verified.
  • NONE – STARTTLS has not been performed.
  • TEMP – Temporary error occurred.
  • PROTOCOL – SMTP error occurred.
  • SOFTWARE – STARTTLS handshake failed.
${server_name}
Holds the name of the server with the current outgoing SMTP connection.
${server_addr}
Holds the address of the server with the current outgoing SMTP connection.
Rule Sets for Running SMTP With TLS
The following table describes rule sets that determine whether an SMTP connection that uses TLS should be accepted, continued, or refused.
Table 14–15 Rule Sets for Running SMTP With TLS
Rule Set
Description
tls_server
Acting as a client, sendmail uses this rule set to determine whether the server is currently supported by TLS.
tls_client
Acting as a server, sendmail uses this rule set to determine whether the client is currently supported by TLS.
tls_rcpt
This rule set requires verification of the recipient's MTA. This recipient restriction makes attacks such as DNS spoofing impossible.
TLS_connection
This rule set checks the requirement that is specified by the RHS of the access map against the actual parameters of the current TLS connection.
try_tls
sendmail uses this rule set to determine the feasibility of using STARTTLS when connecting to another MTA. If the MTA cannot properly implement STARTTLS, then STARTTLS is not used.
For more information, see http://www.sendmail.org/m4/starttls.html.
Security Considerations Related to Running SMTP With TLS
As a standard mail protocol that defines mailers that run over the Internet, SMTP is not an end-to-end mechanism. Because of this protocol limitation, TLS security through SMTP does not include mail user agents. Mail user agents act as an interface between users and a mail transfer agent such as sendmail.
Also, mail might be routed through multiple servers. For complete SMTP security the entire chain of SMTP connections must have TLS support.
Finally, the level of negotiated authentication and privacy between each pair of servers or a client and server pair must be considered. For more information, see Authentication Services in System Administration Guide: Security Services.
Additional Command-Line Options in Version 8.13 of sendmail
The following table describes additional command-line options that are available in version 8.13 of sendmail. Other command-line options are described in the sendmail(1M) man page.
Table 14–16 Command-Line Options Available in Version 8.13 of sendmail
Option
Description
-D logfile
Sends debugging output to the indicated logfile, instead of including this information with the standard output.
-q[!]Qsubstr
Specifies the processing of quarantined jobs that have this substr, which is a substring of the quarantine reason. See the description of the -Qreason option. If ! is added, this option processes quarantined jobs that do not have this substr.
-Qreason
Quarantines a normal queue item with this reason. If no reason is given, the quarantined queue item is unquarantined. This option works with the -q[!]Qsubstr option. The substr is a portion (or substring) of the reason.
Additional and Revised Configuration File Options in Version 8.13 of sendmail
The following table describes the added and revised configuration file options. If you declare any of these options, use one of the following syntaxes.
O OptionName=argument          # for the configuration file
-O OptionName=argument         # for the command line
define(`m4Name',argument)     # for m4 configuration
Table 14–17 Configuration File Options Available in Version 8.13 of sendmail
Option
Description
ConnectionRateWindowSize
m4 name: confCONNECTION_RATE_WINDOW_SIZE
Argument: number
Default value: 60
Sets the number of seconds for incoming connections to be maintained.
FallBackSmartHost
m4 name: confFALLBACK_SMARTHOST
Argument: hostname
To ensure that mail gets delivered to the clients, this option provides a well-connected host that serves as a backup (or failover) for MX records that fail.
InputMailFilters
m4 name: confINPUT_MAIL_FILTERS
Argument: filename
Lists the input mail filters for the sendmail daemon.
PidFile
m4 name: confPID_FILE
Argument: filename
Default value: /var/run/sendmail.pid
As in previous releases, the file name is macro-expanded before it is opened. Additionally, in version 8.13, the file is unlinked when sendmail exits.
QueueSortOrder
m4 name: confQUEUE_SORT_ORDER
Added argument: none
In version 8.13 none is used to specify no sorting order.
RejectLogInterval
m4 name: confREJECT_LOG_INTERVAL
Argument: period-of-time
Default value: 3h, which represents three hours.
When a daemon connection is refused for the period-of-time specified, the information is logged.
