| Skip Navigation Links | |
| Exit Print View | |
Sun Ethernet Fabric Operating System RMON Administration Guide |
Configuring the Ethernet Statistics Group
Enable the Ethernet Statistics Group
Disable the Ethernet Statistics Group
Enable the Ethernet History Group
The Ethernet history group collects a periodic statistical sampling of the data collected by the Ethernet statistics group. The history group stores the samples collected from the Ethernet statistics table in the Ethernet history table (etherHistoryTable). This section contains procedures that explain how to enable or disable the Ethernet history group.
