Skip Navigation Links
Exit Print View
StorageTek 8 Gb FC PCIe HBA From QLogic Installation Guide
For HBA Models SG-XPCIE1FC-QF8-Z, SG-PCIE1FC-QF8-Z, SG-XPCIE1FC-QF8-N, SG-PCIE1FC-QF8-N and SG-XPCIE2-QF8-Z, SG-PCIE2FC-QF8-Z, SG-XPCIE2-QF8-N, SG-PCIE2FC-QF8-N, 7106958, 7106957
Oracle Technology Network
Library
PDF
Print View
Feedback
search filter icon
search icon
Document Information
Using This Documentation
Chapter 1 HBA Overview
Chapter 2 Hardware Installation and Removal
Observing ESD and Handling Precautions
Installing the Hardware
To Install the HBA
To Connect the Optical Cable
To Apply Power
Testing the Installation
To Verify Proper Installation (Oracle SPARC)
To Verify Attached Storage (Oracle SPARC)
To Verify Proper Installation (Oracle x86)
Replacing the SFP+ Unit on the HBA
Removing the Hardware
To Remove the HBA
Chapter 3 Software Installation
Chapter 4 Known Issues
To Apply Power
  1. Verify that the HBA is securely installed in the system.
  2. Verify that the correct fiber-optic cable is attached.
  3. Refer to your system installation or service manual to determine how to power on the system.
  4. Observe the light-emitting diode (LED) status for the power-on self test (POST) results as shown in the following table..
    The yellow, green, and amber LEDs can be seen through openings in the mounting bracket of the HBA. The following table summarizes the LED status conditions.
    Yellow LED
    Green LED
    Amber LED
    State
    Off
    Off
    Off
    Power off
    On
    On
    On
    Power on (before firmware initialization)
    Flash
    Flash
    Flash
    Power on (after firmware initialization)
    Flash in sequence
    Flash sequence is yellow LED > green LED > amber LED, then back to yellow LED.
    Flash in sequence
    Flash in sequence
    Firmware fault
    Off
    Off
    On (for link up) or Flash (if I/O activity)
    2 Gbps link UP/ACT
    Off
    Off
    4 Gbps link UP/ACT
    Off
    Off
    8 Gbps link UP/ACT
    Flash
    Off
    Flash
    Beacon