SuperSafe
m4 name: confSAFE_QUEUE
Short name: s
Added argument: postmilter
Default value: true
If postmilter is set, sendmail defers synchronizing the queue file until all milters have signaled acceptance of the message. For this argument to be useful, sendmail must be running as an SMTP server. Otherwise, postmilter operates as if you are using the true argument.
Additional and Revised FEATURE() Declarations in Version 8.13 of sendmail
The following table describes the added and revised FEATURE() declarations. This m4 macro uses the following syntax.
FEATURE(`name', `argument')
Table 14–18 FEATURE() Declarations Available in Version 8.13 of sendmail
Name of FEATURE()
Description
conncontrol
Works with the access_db rule set to check the number of incoming SMTP connections. For details, see /etc/mail/cf/README.
greet_pause
Adds the greet_pause rule set, which enables open proxy and SMTP slamming protection. For details, see /etc/mail/cf/README.
local_lmtp
The default argument continues to be mail.local, which is the LMTP-capable mailer in this Solaris release. However, in version 8.13, if a different LMTP-capable mailer is used, its path name can be specified as a second parameter and the arguments that are passed to the second parameter can be specified in the third parameter. For example:
FEATURE(`local_lmtp', `/usr/local/bin/lmtp', `lmtp')
mtamark
Provides experimental support for “Marking Mail Transfer Agents in Reverse DNS with TXT RRs” (MTAMark). For details, see /etc/mail/cf/README.
ratecontrol
Works with the access_db rule set to control connection rates for hosts. For details, see /etc/mail/cf/README.
use_client_ptr
If this FEATURE() is enabled, the rule set check_relay overrides its first argument with this argument, $&{client_ptr}.
Changes From Version 8.12 of sendmail
This section contains information about the following topics.
Support for TCP Wrappers From Version 8.12 of sendmail
TCP wrappers provide a way of implementing access controls by checking the address of a host requesting a particular network service against an access control list (ACL). Requests are granted or denied, accordingly. Besides providing this access control mechanism, TCP wrappers also log host requests for network services, which is a useful monitoring function. Examples of network services that might be placed under access control include rlogind, telnetd, and ftpd.
Starting with version 8.12, sendmail enables the use of TCP wrappers. This check does not bypass other security measures. By enabling TCP wrappers in sendmail, a check has been added to validate the source of a network request before the request is granted. See the hosts_access(4) man page.
Note –
Support for TCP wrappers in inetd(1M) and sshd(1M) started with the Solaris 9 release.
For information about ACLs, see Using Access Control Lists to Protect UFS Files in System Administration Guide: Security Services.
Starting with version 8.12, sendmail includes an additional configuration file, /etc/mail/submit.cf. This file, submit.cf, is used to run sendmail in mail-submission program mode instead of daemon mode. Mail-submission program mode, unlike daemon mode, does not require root privilege, so this new paradigm provides better security.
See the following list of functions for submit.cf:
Note the following:
Functions That Distinguish sendmail.cf From submit.cf
The sendmail.cf configuration file is for the daemon mode. When using this file, sendmail is acting as a mail transfer agent (MTA), which is started by root.
/usr/lib/sendmail -L sm-mta -bd -q1h
See the following list of other distinguishing functions for sendmail.cf:
Functional Changes From Version 8.12 of sendmail
With the addition of submit.cf, the following functional changes have occurred:
Additional or Deprecated Command-Line Options From Version 8.12 of sendmail
The following table describes additional or deprecated command-line options for sendmail. Other command-line options are described in the sendmail(1M) man page.
Table 14–19 Additional or Deprecated Command-Line Options From Version 8.12 of sendmail
Option
Description
-Ac
Indicates that you want to use the configuration file, submit.cf, even if the operation mode does not indicate an initial mail submission. For more information about submit.cf, refer to submit.cf Configuration File From Version 8.12 of sendmail.
-Am
Indicates that you want to use the configuration file, sendmail.cf, even if the operation mode indicates an initial mail submission. For more information, refer to submit.cf Configuration File From Version 8.12 of sendmail.
-bP
Indicates that you are printing the number of entries in each queue.
-G
Indicates that the message that is being submitted from the command line is for relaying, not for initial submission. The message is rejected if the addresses are not fully qualified. No canonicalization is done. As is noted in the Release Notes that are part of the sendmail distribution on ftp://ftp.sendmail.org, improperly formed messages might be rejected in future releases.
