Chapter 2 Hardware Installation and Removal
Observing ESD and Handling Precautions
To Verify Attached Storage (Oracle SPARC)
To Verify Proper Installation (Oracle x86)
Replacing the SFP+ Unit on the HBA
The HBA can be identified in the output by looking for the SUNW,qlc@n and SUNW,qlc@n,1 node names, where n is usually a single-digit number from 0 to 9. In this example, there is a dual port HBA installed.
{0} ok show-devs
/ebus@c0
/pci-performance-counters@0
/pci@0
/niu@80
/cpu@e
/cpu@d
/cpu@c
/cpu@b
/cpu@a
/cpu@9
/cpu@8
/cpu@7
/cpu@6
/cpu@5
/cpu@4
/cpu@3
/cpu@2
/cpu@1
/cpu@0
/virtual-devices@100
/virtual-memory
/memory@m0,8000000
/aliases
/options
/openprom
/chosen
/packages
/ebus@c0/serial@0,ca0000
/pci@0/pci@0
/pci@0/pci@0/pci@9
/pci@0/pci@0/pci@8
/pci@0/pci@0/pci@2
/pci@0/pci@0/pci@1
/pci@0/pci@0/pci@8/pci@0
/pci@0/pci@0/pci@8/pci@0/pci@a
/pci@0/pci@0/pci@8/pci@0/pci@9
/pci@0/pci@0/pci@8/pci@0/pci@8
/pci@0/pci@0/pci@8/pci@0/pci@2
/pci@0/pci@0/pci@8/pci@0/pci@1
/pci@0/pci@0/pci@8/pci@0/pci@2/SUNW,qlc@0,1
/pci@0/pci@0/pci@8/pci@0/pci@2/SUNW,qlc@0,1/fp@0,0
/pci@0/pci@0/pci@8/pci@0/pci@2/SUNW,qlc@0,1/fp@0,0/disk
/pci@0/pci@0/pci@8/pci@0/pci@2/SUNW,qlc@0/fp@0,0
/pci@0/pci@0/pci@8/pci@0/pci@2/SUNW,qlc@0/fp@0,0/disk
/pci@0/pci@0/pci@2/scsi@0
/pci@0/pci@0/pci@2/scsi@0/disk
/pci@0/pci@0/pci@2/scsi@0/tape
/pci@0/pci@0/pci@1/pci@0
/pci@0/pci@0/pci@1/pci@0/pci@3
/pci@0/pci@0/pci@1/pci@0/pci@2
/pci@0/pci@0/pci@1/pci@0/pci@1
/pci@0/pci@0/pci@1/pci@0/pci@3/network@0,1
/pci@0/pci@0/pci@1/pci@0/pci@2/network@0,1
/pci@0/pci@0/pci@1/pci@0/pci@1/pci@0
/pci@0/pci@0/pci@1/pci@0/pci@1/pci@0/usb@0,2
/pci@0/pci@0/pci@1/pci@0/pci@1/pci@0/usb@0,1
/pci@0/pci@0/pci@1/pci@0/pci@1/pci@0/usb@0,2/hub@4
/pci@0/pci@0/pci@1/pci@0/pci@1/pci@0/usb@0,2/storage@2
/pci@0/pci@0/pci@1/pci@0/pci@1/pci@0/usb@0,2/storage@2/disk
/virtual-devices@100/rtc@5
/virtual-devices@100/console@1
/virtual-devices@100/random-number-generator@e
/virtual-devices@100/ncp@6
/virtual-devices@100/n2cp@7
/virtual-devices@100/channel-devices@200
/virtual-devices@100/flashprom@0
/virtual-devices@100/channel-devices@200/virtual-channel-client@1
/virtual-devices@100/channel-devices@200/virtual-channel@0
/virtual-devices@100/channel-devices@200/virtual-channel-client@2
/virtual-devices@100/channel-devices@200/virtual-channel@3
/openprom/client-services
/packages/obp-tftp
/packages/kbd-translator
/packages/SUNW,asr
/packages/dropins
/packages/terminal-emulator
/packages/disk-label
/packages/deblocker
/packages/SUNW,builtin-drivers
cd /pci@0/pci@0/pci@8/pci@0/pci@2/SUNW,qlc@0
In the next example, the .properties command output displays the properties of one port in a dual port HBA.
{1} ok select /pci@1e,600000/pci@0/pci@2/SUNW,qlc@0
QLogic QLE2562 Host Adapter FCode(SPARC): 2.03b1 06/06/08
Firmware version 4.03.02
{1} ok .properties
assigned-addresses 81060010 00000000 00002000 00000000 00000100
82060014 00000000 04000000 00000000 00004000 82060030 00000000
04040000 00000000 00040000
manufacturer QLGC version QLE2562
Host Adapter FCode(SPARC): 2.03 06/30/08
model QLE2562
node-wwn 20 00 00 1b 32 14 40 66
port-wwn 21 00 00 1b 32 14 40 66
reg 00060000 00000000 00000000 00000000 00000000 01060010 00000000
00000000 00000000 00000100 03060014 00000000 00000000 00000000
00001000
compatible pciex1077,2532.1077.171.2
pciex1077,171
pciex1077,2532.2
pciex1077,2532
pciclass,c0400
short-version 2.03 06/30/08
devsel-speed 00000000
max-latency 00000000
min-grant 00000000
#size-cells 00000000
#address-cells 00000002
device_type scsi-fcp
name SUNW,qlc
fcode-rom-offset 0000b200
interrupts 00000001
class-code 000c0400
subsystem-id 00000171
subsystem-vendor-id 00001077
revision-id 00000002
device-id 00002532
vendor-id 00001077
{1}
