Skip Navigation Links
Exit Print View
StorageTek 8 Gb FC PCIe HBA From QLogic Installation Guide
For HBA Models SG-XPCIE1FC-QF8-Z, SG-PCIE1FC-QF8-Z, SG-XPCIE1FC-QF8-N, SG-PCIE1FC-QF8-N and SG-XPCIE2-QF8-Z, SG-PCIE2FC-QF8-Z, SG-XPCIE2-QF8-N, SG-PCIE2FC-QF8-N, 7106958, 7106957
Oracle Technology Network
Library
PDF
Print View
Feedback
search filter icon
search icon
Document Information
Using This Documentation
Chapter 1 HBA Overview
Chapter 2 Hardware Installation and Removal
Observing ESD and Handling Precautions
Installing the Hardware
To Install the HBA
To Connect the Optical Cable
To Apply Power
Testing the Installation
To Verify Proper Installation (Oracle SPARC)
To Verify Attached Storage (Oracle SPARC)
To Verify Proper Installation (Oracle x86)
Replacing the SFP+ Unit on the HBA
Removing the Hardware
To Remove the HBA
Chapter 3 Software Installation
Chapter 4 Known Issues
Note - The HBA does not allow normal data transmission on an optical link unless it is connected to another similar or compatible Fibre Channel product (that is, multimode to multimode).
Use multimode fiber-optic cable, intended for short-wave lasers, that adheres to the specifications listed in HBA Features and Specifications in HBA Features and Specifications.
  1. Connect the fiber-optic cable to an LC connector on the HBA.
    Connecting the Optical Cable: Single Port HBA shows the single port HBA and Connecting the Optical Cable: Dual Port HBA shows the dual port HBA.
    Figure 2-2  Connecting the Optical Cable: Single Port HBA
    image:Figure that shows connecting the optical cable to a single port HBA
    Figure 2-3  Connecting the Optical Cable: Dual Port HBA
    image:Figure that shows how to connect the optical cable to the dual port HBA.
  2. Connect the other end of the cable to the FC device.
    After the optical cable is connected to the HBA, you can power on the system, if required. See your system installationg and service manual for more information.
