| Skip Navigation Links | |
| Exit Print View | |
Sun Ethernet Fabric Operating System RMON Administration Guide |
Configuring the Ethernet Statistics Group
Enable the Ethernet Statistics Group
Disable the Ethernet Statistics Group
Configuring the Ethernet History Group
Enable the Ethernet History Group
This example topology illustrates a general network configuration on which you can configure RMON. The procedures in this guide are based on the values given in this example topology. The values for your site might be different. However, you can use this example as a guide to configure RMON in your network environment.
This table contains the network details for the example topology. The procedures in this guide use these values in the instructions as user input.
