Chapter 2 Hardware Installation and Removal
Observing ESD and Handling Precautions
To Verify Proper Installation (Oracle SPARC)
To Verify Attached Storage (Oracle SPARC)
Replacing the SFP+ Unit on the HBA
QLogic Corporation QLE2562 PCI Fibre Channel ROM BIOS version 2.02 Copyright (c) QLogic Corporation 1992-2008. All rights reserved. www.qlogic.com Press <Ctrl-Q> or <Alt-Q> for Fast!UTIL BIOS for Adapter 0 is disabled BIOS for Adapter 1 is disabled ROM BIOS NOT INSTALLED
The following QLogic Fast!UTIL menu is displayed.
QLogic Corporation QLE2562 PCI Fibre Channel ROM BIOS version 2.02 Copyright (c) QLogic Corporation 1993-2008. All rights reserved. www.qlogic.com Press <Ctrl-Q> or <Alt-Q> for Fast!UTIL BIOS for Adapter 0 is disabled BIOS for Adapter 1 is disabled ROM BIOS NOT INSTALLED <CTRL-Q> Detected, Initialization in progress, Please wait...
Then the following QLogic Fast!UTIL menu is displayed.
QLogic Fast!UTIL Select Host Adapter ---------------------------------------------------------- Adapter Type I/O Address Slot Bus Device Function QLE2562 9400 01 02 01 1 QLE2562 9800 01 02 01 0
QLogic Fast!UTIL Selected Adapter ---------------------------------------------------------- Adapter Type I/O Address Slot Bus Device Function QLE2562 9400 01 02 01 1 ---------------------------------------------------------- Fast!UTIL Options Configuration Settings Scan Fibre Devices Fibre Disk Utility Loopback Data Test Select Host Adapter Exit Fast!UTIL
In the example that follows, a storage JBOD has six targets attached to one port of a dual port HBA.
QLogic Fast!UTIL Scan Fibre Channel Loop ID Vendor Product Rev Port Name Port ID 0 SEAGATE ST336752FSUN36G 0205 21000004CF64C8E0 0000CC 1 SEAGATE ST336752FSUN36G 0205 21000004CF6493D0 0000CB 2 SEAGATE ST336752FSUN36G 0205 21000004CF6428C4 0000CA 3 SEAGATE ST336752FSUN36G 0205 21000004CF64C5B2 0000C9 4 SEAGATE ST336752FSUN36G 0205 21000004CF6096F0 0000C7 5 SEAGATE ST336752FSUN36G 0205 21000004CF648010 0000C6 6 SUN StorEdge 3510F D1046 215000C0FF00225B 0000CD 7 No device present 8 No device present 9 No device present 10 No device present 11 No device present 12 No device present 13 No device present 14 No device present 15 No device present
QLogic Fast!UTIL Exit Fast!UTIL ---------------------------------- Reboot System Return to Fast!UTIL
