| Skip Navigation Links | |
| Exit Print View | |
Sun Ethernet Fabric Operating System RMON Administration Guide |
Configuring the Ethernet Statistics Group
Enable the Ethernet Statistics Group
Disable the Ethernet Statistics Group
Configuring the Ethernet History Group
SEFOS# configure terminal SEFOS(config)# interface extreme-ethernet 0/15
SEFOS(config-if)# no rmon collection history 1 SEFOS(config-if)# end SEFOS(config)# exit
SEFOS# show rmon history RMON is enabled % History entry with this index does not exist
