| Skip Navigation Links | |
| Exit Print View | |
Sun Ethernet Fabric Operating System RMON Administration Guide |
Configuring the Ethernet Statistics Group
Enable the Ethernet Statistics Group
Disable the Ethernet Statistics Group
Configuring the Ethernet History Group
Enable the Ethernet History Group
This section contains procedures that explain how to enable or disable the RMON module. Before you can configure RMON features, you must configure your network environment, as described in Topology Example. Fatal error messages are displayed if you execute commands without enabling the RMON feature. If the RMON module is disabled, the commands have no effect even if they are configured.
