| Skip Navigation Links | |
| Exit Print View | |
Sun Ethernet Fabric Operating System RMON Administration Guide |
Configuring the Ethernet Statistics Group
Enable the Ethernet Statistics Group
Disable the Ethernet Statistics Group
Configuring the Ethernet History Group
Enable the Ethernet History Group
The event group generates events whenever an alarm condition takes place in the device. The alarm group calls the event group, so you must first create an event for the alarm to call. This section contains procedures that explain how to create or disable events. To create an event, you must set the event type (none, log, or trap) and provide an event description.
