| Skip Navigation Links | |
| Exit Print View | |
Sun Ethernet Fabric Operating System RMON Administration Guide |
Configuring the Ethernet Statistics Group
Enable the Ethernet Statistics Group
Configuring the Ethernet History Group
Enable the Ethernet History Group
SEFOS# configure terminal SEFOS(config)# interface extreme-ethernet 0/15
SEFOS(config-if)# no rmon collection stats 1 SEFOS(config-if)# exit SEFOS(config)# exit
SEFOS# show rmon statistics RMON is enabled Statistics entry with this index does not exist