-L tag
Sets the identifier that is used for syslog messages to the supplied tag.
-q[!]I substring
Processes only jobs that contain this substring of one of the recipients. When ! is added, the option processes only jobs that do not have this substring of one of the recipients.
-q[!]R substring
Processes only jobs that contain this substring of the queue ID. When ! is added, the option processes only jobs that do not have this substring of the queue ID.
-q[!]S substring
Processes only jobs that contain this substring of the sender. When ! is added, the option processes only jobs that do not have this substring of the sender.
-qf
Processes saved messages in the queue once, without using the fork system call, and runs the process in the foreground. Refer to the fork(2) man page.
-qGname
Processes only the messages in the name queue group.
-qptime
Processes saved messages in the queue at a specific interval of time with a single child that is forked for each queue. The child sleeps between queue runs. This new option is similar to the -qtime, which periodically forks a child to process the queue.
-U
As is noted in the Release Notes that are part of the sendmail distribution on ftp://ftp.sendmail.org, this option is not available as of version 8.12. Mail user agents should use the -G argument.
Additional Arguments for the PidFile and ProcessTitlePrefix Options From Version 8.12 of sendmail
The following table describes additional macro-processed arguments for the PidFile and ProcessTitlePrefix options. For more information about these options, see the sendmail(1M) man page.
Table 14–20 Arguments for the PidFile and ProcessTitlePrefix Options
Macro
Description
${daemon_addr}
Provides daemon address (for example, 0.0.0.0)
${daemon_family}
Provides daemon family (for example, inet, and inet6)
${daemon_info}
Provides daemon information (for example, SMTP+queueing@00:30:00)
${daemon_name}
Provides daemon name (for example, MSA)
${daemon_port}
Provides daemon port (for example, 25)
${queue_interval}
Provides queue run interval (for example, 00:30:00)
Additional Defined Macros From Version 8.12 of sendmail
The following table describes additional macros that are reserved for use by the sendmail program. The macros' values are assigned internally. For more information, refer to the sendmail(1M) man page.
Table 14–21 Additional Defined Macros for sendmail
Macro
Description
${addr_type}
Identifies the current address as an envelope sender or a recipient address.
${client_resolve}
Holds the result of the resolve call for ${client_name}: OK, FAIL, FORGED, or TEMP.
${deliveryMode}
Specifies the current delivery mode sendmail is using instead of the value of the DeliveryMode option.
${dsn_notify}, ${dsn_envid}, ${dsn_ret}
Holds the corresponding DSN parameter values.
${if_addr}
Provides the interface's address for the incoming connection if the interface does not belong to the loopback net. This macro is especially useful for virtual hosting.
${if_addr_out}, ${if_name_out}, ${if_family_out}
Avoids the reuse of ${if_addr}. Holds the following values respectively:
The address of the interface for the outgoing connection
The host name of the interface for the outgoing connection
The family of the interface for the outgoing connection
${if_name}
Provides the interface's host name for the incoming connection and is especially useful for virtual hosting.
${load_avg}
Checks and reports the current average number of jobs in the run queue.
${msg_size}
Holds the value of the message size (SIZE=parameter) in an ESMTP dialogue before the message has been collected. Thereafter, the macro holds the message size as computed by sendmail and is used in check_compat. For information about check_compat, refer to Table 14–25.
${nrcpts}
Holds the number of validated recipients.
${ntries}
Holds the number of delivery attempts.
${rcpt_mailer}, ${rcpt_host}, ${rcpt_addr}, ${mail_mailer}, ${mail_host}, ${mail_addr}
Holds the results of parsing the RCPT and MAIL arguments, which is the resolved right-hand side (RHS) triplet from the mail delivery agent ($#mailer), the host ($@host), and the user ($:addr).
Additional Macros From Version 8.12 of sendmail
In this section, you can find a table that describes the additional macros that are used to build the sendmail configuration file.
Table 14–22 Additional Macros Used to Build the sendmail Configuration File
Macro
Description
LOCAL_MAILER_EOL
Overrides the default end-of-line string for the local mailer.
LOCAL_MAILER_FLAGS
Adds Return-Path: header by default.
MAIL_SETTINGS_DIR
Contains the path (including the trailing slash) for the mail settings directory.
MODIFY_MAILER_FLAGS
Improves the *_MAILER_FLAGS. This macro sets, adds, or deletes flags.
RELAY_MAILER_FLAGS
Defines additional flags for the relay mailer.
Additional MAX Macros From Version 8.12 of sendmail
Use the following macros to configure the maximum number of commands that can be received before sendmail slows its delivery. You can set these MAX macros at compile time. The maximum values in the following table also represent the current default values.
Table 14–23 Additional MAX Macros
Macro
Maximum Value
Commands Checked by Each Macro
MAXBADCOMMANDS
25
Unknown commands
MAXNOOPCOMMANDS
20
NOOP, VERB, ONEX, XUSR
MAXHELOCOMMANDS
3
HELO, EHLO
MAXVRFYCOMMANDS
6
VRFY, EXPN
MAXETRNCOMMANDS
8
ETRN
Note –
You can disable a macro's check by setting the macro's value to zero.
Additional and Revised m4 Configuration Macros From Version 8.12 of sendmail
This section contains a table of additional and revised m4 configuration macros for sendmail. Use the following syntax to declare these macros.
symbolic-name(`value')
If you need to build a new sendmail.cf file, refer to Changing the sendmail Configuration in Chapter 13, Mail Services (Tasks).
Table 14–24 Additional and Revised m4 Configuration Macros for sendmail
m4 Macro
Description
FEATURE()
For details, refer to Changes to the FEATURE() Declaration From Version 8.12 of sendmail.
LOCAL_DOMAIN()
This macro adds entries to class w ($=w).
MASQUERADE_EXCEPTION()
A new macro that defines hosts or subdomains that cannot be masqueraded.
SMART_HOST()
This macro can now be used for bracketed addresses, such as user@[host].
VIRTUSER_DOMAIN() or VIRTUSER_DOMAIN_FILE()
When these macros are used, include $={VirtHost} in $=R. As a reminder, $=R is the set of host names that are allowed to relay.
Refer to the following tables for information about the specific changes to the FEATURE() declarations.
To use the new and revised FEATURE names, use the following syntax.
Table 14–25 Additional and Revised FEATURE() Declarations
Name of FEATURE()
Description
compat_check
Argument: Refer to the example in the following paragraph.
This new FEATURE() enables you to look for a key in the access map that consists of the sender address and the recipient address. This FEATURE() is delimited by the following string, <@>. sender@sdomain<@>recipient@rdomain is an example.
delay_checks
Argument: friend, which enables a spam-friend test, or hater, which enables a spam-hater test.
A new FEATURE() that delays all checks. By using FEATURE(`delay_checks'), the rule sets check_mail and check_relay are not called when a client connects or issues a MAIL command respectively. Instead, these rule sets are called by the check_rcpt rule set. For details, refer to the /etc/mail/cf/README file.
dnsbl
Argument: This FEATURE()accepts a maximum of two arguments:
  • DNS server name
  • Rejection message
A new FEATURE() that you can include multiple times to check the return values for DNS lookups. Note that this FEATURE() enables you to specify the behavior of temporary lookup failures.
enhdnsbl
Argument: domain name.
A new FEATURE() that is an enhanced version of dnsbl, which enables you to check the return values for DNS lookups. For more information, refer to /etc/mail/cf/README.
generics_entire_domain
Argument: None.
A new FEATURE() that you can also use to apply genericstable to subdomains of $=G.
ldap_routing
Argument: For details, refer to the “Release Notes” in http://www.sendmail.org.
A new FEATURE() that implements LDAP address routing.
local_lmtp
Argument: Path name of an LMTP-capable mailer. The default is mail.local, which is LMTP capable in this Solaris release.
A FEATURE() that now sets the delivery status notification (DSN) diagnostic-code type for the local mailer to the proper value of SMTP.
local_no_masquerade
Argument: None.
A new FEATURE() that you can use to avoid masquerading for the local mailer.
lookupdotdomain
Argument: None.
A new FEATURE() that you can also use to look up the .domain in the access map.
nocanonify
Argument: canonify_hosts or nothing.
A FEATURE() that now includes the following features.
Enables a list of domains, as specified by CANONIFY_DOMAIN or CANONIFY_DOMAIN_FILE, to be passed to the $[ and $] operators for canonification.
Enables addresses that have only a host name, such as <user@host>, to be canonified, if canonify_hosts is specified as its parameter.
Adds a trailing dot to addresses with more than one component.
no_default_msa
Argument: None.
A new FEATURE() that turns off sendmail's default setting from m4–generated configuration files to “listen” on several different ports, an implementation of RFC 2476.
nouucp
Argument: reject, which does not allow the ! token, or nospecial, which does allow the ! token.
A FEATURE() that determines whether to allow the ! token in the local part of an address.
nullclient
Argument: None.
A FEATURE() that now provides the full rule sets of a normal configuration, allowing antispam checks to be performed.
preserve_local_plus_detail
Argument: None.
A new FEATURE() that enables you to preserve the +detail portion of the address when sendmail passes the address to the local delivery agent.
preserve_luser_host
Argument: None.
A new FEATURE() that enables you to preserve the name of the recipient host, if LUSER_RELAY is used.
queuegroup
Argument: None.
A new FEATURE() that enables you to select a queue group that is based on the full email address or on the domain of the recipient.
relay_mail_from
Argument: The domain is an optional argument.
A new FEATURE() that allows relaying if the mail sender is listed as a RELAY in the access map and is tagged with the From: header line. If the optional domain argument is given, the domain portion of the mail sender is also checked.
virtuser_entire_domain
Argument: None.
A FEATURE() that you can now use to apply $={VirtHost}, a new class for matching virtusertable entries that can be populated by VIRTUSER_DOMAIN or VIRTUSER_DOMAIN_FILE.
FEATURE(`virtuser_entire_domain') can also apply the class $={VirtHost} to entire subdomains.
The following FEATURE() declarations are no longer supported.
Table 14–26 Unsupported FEATURE() Declarations
Name of FEATURE()
Replacement
rbl
FEATURE(`dnsbl') and FEATURE(`enhdnsbl') replace this FEATURE(), which has been removed.
remote_mode
MASQUERADE_AS(`$S') replaces FEATURE(`remote_mode') in /etc/mail/cf/subsidiary.mc. $S is the SMART_HOST value in sendmail.cf.
sun_reverse_alias_files
FEATURE(`genericstable').
sun_reverse_alias_nis
sun_reverse_alias_nisplus
Changes to the MAILER() Declaration From Version 8.12 of sendmail
The MAILER() declaration specifies support for delivery agents. To declare a delivery agent, use the following syntax.
MAILER(`symbolic-name')
Note the following changes.
For more information about mailers, refer to Mailers and sendmail. If you need to build a new sendmail.cf file, refer to Changing the sendmail Configuration in Chapter 13, Mail Services (Tasks).
Additional Delivery Agent Flags From Version 8.12 of sendmail
The following table describes additional delivery agent flags, which by default are not set. These single-character flags are Boolean. You can set or unset a flag by including or excluding it in the F= statement of your configuration file, as shown in the following example.
Mlocal,    P=/usr/lib/mail.local, F=lsDFMAw5:/|@qSXfmnz9, S=10/30, R=20/40,
Mprog,     P=/bin/sh, F=lsDFMoqeu9, S=10/30, R=20/40, D=$z:/,
Msmtp,     P=[IPC], F=mDFMuX, S=11/31, R=21, E=\r\n, L=990,
Mesmtp,    P=[IPC], F=mDFMuXa, S=11/31, R=21, E=\r\n, L=990,
Msmtp8,    P=[IPC], F=mDFMuX8, S=11/31, R=21, E=\r\n, L=990,
Mrelay,    P=[IPC], F=mDFMuXa8, S=11/31, R=61, E=\r\n, L=2040,
Table 14–27 Additional Mailer Flags
Flag
Description
Mailers that use this flag do not attempt delivery to the initial recipient of a message or to queue runs unless the queued message is selected by using an ETRN request or one of the following queue options: -qI, -qR, or -qS.
1
This flag disables the ability of the mailer to send null characters (for example, \0).
2
This flag disables the use of ESMTP and requires that SMTP be used instead.
6
This flag enables mailers to strip headers to 7 bit.
Additional Equates for Delivery Agents From Version 8.12 of sendmail
The following table describes additional equates that you can use with the M delivery-agent definition command. The following syntax shows you how to append new equates or new arguments to the equates that already exist in the configuration file.
Magent-name, equate, equate, ...
The following example includes the new W= equate. This equate specifies the maximum time to wait for the mailer to return after all data has been sent.
Msmtp, P=[IPC], F=mDFMuX, S=11/31, R=21, E=\r\n, L=990, W=2m
When you modify the definition of a value for m4 configuration, use the syntax that is provided in the following example.
define(`SMTP_MAILER_MAXMSGS', `1000')
The preceding example places a limit of 1000 on the number of messages that are delivered per connection on an smtp mailer.
Note –
Typically, you modify the equate definitions in the mailer directory only when you fine-tune.
Table 14–28 Additional Equates for Delivery Agents
Equate
Description
Argument: Path to a directory
Specifies a directory to apply chroot() to before the mailer program is executed
m=
Argument: Any of the following m4 values that have previously been defined with the define() routine
    SMTP_MAILER_MAXMSGS, for the smtp mailer
    LOCAL_MAILER_MAXMSGS, for the local mailer
    RELAY_MAILER_MAXMSGS, for the relay mailer
Limits the number of messages that are delivered per connection on an smtp, local, or relay mailer
W=
Argument: An increment of time
Specifies the maximum time to wait for the return of the mailer after all data has been sent
Additional Queue Features From Version 8.12 of sendmail
The following list provides details about additional queue features.
For task information, refer to Administering the Queue Directories (Task Map).
Changes for LDAP From Version 8.12 of sendmail
The following list describes changes in the use of the Lightweight Directory Access Protocol (LDAP) with sendmail.
The following example shows how these tokens differ for a “*” lookup.
Table 14–29 Comparison of Tokens
LDAP Map Specification
Specification Equivalent
Result
-k"uid=%s"
-k"uid=*"
Matches any record with a user attribute
-k"uid=%0"
-k"uid=\2A"
Matches a user with the name “*”
The following table describes additional LDAP map flags.
Table 14–30 Additional LDAP Map Flags
Flag
Description
-1
Requires a single match to be returned. If more than one match is returned, the results are the equivalent of no records being found.
-r never|always|search|find
Sets the LDAP alias dereference option.
-Z size
Limits the number of matches to return.
Change to the Built-In Mailer From Version 8.12 of sendmail
The old [TCP] built-in mailer is not available. Use the P=[IPC] built-in mailer instead. The interprocess communications ([IPC]) built-in mailer now enables delivery to a UNIX domain socket on systems that support it. You can use this mailer with LMTP delivery agents that listen on a named socket. An example mailer might resemble the following.
Mexecmail, P=[IPC], F=lsDFMmnqSXzA5@/:|, E=\r\n,
S=10, R=20/40, T=DNS/RFC822/X-Unix, A=FILE /var/run/lmtpd
The first mailer argument in the [IPC] mailer is now checked for a legitimate value. The following table provides possible values for the first mailer argument.
Table 14–31 Possible Values for the First Mailer Argument
Value
Description
A=FILE
Use for UNIX domain socket delivery
A=TCP
Use for TCP/IP connections
A=IPC
Is no longer available as a first mailer argument
Additional Rule Sets From Version 8.12 of sendmail
The following table lists the additional rule sets and describes what the rule sets do.
Table 14–32 New Rule Sets
Set
Description
check_eoh
Correlates information that is gathered between headers and checks for missing headers. This rule set is used with the macro storage map and is called after all of the headers have been collected.
check_etrn
Uses the ETRN command (as check_rcpt uses RCPT).
check_expn
Uses the EXPN command (as check_rcpt uses RCPT).
check_vrfy
Uses the VRFY command (as check_rcpt uses RCPT).
The following list describes additional rule set features.
Changes to Files From Version 8.12 of sendmail
sendmail Version 8.12 and IPv6 Addresses in Configuration
Starting with version 8.12 of sendmail, IPv6 addresses that are used in configuration should be prefixed with the IPv6: tag to identify the address properly. If you are not identifying an IPv6 address, a prefix tag is not used.
